![]() Join Date: Jun 2008
C40 engine?
i have a shot at getting a big block out of a c40 for 300 bucks
Re: C40 engine?
Most likely a 366 and not a real good motor. It was a truck motor but not good for performance.I had one in my 66 C50
69 Chevy 4x4 383 Power ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: C40 engine?
I agree, likely a 366, which is a tall deck engine with little bores.
The small back window thing doesn't mean anything on big trucks either. They used small windows way up into the 80s on heavies.
Re: C40 engine?
alrighty thanks guys ill get some casting numbers off the block next time i go back
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Re: C40 engine?
I don't think a 427 was offered in the C40, maybe not even the C50. I think you had to step up to a C60.
But I could be wrong, it wouldn't be the first time ![]()
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Re: C40 engine?
yea im just gettin my hopes up its prolly a 366
its all about the +6 inches
Re: C40 engine?
unless its a 427, i wouldn't even bother
Re: C40 engine?
I've heard the 427 truck engines are really torquey (?) motors. In terms of overall performance, are they worth using? Or would someone be better off with just a good ol' 396 or 454?
![]() Join Date: May 2007
Re: C40 engine?
Even if it's a 427, it's probably a tall deck block. Find yourself a 454.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Hollister Road Co.
Re: C40 engine?
The 67 C40 6 wheel dump I drove had a 348. My 70 Box truck had a small block. Depends on what body it had. On or off road and GVW
Re: C40 engine?
348 wouldn't have been original if I'm not mistaken.
The 427 would indeed be a tall deck... but the steel crank is worth a couple bucks, and then there's some people wou atill think a 40 year old block is a good idea for a 500+ cube 'mountain motor'. I wouldn't use it if it was ready to stab in my truck. I'd use it to make money then grab a big block that is worthey. |
Hollister Road Co.
Re: C40 engine?
![]() Join Date: Apr 2001
Re: C40 engine?
From what I have been reading a 366 and 427 Truck motors are just that Great truck motors... I am seriously thinkng about a 427 in my 3x4 4x4 build i am planning. It will never see the far side of 4500 Rpm and rock solid internals... remember these things hauled huge amoutns of weight over the road for many years... i will probably do a close to stock rebuild and drive the he** out of it... depends on what you want, if you went 366 you could prolly score a nice running engine for 50-100 dollars cuz no one wants them... throw it under your hood and brag up as a big block
![]() --Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Well, Whoop-dee-do!
Re: C40 engine?
At 4:37, our tall deck that isn't "worthy" comes on the track for a 8,600 rpm 1st place run. Nothing very trick about it, it still has iron heads and steel rods. Over 40 hooks on it this year with nothing more than an oil change and 2 valve adjustments.
#15 |
Re: C40 engine?
OK... they can be built up... how much do you have in it if I may ask?
#16 |
Well, Whoop-dee-do!
Re: C40 engine?
My ownership consists of sweat equity, a 1 ton frame I had, and about $300 I spent on doors and a hood scoop
![]() It's kind of tough to say what my partner has in the engine dollar wise. It came with a truck he traded another truck for. The engine was built by a reputable shop 2 years ago, and came with the parts specs. Carb to pan would have to be at least 15K based on that. Looking at it that way, a tall deck isn't a good choice for an affordable street engine. I don't have 2,500 in the engines of my 3 trucks combined. CSOB club member here for sure ![]()
#17 |
70 Chevrolet=Obsession
Re: C40 engine?
I like the exhaust pipes on those trucks. I think I'll do that to mine!
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
#18 |
Re: C40 engine?
you can get 1500 horses out of a quad 4, but it isn't cost effective.
