Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-06-2009, 12:10 AM   #1
Super73
Super73's Avatar
New weight.. 3,620 with me in it.
Just want people to put info up for people.. Might help them..
Previous weight 3,850 with a half tank of gas. 2,050 front (52.7%) and 1,800 rear (47.2%). This was with my tailgate down (added weight to it so there is a leverage ratio)
Still have the steel front, but no hood/springs, and inner fenders cut out.
Swapped the bench seat for Summit Racing plastic seats.
Made my front crossmember but swapped intakes (plastic to alum) this was technically a wash as I shaved 25lbs but added 25lbs.
New weight 3,620 with a full tank. 1,880 front (51.9%) 1,720 rear (48.1%). This was with my tailgate up so no extra leverage.
Not exactly sure how I got +230lbs out from the last track outing. by my math I only come up with about 150lbs.. But I'll take it!!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 10-18-2009, 12:45 PM   #2
phipp13
THE DAMN YANKEE
phipp13's Avatar
Re: New weight.. 3,620 with me in it.
nice what #s you runnin now? any new video?? would like to see some.
phipp
phipp13 is offline   Reply With Quote
Old 10-18-2009, 02:31 PM   #3
Super73
Super73's Avatar
Phipp.. Unfortunately I'm out of work right now and my mortgage is more important than spending $250-$300 going to the track. it's 198 miles away, so it's a bit of an expense.. Someday..
My very late street night pass on my fairly accurate G-tech (with in .1 and 1mph at the track) says I a 7.68 @ 96.5mph in the 1/8 on a spinning slow 1.89 60' So it should on a good hook go 11.50's maybe on motor??
Old 10-18-2009, 03:15 PM   #4
cableguy0
good deal every little bit helps. these old tanks need all the help they can get to get moving
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-21-2009, 01:31 AM   #5
CreditGod
my dad got a truck down to 2800 pounds but we used a smoke wrench on anything we could find we also took out the radiator support and used angle iron to hold the fenders straight, if you really start looking around you can cut weight if you think about it the windows in that thing with the tracks weigh about 30 pounds a piece. you can take more wright out get it on a lift and look under it there is extra bracing everywhere just look real hard.
CreditGod is offline   Reply With Quote
Old 10-21-2009, 01:41 AM   #6
Super73
Super73's Avatar
What year truck?
What trans and motor?
Old 10-21-2009, 01:48 AM   #7
CreditGod
1966 swb with a small block in it add 170 pounds if it is a big block
you can trim the inside of the fenders,doors, you can cut the floor and use aluminum in its place you just have to take your time and think also that front wind shield is heavy you can by lexsan in 4x8 sheets.
there is easily 100 pounds on the frame that can be trimmed
Old 10-21-2009, 02:19 AM   #8
Super73
Super73's Avatar
i have been working on finding weight to cut. The 3,620 (3,420 with out me) has the following done..
Alum block and heads (LS1)
Trans is rather heavy being an OD 4L80E, I'm sure there is a 100lb saving using a glide.
Bench seat replaced with Summit racing seats
No front bumper
Alum wheels (15x12 315/60/15 drag radial rear / 15x6 front with a 195/75/15 front)
No hood
Inner fenders cut out
Alum radiator
Gas tank replaced with a plastic fuel cell in the back of the bed
Heater removed
Roll pan in rear
The glass front i plan on putting on i think will cut another 40ish lbs.
I need to swap tailgates out as i have about 100lbs added to it.
I have a tow hitch made from 2x4 that probably weighs 30-35lbs that needs to go
I would like to go with a Mustang 2 front when I have a job again. No idea on this.
I have a brake booster that needs to come off (alum brake master) 10-15lbs?
When i can, I'd like to make a new frame from either 2x3 or 2x4 .120 wall.
Windows are definately something I have thought about, but the truck is still driven on the street and get's parked out side on a regular basis.
More ideas would be great..
Old 10-21-2009, 03:37 AM   #9
CreditGod
Oh sorry our was just a drag truck it just looked like a daily driver
our gas tank "fuel cell" was in the back and the battery
but seems like eventually you will get down to about 3100
good luck and have fun with the smoke wrench
Old 10-21-2009, 01:48 PM   #10
The Big Green
How are you weighing it? Track with a scale? Around here I've heard you can weigh in at a big truck scale, just have to pay something and they would let you weigh in. What's the weight of your truck in stock form? I have a '91 S-10 and I want to start getting the weight down.
The Big Green is offline   Reply With Quote
Old 10-21-2009, 01:55 PM   #11
CreditGod
digital scales like the ones that dirt track people use I don't know the original weight we started cutting on it 30 minutes after we got it it took us two weeks to trim it all down
Old 10-21-2009, 10:34 PM   #12
Super73
Super73's Avatar
i normally weigh mine at a local truck scale and at the track when I go..
Old 10-21-2009, 10:35 PM   #13
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Damn super that's RAD. Your are going to be all over that roll bar mark.
If I could put my pig on that type of diet, I also would be smashing my way into the lower 11's
How much did you want for those front springs?
68 C-10 KID is offline   Reply With Quote
Old 10-22-2009, 10:21 PM   #14
fast_dev
fast_dev's Avatar
the diet helps alot, mine weight 3450 with me in it. small block and a stick. all steel body. rad support chopped down alot, no inner fenders, plastic seats, no gate or rear bumper, plastic cell. etc.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 10-27-2009, 11:22 PM   #15
phipp13
THE DAMN YANKEE
phipp13's Avatar
super 73, sorry to hear about the work situation! this economy needs a boot in the ass to keep it going. NOT GETTIN TO POLITICS WITH ANYONE! I hope you find employment soon. v/ phipp
Old 10-28-2009, 01:20 AM   #16
Super73
Super73's Avatar
Thanks Phipp.. i hope i do too. I want to go racing..
BTW, I have been experimenting with front and rear springs again. since the recent weight loss, i think i might have a spring that will work just as good as the moroso, but it will come from a junk yard for less money, BUT, your front weight would have to be very close to mine. I can tell you one spring that is a little too soft, but the right length, a Jeep Cherokee 6cyl front spring.. 17 3/4' long, but about a 160lb rate. Puts my truck a touch tooo low. The LaC shafts are literally 1/2-3/4" off the ground right now. If your front weighs 1,650, they would probably be on the money.. Gonna try the grand cherokee next.
Old 10-28-2009, 11:28 PM   #17
Super73
Super73's Avatar
Jeep Grand Cherokee V8 springs are money in my truck.. 17 3/4 inches long, guessing 190-200lb rate (I didn't measure compressed ride height so not 100% sure).
Old 10-28-2009, 11:52 PM   #18
Rodms
Rodms's Avatar
73 I hope we drop to around 3300 or so with the fiber hood,only thing else is to start cutting,You know what I mean,It may happen this winter,I don't want to sell it since I bought it new but may if I can get the old nova at 600 bucks,And I just bought a new hood!!!!!!!!!!!!!!!!!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 10-28-2009, 11:58 PM   #19
Super73
Super73's Avatar
Please let me know if I can help you once things are semi finalized..
Old 11-09-2009, 01:40 PM   #20
Wasted Income
Boosted Member
Wasted Income's Avatar
Mine weighs in at 3950 without me in it.
LWB Fleet
Air bag suspension (no tank or compressor)
steel roll pan
Iron block, aluminum head LSx
4L80E
Looking to put her on a diet this winter, and add some more power
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
