Old 09-23-2009, 01:40 PM   #101
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
looking good. steady progress.
hows the tube bender workin out?
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-23-2009, 04:03 PM   #102
onlyifihadachevy
Re: Got a new truck
It good just trying to get the degrees down like the top hoop is off on one side by 1 degree but the length is off i think, its confusing . Did not work on it yesterday but when my dad gets home we will.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 09-24-2009, 07:05 PM   #103
onlyifihadachevy
Re: Got a new truck
We worked on it some more and will a litttle later today, and pics will come later tonight as well. We got the rocker slider, the top hoop has more supports on it too.
My 72 thread
Old 09-24-2009, 11:04 PM   #104
onlyifihadachevy
Re: Got a new truck
WE did some work.
This was a few days ago
Yesterdays work sorry for bad pic.
it was wleded mostly yesterday but finished it up today, got the other side made and tacked, weld it up tomarrow, And finishing up the back half, or at least most of it. And the backhalf wil be done this weekend. We will start on the middle cage, I am going to with a exo cage. Hopefully we get the heims soon, so it will roll again. And wheel it! Should be wheeling in a month at best.
We picked up my other truck yesterday, it ran great a little loud, no stereo and boggers going down the highway.
My 72 thread
Old 09-24-2009, 11:05 PM   #105
onlyifihadachevy
Re: Got a new truck
Forgot the rock slider.
My 72 thread
Old 09-25-2009, 08:43 AM   #106
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
are you going to wheel the 1/2 tons or swap in your other axles?
my jimmy build
Old 09-25-2009, 06:20 PM   #107
onlyifihadachevy
Re: Got a new truck
I have a 14 for the rear end and working on getting a 60 front, i was thinking about a 44 or 10 for the frontend until i get a 60 which would work, with my 35s form my other truck. which i mostly will run until i can get bigger tires.
My 72 thread
Old 09-26-2009, 11:41 AM   #108
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
what about that 60 closed knuckle?
my jimmy build
Old 09-26-2009, 02:30 PM   #109
onlyifihadachevy
Re: Got a new truck
I was thinking about it still so i may use it once i find a 4.88 rear.
My 72 thread
Old 09-26-2009, 04:47 PM   #110
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: Got a new truck
cool build
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 09-26-2009, 05:23 PM   #111
onlyifihadachevy
Re: Got a new truck
Well i burnt my hand on a weld accidently touching it when trying to find the degree. But, it feels a little better, i classifed it as a 2nd degree major burn, because its bistered, and bigger than 2", I do not think is a 3rd because its not dark.
I will get a pic later, and some progress pics, my dad was still working when i was soaking it so we got some done, I was telling him what i wanted him to do.
The back is almost done being braced.
My 72 thread
Old 09-26-2009, 09:27 PM   #112
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
why not re gear the 14 bolt?
my jimmy build
Old 09-27-2009, 12:57 AM   #113
onlyifihadachevy
Re: Got a new truck
Because the cost of regearing, and that not being the gears i want. If i regear i want to get 5.13 or 5.38s, so i can have a super low crawl ratio. I am thinking grnny low, 205 low and a 5 axle would give me about 20/1
My 72 thread
Old 09-27-2009, 01:26 PM   #114
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
5.38 would give you more like a 70.6:1.
4:88 would net you bout 64:1
(i cant remember what the granny first gear really is so i used bout 6.7:1 x 1.96:1x given gear.)
either ratio you do go with you have a pretty darn good crawl ratio.
my jimmy build
Old 09-27-2009, 04:58 PM   #115
onlyifihadachevy
Re: Got a new truck
I thought g low was like 2 to 1 but i'm not sure, but i am thinking of maybe ddoing the 4.88.
we cut the top off, my dad regrets it and i kinda do but, the cage would have being a a lot harder to build with it and rust was falling off, so i think we did the best thing, next time i build a truck i want to keep the top on.
My 72 thread
Old 09-27-2009, 08:28 PM   #116
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
the sm465 granny low is something like 6.7 or lower. close to 7 almost.
post up some progress pics
my jimmy build
Old 09-27-2009, 10:15 PM   #117
onlyifihadachevy
Re: Got a new truck
Well my hand after the burn, and today, it healed fast. Which i was happy, so i could work today.
Last night, pretty the backs done, excpet the shock hoops.
Todays work,
My 72 thread
Old 09-28-2009, 12:36 PM   #118
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
trucks coming out good.
what r you going to do as far as a top? soft top?
my jimmy build
Old 09-28-2009, 06:33 PM   #119
onlyifihadachevy
Re: Got a new truck
I was thinking soft top
My 72 thread
Old 09-28-2009, 09:25 PM   #120
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
any closer shots of the back of the cage.
where the tubes tie into the back plate
my jimmy build
Old 09-28-2009, 09:46 PM   #121
onlyifihadachevy
Re: Got a new truck
I will get a few, don't make fun of my welding it has gotten better, a lot better. The real welds holding it together are great beads that my dad did but the ones over it aren't good because i was trying to fill the gaps at the corners. A quarter inch bead in 2 spots on a tube will not break hitting it with a small sledge so it should be good.
My 72 thread
Old 09-28-2009, 09:59 PM   #122
onlyifihadachevy
Re: Got a new truck
The furthest back part, sorry for the bad pic, my iphone doesn't upload pics well. And i lost my moms camera.
My 72 thread
Old 09-28-2009, 10:13 PM   #123
onlyifihadachevy
Re: Got a new truck
I also plan on weldig a bar right next to the plate, perpendicular to the ground, for additional strength, between the bars.
My 72 thread
Old 09-29-2009, 01:24 PM   #124
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Got a new truck
good idea. what are you going to run for tires?
my jimmy build
Old 09-29-2009, 06:24 PM   #125
onlyifihadachevy
Re: Got a new truck
I think my 35 boggrs from my other truck seeing as it doesn't need them for pavement pounding. And no money.
I want 44 boggers, or rockers. Maybe if i am lucky my uncle will let me use his 44 truxs tires, not really aggersive but should work.
My 72 thread
