Old 09-26-2009, 10:47 AM   #1
blazer2007
input on this setup
I was looking for ideas to do the rear,I saw this and it looked simple.Is this a good setup,won,t let me upload the pic but is a 2 link where the link goes from the rearu bolts and connects to the old spring hanger
blazer2007 is offline   Reply With Quote
Old 09-26-2009, 11:00 AM   #2
SCOTI
SCOTI's Avatar
Re: input on this setup
Like this....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-26-2009, 11:04 AM   #3
SCOTI
SCOTI's Avatar
http://www.ekstensive.com/
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-27-2009, 10:24 AM   #4
blazer2007
ya like that,is it ok
Old 09-27-2009, 10:30 AM   #5
SCOTI
SCOTI's Avatar
There are those that think they're great; there are those that think they're not so great. I looked into this set-up for my 74, but decided against because of the drastic amount of pinion angle change they are capable of as the suspension cycles through compression/extension.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-27-2009, 10:41 AM   #6
blazer2007
so what did u decide to go with
Old 09-27-2009, 12:30 PM   #7
Rochlow
I drove on an Ekstensive 2-link for years in my 97 x-cab and never had one problem with it.
Just this summer I swapped the panhard for a watts link. Worked like a charm..
I never changed the air pressure while driving... Raised it to drive height, layed it out at a show...
Rochlow is offline   Reply With Quote
Old 09-27-2009, 03:26 PM   #8
SCOTI
SCOTI's Avatar
I left the flip-kit + shackles in & added a home built air-over-leaf so I could tow my trailer.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-28-2009, 10:24 AM   #9
blazer2007
would u happen to have any pic of your homemade setup
Old 09-28-2009, 11:05 AM   #10
SCOTI
SCOTI's Avatar
Look here, page-15 starting w/post #366.... http://67-72chevytrucks.com/vboard/s...d.php?t=223158
I followed this logic but mine has the upper home-made bag plate welded to the bolt-in c-section & the lower bag mount is the original leaf spring pad on the top of the rear end housing. My bags are bolted in from the top & float on the bottom using an allen bolt in the bottom of the bag to locate it on the spring perch.
Before I did mine, I PM'd Kevin to inquire about how the dbl convoluted worked for him. He said he ran it w/o air psi when he didn't need the extra capacity so you don't even know they're there. I agree.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-28-2009, 02:46 PM   #11
blazer2007
thank you
