Old 06-11-2009, 08:41 PM   #1
Slik69
ATemperature sending unit with Vortec heads
I bought a sending unit without thinking, brought it home and the threads that go into the block are wayyyyy to big. I ordered one for a 97 tahoe (my head came off of) an dit has a different connector for the wire hook-up. Will these work on the dash guage or will I need to buy aftermarket to get to work. I should probably do that anyway to see what my reading truly is.
Slik69 is offline   Reply With Quote
Old 06-11-2009, 09:46 PM   #2
Sammy
Re: ATemperature sending unit with Vortec heads
I never trusted those ol gages. Just put in an aftermarket one it comes all the adapter and so forth.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-11-2009, 09:51 PM   #3
lilred67
lilred67's Avatar
i installed my temp. sending unit in the intake. not the most desireable or accurate place to put it,but it works.
lilred67 is offline   Reply With Quote
Old 06-12-2009, 09:48 AM   #4
brian mac
I can turn down and re-thread the stock style sending unit to 3/8 pipe. This will allow it to fit into the vortec heads. Cost is 25.00. This includes a new sending unit and shipping. PM me if you have more questions.I sold two of these to board members, but I can't remember who they are. Maybe they will chime in.
brian mac is offline   Reply With Quote
Old 06-12-2009, 11:16 AM   #5
Slik69
Same thing rigtht.. as long as it works. I will still upgrade the temp guage. If this is the only way.. I will be in touch with you. I have a swapmeet in my area. I'll see if anyone has one there.. if not, we'll be in touch.
Thank you.
Old 06-30-2009, 01:15 AM   #6
Slik69
I was able to pick up locally for $10. Works perfect.
Old 06-30-2009, 06:55 AM   #7
JMac11
JMac11's Avatar
Part # please, and where ya got it would be great.
JMac11 is offline   Reply With Quote
Old 06-30-2009, 03:18 PM   #8
Slik69
I see you're a little ways away.. but mine was bought at tops auto in anaheim ca. What you could do is call them and ask for their distributors numbers. Call them, and see if they distribute to an auto parts store in your area. If not, at least you know you've got at least 3 places where they could be ordered if you needed one bad enough.
If you do decide to call Tops, ask for Kevin. He's sharpe and up on street roddin etc.
Now how accurate these guages are I don't know. I do notice though that at times, it runs a tad hotter than the old motor.
Old 09-20-2009, 03:04 PM   #9
TonyJohnson
TonyJohnson's Avatar
Since no one seems to have a correct vortec sender number for our trucks gauges, I rigged this up to get by until I find the correct 3/8" sender. Yes, I need to clean up that connection...
Parts:
Napa TS6469SB Temp Switch $7.33
Home Depot Watts A-815 Pipe Reducing Coupling 1/2" x 3/8" FIP $4.59
Home Depot Watts A-785 Brass Pipe Nipple 3/8" x 3/8" MIP $1.91
Total cost: $13.83
It isn't ideal, because the length of the sender housing goes almost to the pipe nipple. I used teflon tape to make it tighten sooner and give it some room. The waterflow around the housing won't be very good since it's inside the coupling. The good news is that it works and since our temp gauge is just a "relative" temperature reading, it works just fine. Just remember where it sits in high temp traffic situations...
Anyway, if anyone ever gets a part number for the vortec sender, it would be nice to post here.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 09-20-2009, 09:01 PM   #10
mtdave2
newly minted old timer
mtdave2's Avatar
i used the stock sensor, and just went to a pluming store and bought a step down coupler and a nipple.. works great
we talked about it in this thread
http://67-72chevytrucks.com/vboard/s...t=sending+unit
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 09-20-2009, 09:18 PM   #11
TonyJohnson
Same thing, just pipe instead of brass.
Tony Johnson
Old 09-20-2009, 09:21 PM   #12
mtdave2
mtdave2's Avatar
yeppers =)
69 k10 Suburban
Old 09-20-2009, 09:49 PM   #13
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I used the stock sender in my LT1 and used a resistor to adjust the ohms to match the old gauge. Works great.
low'n slow is offline   Reply With Quote
Old 09-21-2009, 08:54 AM   #14
TonyJohnson
Any details?
Tony Johnson
Old 09-21-2009, 12:32 PM   #15
Green Machine
Green Machine's Avatar
That's great to hear that someone is taking the stock gauge temp senders and turning them down. That is the only "correct" way to do it. There have been several people that have done that in the past, but seems like they aren't on the board very often or are gone. Finding someone to do that is like finding hen's teeth, I have 2 which is all I need right now for our trucks, but I should order a spare someday.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
