09-10-2009, 10:37 PM | #1 |
Door Hinge replacement 99 Silverado
Anyone have good instructions or tips on replacing door hinges on a 99 Silverado? It looks like someone did a poor job of replacing the pins and as a result, the entire hinges are going to need to be changed.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
09-11-2009, 12:31 PM | #2 |
Re: Door Hinge replacement 99 Silverado
I was under the impression they are not really replacable, at least to us normally folks. They are welded in place to the door.
09-11-2009, 02:42 PM | #3 |
These guys were advertising on another forums, looks cool.
http://www.totalauto.com/presentation/index.html http://www.totalauto.com/
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F Last edited by bwood; 09-11-2009 at 02:43 PM. |
09-11-2009, 05:57 PM | #4 |
We sell all the same products from Total Auto.
We have installed many of their hinge replacement kits. It helps to have a door lift though or at least a makeshift if a DIY Last edited by mbgmike; 09-11-2009 at 06:05 PM. |
09-11-2009, 05:58 PM | #5 | |
I can send you the Factory replacement instructions from Gm if you want. Give me you email and I can send the file. Easier than you may think |
09-11-2009, 06:03 PM | #6 | |
Impossible to reweld them back on. GM can't even do it. You have to bolt them back on. Send me email and I can send you the factory repair sheets |
09-11-2009, 08:22 PM | #7 |
PM sent. Thanks
09-11-2009, 09:15 PM | #8 |
It should be there Bud. If you need the service kit we can send you one but any GM dealer should have it Last edited by mbgmike; 09-11-2009 at 09:17 PM. |
09-11-2009, 09:21 PM | #9 |
Just for info GM charges like $900 to do this We do it for quite a bit less
09-11-2009, 10:50 PM | #10 | |
09-12-2009, 09:54 AM | #11 | |
He now has the Factory replacement instruction sheets. The door side is easy. The body side a little harder but you need GM's kit to do it right. The door side hinge kit will cost around $60.00 each hinge. the body side less than $100.00 . Right there your looking at $320.00 w/o the hinge pins. Then you need the repair kit if replacing the body hinges. then the hinge pin kit of your choice. Factory or the newer replacement kits. It is about a 3 hour job to do w/o tearing anything up. Pictures would help. We have done many of these replacements, we do this for a living (I think). The design is a piece of crap. A big wind blows open the door on pushes the door past the liitle stop and now you have a 90 degree door and a bent hinge. |
09-12-2009, 02:15 PM | #12 |
mbgmike Are we talking about the same trucks ? I know the 88-98 body style has the pin separate from the hinges. The 99-07 hinge should have the pin incorporated with the body side hinge (on gm replacements) & a check strap separate. I was referring to a picture of his hinges. You can have all the hinge replacements. I hate them !! James
09-12-2009, 04:01 PM | #13 | |
part number 12475677 for body side replacement hinge part number 12472843 for door side replacement hinge These are replacement hinges that bolt on from GM there are NO weld on replacement ones. Here da are sorry if any confusion body side is 90.00 each door side $55.00 each Last edited by mbgmike; 09-12-2009 at 04:05 PM. |
09-13-2009, 07:49 AM | #14 |
???(Attached Images) ??? SEE mbgmike POST ABOVE FOR PICTURES
Hinge 101 ! First hinge #12472843 in top picture is 99-07 door side, bolt on replacement (welded on from the factory) , Second hinge #25863523 is 07-09 new body style lower (bolt on from the factory). Second picture #12475677 is 98 & older or 99 classic body style, body side hinge, bolt on replacement (welded on from the factory). Is your 99 Silverado the new body style (99-07) or is it a 99 classic (88-98) body style, would make a big difference on what hinges you need ? Thanks for the pictures mbgmike. James. Last edited by truckpoorpackrat; 09-13-2009 at 07:52 AM. Reason: attached images didnt attach (wrong glue !!) lol |
09-18-2009, 10:07 PM | #15 |
have you tried drilling out the holes and use an oversized bushing?
09-19-2009, 12:44 PM | #16 | |
Thats more work than the factory fix plus i doubt if that would withstand the time. The Factory fix is the way to go on this. Its really pretty simple. you drill out the holes. fish a knurled bolt up though the access hole in pillar. pull it through the oversize hole and bolt your hinge on. If their was an easier way we would do it. Last edited by mbgmike; 09-19-2009 at 12:52 PM. |
09-20-2009, 09:42 PM | #17 |
Well, finished the top hinge. Not hard to install at all but, getting the old ones off is a PITA.
09-21-2009, 06:49 AM | #18 |
09-27-2009, 07:01 PM | #19 |
It's finally complete. I have to do a little adjustment (2X4 to the door) but, it is a lot better than it was. If anyone is trying this, I would strongly recommend an air chisel.
Thanks to everyone for the help.
08-30-2016, 05:15 PM | #20 |
Can you send an email to me? My brother needs to replace his hinges on his silverado. My email is dixiegirl1629@aol.com. Thanks.
01-11-2017, 12:44 AM | #21 |
I too need help with these hinges. 2000 Silverado. Has lamb o doors n I wanna go back to stock. Help would b appreciated. Pm me
