03-21-2009, 05:03 PM | #26 |
low n' slo
Re: What HEI Ignition to get?
whats the benefits of having one of these over the stock ones? i need to get a new distributor because mine is all rusted up on the 67 suburban i just bought. not sure if i should get the stock one or the hei?
03-21-2009, 05:34 PM | #27 |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
03-21-2009, 06:41 PM | #28 |
User #12137
i am so glad that skip is in town and only bout 7 miles from here
03-21-2009, 09:16 PM | #29 |
I just used a stock Chevy HEI with a Summit coil and Accel wires.
03-21-2009, 11:01 PM | #30 |
I just picked yo 2. Im hoping one will work on my 307. for $45 bucks you cant go wrong.
http://cgi.ebay.com/ebaymotors/SBC-B...mZ270361047712 |
03-21-2009, 11:10 PM | #31 | |
A much hotter spark than a stock setup. It's basically an ignition upgrade. The first HEIs GM installed were in 74/75. They were a response to meeting tougher emissions brought on by the EPA. In stock form, they aren't much of a hi-performance item, but can be easily upgraded. That is, if your motor demands it. You could upgrade your stock distributor, but you mentioned a rust problem. That and some of the old stuff is just worn out. One other option is using a Petronix or a Compu fire module in your small cap stock distributor. But that rust issue, kinda makes me think a new distirbutor is the way to go.
'72 GMC custom camper 350/350 |
03-22-2009, 11:42 AM | #32 |
low n' slo
well since this motor is getting swapped later i think i might just get an original one in there. seems easier than to replace the points and weights or whatever all those rusted parts are.
03-22-2009, 01:44 PM | #33 |
Between Trucks...
I'm guessing for the price of a new points distributor you can pick up a Skip White HEI off of fleabay. HEI is a great upgrade.
Beat it to fit, Paint it to match... |
03-23-2009, 02:31 AM | #34 |
I bought a rebuilt stock GM Hei from Napa.
03-23-2009, 09:13 AM | #35 |
Wrench Wench
I just replaced points dist. with the Skip White over the weekend....." Holy power boost Batman!!" Made a huge improvement in takeoff power and idle. I also opened spark plug gap to .045, and used 74 vette wires. Would highly recommend this upgrade, and Skip White product.
If everyone had good taste, who would buy all the FORDS? Women join us!! BUSTED KNUCKLE BABES "Face it girls, I'm older and have better insurance" -Fried green tomatoes |
03-23-2009, 09:23 AM | #36 |
low n' slo
hey dave what motor and year you get it for?
08-17-2009, 09:49 AM | #37 |
C-20 Long Stroker
Hey,
Will the HEI fit in place of the stock distributor on a 1970 Suburban K10. Or do you have to get the small cap HEI with external coil. I want to do this upgrade but do want to have a fitment problem, especially when turning the distributor when timing engine. Has anyone put the BIG cap HEI in a '70 Burb 4x4 ??? Thanks, Dan
"A Hand Shake Is Your Word." Decodan ************************ 1951 Chevrolet Suburban 1952 GMC Suburban 1963 Mercury Comet 2-dr (Sorry, I know) 1963 Mercury Comet 2-dr Parts Car, (better than what I originally started with) 2010 F-150 4WD 2015 Subaru Outback (what the hey, got to have one that is not a gas hog) |
08-17-2009, 10:17 AM | #38 | |
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-17-2009, 10:39 AM | #39 |
low n' slo
I bought the red cap and I have tons of room, but mine is a 1/2 ton 2wd suburban so not sure if u have the same amount of room
08-17-2009, 04:45 PM | #40 |
I just did this to my 72 C10 350/350 - there was tons of room for me. I had to bent the oil pressure line a little but its made to do that. the stock air filter still fit.
08-17-2009, 04:56 PM | #41 |
4WD trucks have the engine set back about 2-3" though...
08-17-2009, 05:08 PM | #42 |
I've got a red Procomp mini starter like Skip White sells and it works fine. I also have had two one wire alternators and they are ok, except you have to rev up the engine to get the self exciting internal regulator to turn on and start charging. Personally, if you have a stock alternator, I would stick with that set up or maybe go with the GM 3 wire internal regulated alternator.
08-17-2009, 05:38 PM | #43 |
C-20 Long Stroker
Thanks, I only have room for maybe a finger between the firewall and cap with the stock points distributor. So unless someone with a 70 4x4 has used the BIG cap HEI with no problems I am thinking that maybe I should go with the small cap HEI and an external coil. Anyone with a 70 Burb 4x4 ???
Dan
08-17-2009, 06:05 PM | #44 |
low n' slo
ah I didn't know that I could measure from my cap to the firewall when I get home to maybe give u an idea of close it would be..I have some pics too if I can find them
08-17-2009, 06:17 PM | #45 |
i bought accel distributor with accel wires and ac delco plugs with the accel coil pack with msd cap and rotor for about $250
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
08-17-2009, 06:19 PM | #46 |
i bought accel distributor with accel wires and ac delco plugs with the accel coil pack with msd cap and rotor for about $250.. if u go to the parts store say u need hei conversion kit for a 75 chevy or something thats what i did
08-18-2009, 10:12 AM | #47 |
I can tell you that the Skip White Hei (red cap standard size) fits in a '72 2wd 3/4 ton Big Block Suburban with a little room to spare. It sure seems like it would fit in a 4x4, even with the motor set back a little.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
08-18-2009, 10:29 PM | #48 |
C-20 Long Stroker
Hey,
I went to the parts store and measured the HEI and the cap is right at 6" in diameter. I will pull the cap on mine tomorrow and measure that and also see what the distance from the center of the rotor to the firewall is. I will let you all know. Thanks, Dan
08-20-2009, 01:07 PM | #49 |
C-20 Long Stroker
OK, here's the deal.
On a 1970 4x4 Suburban you cannot use the standard BIG cap HEI. Measurement from firewall to center of distributor is about 2-3/8 inches. So maximum diameter distributor you can use is about 5 inches. That means you have to use the small cap HEI or convert to Petronix or something. Thanks to everyone for the info and help. Dan
08-20-2009, 05:11 PM | #50 |
I have put skip whites in two different trucks now. I called them directly both times. They are nice and you dont have to order online thu pay pal. I was also ordering straight universal plugs and crimpers when I got mine. I have purchaced both the standard black and the accell red styles. They are cheaper than getting a ignition module, cap and rotor.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
