11-01-2009, 11:17 PM | #51 |
VA72C10
Re: Project: Agent Orange
In
Looks like a cool project and great work so far!
Looking for a 67-72 swb or blazer project in or around VA. |
11-01-2009, 11:41 PM | #52 |
GEARHEAD
The masking would probably be easier if you used plastic sheet instead of newspaper. I'm not saying, just saying, ya know...
Looks like a good result though, the name definitely fits the finish.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-02-2009, 12:17 AM | #53 |
SWB 4x4 Collector
Plastic sheets are not the best for using as a masking barrier. Paint can "sit" on top of it unlike a paper barrier where it absorbs and dries. When you go to pull plastic off you can leave paint chips or even paint that isn't dry onto your new paint job. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-02-2009, 06:50 AM | #54 | ||
We'll see what the ceramic layer does for it. Quote:
Your right, Lizard Skin...lol New pics, same spot of what it's looking like this a.m. as it's drying, calming down a lot too. |
11-02-2009, 09:09 AM | #55 |
I feel sorry for the guy that has to scrape that off, in 100 years!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-02-2009, 09:32 AM | #56 |
That is a big difference. Looks smoother.
11-02-2009, 09:35 AM | #57 | |
With luck, it'll be one of my great grand kids! Never thought I'd do this to a truck but in this case, it made good sense for the intended use & abuse it's going to see. Build em to drive em baby! |
11-02-2009, 09:37 AM | #58 |
11-02-2009, 09:38 AM | #59 |
Looks good! What is the cure time on that stuff - does it need heat to dry out - since it isn't that warm here (or there) much longer -
11-02-2009, 09:57 AM | #60 | |
First coat seemed to dry enough to spray over in a couple hours, heat was @ 65 degrees in the shop. I used a heat gun a little bit to help it along so I could spray the 2nd coat before ending my day in the shop, only had to hit the nooks & crannies. the flats were dry. I applied the 2nd coat really heavy and there's still a couple places were it hasn't dried yet and I kept the shop @ 60 degrees all night. Going to leave the heat @ 60 with hopes of being able to apply the ceramic layer tonight after work. Haven't decided if I'm going to apply color to this section while it's masked off or whether I'll continue onto the bed area with the liner, at least spray color on the firewall & under the dash to avoid over-spray later I'm thinking. Last edited by vtblazer; 11-02-2009 at 09:58 AM. |
11-02-2009, 10:33 AM | #61 |
Does that stuff come in colors or is it only gray? Looks good VT!
11-02-2009, 11:13 AM | #62 |
The thing that turned me off about the lizards skin is the fact that it is sandable. That just makes it sound like it wont last as long as bed liner.
11-02-2009, 11:17 AM | #63 |
AWESOME!!
So next winter I can drop of my K5 and pick it up early spring? That should be enough time for you to LIZARDSKIN my rig hahhaaa Too much again hehehe One of these years I need to do something about my floor...it's not too bad but year after year I can see the rust taking it's corse...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
11-02-2009, 01:27 PM | #64 | ||
Just flat black when it's dry but it's paintable.
Two other things to consider though, #1 - it's paintable where others are not & #2 - it cleans up with water. Quote:
When we're done with Moab next year, tag along with Greg & I on the trip home and fly back to Cali leaving it here to be fixed up, then the following Sept. fly out and we'll pull a caravan out to Moab again! See how easy... Last edited by vtblazer; 11-02-2009 at 01:49 PM. |
11-02-2009, 01:43 PM | #65 |
Dried & outside in the sunshine.
11-02-2009, 01:46 PM | #66 |
hahaha
Looks like a great product! Thanks!
11-02-2009, 05:09 PM | #67 | |
But for the people talking about it being hard to remove, it is not a bedliner, and thus would be easier to remove. I do plan to try it out, but on a car where it will be covered by carpet. |
11-02-2009, 05:21 PM | #68 |
How do you plan on using it VT? Just as it is, or are you going to cover it?
11-02-2009, 05:29 PM | #69 | ||
Going to use a base/clear system. There is a noticable difference now when rapping on the metal, a fair amount more muffled. |
11-02-2009, 05:51 PM | #70 |
Ceramic coat dried up.
Didn't really apply it "as per instructions" but I think it laid down better my way. |
11-02-2009, 06:11 PM | #71 |
Whats the surface like after it dried? Is it hard, or more soft and rubber like?
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
11-02-2009, 07:36 PM | #72 |
That really looks good dude!
11-02-2009, 10:57 PM | #73 |
Junior Member
Looks good.
1967 Camaro (in pieces) 1972 Chevrolet K/5 Blazer 1969 Chevrolet K/5 Blazer 2000 Chevrolet K2500 Crew Cab 454 1999 Chevrolet Blazer 2008 Polaris Ranger XP Orange Crush |
11-03-2009, 01:05 PM | #74 |
Some how seems brighter in the shop now...
Base coat, still wet but ya can get the idea. |
11-03-2009, 01:39 PM | #75 |
Had to air out the shop...
