Old 12-11-2009, 01:33 PM   #51
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
3r!c84
The little guy was $240 in the polish $200 for the natural finish
smokedat is offline   Reply With Quote
Old 12-12-2009, 02:30 PM   #52
smokedat
smokedat's Avatar
Re: LS1 Swap to a 73 cheyenne
Old 12-12-2009, 02:39 PM   #53
smokedat
smokedat's Avatar
Old 12-12-2009, 02:45 PM   #54
smokedat
smokedat's Avatar
gas tank
Old 12-12-2009, 02:52 PM   #55
Damien
Damien's Avatar
I'm not a big fan of Airtex or Carter Fuel pumps. I would have grabbed a Delco. They just seem to out last the rest.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-12-2009, 07:04 PM   #56
clinebarger
You may already know but you need different clamps and high pressure hose between the pump and sender, The low pressure hose will blow or the plastic clamps will give, causing a major fuel leak inside the tank.
clinebarger is offline   Reply With Quote
Old 12-12-2009, 07:36 PM   #57
rongstad
Future: 86 on GenIV power!
x2............change to high pressure hose and plastic to stainless clamps
rongstad is offline   Reply With Quote
Old 12-13-2009, 02:24 PM   #58
smokedat
smokedat's Avatar
thanks for the input will upgrade the clamps
Old 12-15-2009, 03:12 AM   #59
smokedat
smokedat's Avatar
new bumper
Old 12-15-2009, 03:18 AM   #60
smokedat
smokedat's Avatar
nade shifter
Old 12-15-2009, 09:09 AM   #61
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by 78-5.3 View Post
i used factory tahoe fule lines in my truck im amazed it not used as much??
i got them from a wreck 2001 tahoe your engine being from a camaro? why not look a the fuel lines from that?? i did some slight rebending but it followed down the back of the engine on the transmission across to the chassis rair down to the tank where i modified it to suit my 78 job done im sure the camaro lines have a similar setup
This is a good idea if you can make them work in your truck.
Old 12-15-2009, 09:32 AM   #62
menace121978
menace121978's Avatar
looking good man! you arent messing around!
btw, what mount plates are you going with for the LSx?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-15-2009, 02:46 PM   #63
smokedat
smokedat's Avatar
btw, what mount plates are you going with for the LSx?[/QUOTE]
the motor mount plates are from S&P, allows you to bolt LS-1 to original V-8 motor mounts
Old 12-15-2009, 05:23 PM   #64
mcbassin
Still Learning
mcbassin's Avatar
Looking Good!
Old 12-15-2009, 06:53 PM   #65
JohnC
JohnC's Avatar
Sweet!
JohnC is offline   Reply With Quote
Old 12-15-2009, 07:24 PM   #66
smokedat
smokedat's Avatar
Keep it cool, so i got my electric fan today and I just finished mounting it. The fan is from Jegs its their dual 12'' S-blade reversible but im going to run it as a puller, sweet fan it eavan had a rubber type cushion. For the wiring i used the Perma Cool's adjustable prope type Kit. Dual fans require a 30 Amp relay sold separately, 160°F - 210°F "Vari-Cool" adjustable electronic fan control. To mount it i used Perma Cool's metal strap kit, had to bend to custom fit.
Old 12-15-2009, 07:27 PM   #67
smokedat
smokedat's Avatar
more pics
Old 12-15-2009, 07:30 PM   #68
smokedat
smokedat's Avatar
Old 12-15-2009, 09:32 PM   #69
rongstad
nice....very nice
Old 12-15-2009, 10:30 PM   #70
3r!c84
Badass
3r!c84's Avatar
nice dog bone lol and the parts are good too lmao
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-16-2009, 01:53 AM   #71
menace121978
right on man... the pics say a thousand words! good stuff!! thanks for the reply also
"Dennis the Menace"
Old 12-16-2009, 02:18 AM   #72
smokedat
smokedat's Avatar
I apologize for the deleted double posts, my thread got moved and caused double posts
Old 12-16-2009, 02:49 AM   #73
shrtbx
Very cool build i keep debating on putting the ls into my truck as well. I was at half off sale a few months ago and saw a ls motor out of a camaro getting wheeled up to the cash register. I was sick to my stomach.....if only i was there earlier.
shrtbx is offline   Reply With Quote
Old 12-16-2009, 09:18 PM   #74
smokedat
smokedat's Avatar
This is how it sits now, after the swap the front will rise about 2" +or- due to the lighter aluminum block. I will have to adjust the front suspension to have it sit like this again.
Old 12-16-2009, 09:25 PM   #75
smokedat
smokedat's Avatar
73c10, c10, cheyenne, ls1, swap
