Location: Sunny, Florida, some might call it South Alabama
Installing a T-56
I did a search and didn't really find a thread specifically talking about this so i thought I would start one. I just bought a T-56 transmission it came out of a '96 Camaro Z28. My truck was a 3 speed on the tree when i first got it, I converted it to an auto. What all am I going to need to make the T-56 work other than cutting a hole in the floor and re-installing the clutch pedal assembly.
Thank you in advance, Brandon
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
member #16
![]() Join Date: Dec 1999
Re: Installing a T-56
You might have already read this post by brad on his T5 install, if not there might be some useful parts on your T-56 install.
http://67-72chevytrucks.com/vboard/s...d.php?t=313954
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
I have one I have thought about installing also but I think without relocating the shifter it will be very far back? You might check that and see. I did see a post on here (I think) on relocating to the center access cover.
I will keep watching as I am thinking this direction also. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Thanks so far, keep em coming please.
Probably have to convert to a hydraulic clutch setup.
Come up with a speedo solution (electronic output on tranny) Driveshaft shortening (probably) Devise some sort of circuit to enable/disable the reverse lockout solenoid as well as the 1-4 shift solenoid. Good luck.....it will be worth it if you can get through these issues. |
Thank you, I was hoping that i could piggie back off of someone else's glory, I know I have heard of guys running these tranny's in our trucks.
Shifty might chime in....i know he has one that he plans on installing.
I am planning on installing one eventually. i do believe that you have to go with a hydraulic clutch. and you will have to run bucket seats due to the shifter being so far back. i also think that you have to reinforce your firewall due to the clutch, i could be wrong about that. i seems like i just saw something on a different forum where a company make a bellhousing adapter plate for this install. |
How hard is it to convert to a hyd. clutch? Also Would I be able to run a late model (1999 and up) seat, or would those also be in the way?
On the path to financial ruin!
![]() Join Date: Jan 2009
The T56 only comes as a hydraulic clutch setup. Yes......
1. You will have to reinforece the firewall to keep the clutch pedal from pushing thru. 2. You will have to modify your trans tunnel/hump and relocate the tranny crossmember. 3. Buy an adapter plate for the bellhousing if you don't have an LS(Gen III/IV motor) 4. Hook up a clutch pedal for the clutch. 5. Shorten your driveshaft 6. Change your rear gears, because if you don't 6th gear may be virtually unusable. There's a few other small variables in there, but that's pretty much it.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
So i won't be able to run 410s? I would think that would be the perfect gear for a 6 speed, but if not plesae elaborate. I would need to cut a whole in my floor I know. But would I need to modify it to a high hump? Also please break down what you mean by reinforcing the firewall so I won't push the clutch pedal thru. And just so I'm on the same page. Will I be able to use the clutch setup that actually came in my truck? Or will I need to build and/or modify something?
410's would probably be a good all around gear depending on the size of tires you run. I have the T56 in my 94 Z28 and run 3.73's, but my tires are most likely smaller than a tire used on a truck. As for the Skip shift, all you have to do is leave it unplugged and it will never activate. For the reverse lockout, it's pretty easy to push past it. I never hooked mine up as I converted my Z from an auto to T56. Even with a short shifter on it, it's easy, and with an extended shifter need on our trucks, it wouldn't be bad at all. If you did want to hook it up though, I guess a properly positioned microswitch could be used so that when you go full right, it would hit the switch and allow the reverse lockout to disengage.
Crazy |
#12 | |
4.10s will be great. My F-bodies/corvette had 3.42 gears and they were fine (stock tires, a little lighter weight). For the clutch pedal, you'll need a clutch master cylinder and come up with a way to acuated it. And then you're required to take pictures and post them to show others how you did it ![]() |
#13 | |
#14 | |
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 Last edited by 68jewel; 11-30-2009 at 08:47 PM. |
#15 |
Awesome. Thank you for breaking that down for me
#16 |
No problem bro. Just do us a favor and post plenty of pics when and if you decide to do this.
#17 |
No problem...it'll be a little while...the transmission has to be delivered and I'm pretty sure that I'm going to build a 393 in the mean time.
#18 |
a "383"
#19 |
Well I was doing the math, and if a 383 bored .030 over is a 388 then wouldn't a 383 bored .060 over be a 393?
#20 |
good question.... sounds like lots of power to me..
#21 |
A .060 over 350 block w/a 3.75 stroke crank is 388ci. W/an offset grind on the crank (3.8 stroke) & .060 over-bore, you'd yield 393ci.
#22 |
Thanks for explaining, but I'm still confused...so .030 bore on a 350 makes it a 355 but it takes a .060 bore on a 383 to do the same?
#23 | |
4.03 x 3.48 = 355 4.06 x 3.48 = 360 4.03 x 3.75 = 383ci 4.06 x 3.75 = 388
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-01-2009 at 12:02 PM. |
#24 |
Alright, I understand. I never realized that for it to be a 383 that it should have a .030 bore. Thank you for helping me out. Alright, now back on topic. Has no one installed a T-56 in one of your trucks before?
#25 |
Me personally, I wouldn't bore a block .60 over. You've taken the cylinder walls to it's thinnest boundaries. Therefore, heating issues become a problem as far as the amount of heat produced within the cylinder walls by the pistons and this affects the tolerances of heat in your block. I know alot of people do bore .60 over but, it's just my opinion.
