Old 11-04-2009, 11:33 PM   #101
brian69longbed
brian69longbed's Avatar
Re: My 69 lonbed
there's always something that needs to be done. this is temporary considering im not sure if it will work with the rims i want. 20x10 zero off set. axles were installed for mock up and rolling chassis. gonna run 5 on 5. anyone got any for sale???
sand blasted, thanks harbor freight!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 11-04-2009, 11:35 PM   #102
brian69longbed
Re: My 69 lonbed
the right way to remove factory bracketry
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 11-04-2009, 11:42 PM   #103
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Looks good. Glad to see progress...
Old 11-04-2009, 11:45 PM   #104
brian69longbed
Re: My 69 lonbed
woo hoo page 5! ha ha yeah its been eating at me to work on it. SOMETHING...
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 11-05-2009, 12:02 AM   #105
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
I know I'm slacking on mine between work and family not much time...plus, I'm waiting for parts to arrive....I still have about a billion things I could be working on but it's hard to get over there w/ the hours I put in and still see my girls so the truck is the one that suffers
Old 11-05-2009, 08:26 AM   #106
0331grunt
Now what??
0331grunt's Avatar
Re: My 69 lonbed
progress is progress...
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 11-12-2009, 12:28 AM   #107
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Attachment 510907
Attachment 510908
Great progress, glad I checked in it again. Just curious, what is the "right" way to remove the factory mounts? I may be doing the same thing on mine if I decide to buy a donor burb (86 5 hole). Plasma? Torch? or the cut-off wheel method? something else?
Old 11-12-2009, 03:43 PM   #108
brian69longbed
Re: My 69 lonbed
well the brakets are either 3/16" or 1/4". you'd have to have a fairly decent plasma to get them off. the cut off wheel would take forever and you'd constantly have to change the wheel. i used oxygen acetylene torch with a scarfing tip. it worked well and with little clean up. for the clean up i used a 4 1/2" grinder with a sand paper wheel. it was all very little effort for a very good turn out. hope it helps
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 11-17-2009, 12:04 AM   #109
brian69longbed
Re: My 69 lonbed
kind of irrelevant but here i am last weekend in the desert. it's riding season![IMG][/IMG]
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-16-2009, 09:06 PM   #110
brian69longbed
Re: My 69 lonbed
OK starting to get back on track... here are some updates.
i started fixing the small dents in my front fenders, the decided to work on shaving my marker lights.
i cut out the marker light attatchment point. I made a panel with a step in it using this cool stepping tool that goes in a air hammer. the panel goes in from the back side of the fender. i tacked it in place and then used silver solder brazing rod and sealed the panel to the fender. now its sealed, as with welding a pinhole could mean rust down the line. check em out
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-16-2009, 09:09 PM   #111
brian69longbed
Re: My 69 lonbed
the only down side to brazing is the heat, BUT... i already straightened the area. it came right back with minimal effort.
it took 3 rods of silver solder to do this marker. i learned as i went...
the three rods were 27 bucks! need to get more, they come in packs of 3.
STAY TUNED!!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-16-2009, 09:55 PM   #112
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Attachment 524768
STAY TUNED!!
Looks like a very strong joint using sivler solder. Just curious why you decided to go this direction? Just an experiment? It seem like a mig or tig would be signifcantly cheaper and hard to keep the heat level down. I really like the way you made the lip on the edge to overlap the joint. Keep it up!
Old 12-17-2009, 10:37 AM   #113
brian69longbed
Re: My 69 lonbed
originally i was going to mig it but then my boss made a good point. when you mig sheetmetal you have to tack and tack and tack etc. until your piece is fully welded. with tacking you could still have a small pine hole and not know it. this means moisture and rust down the line. the silver solder flows into the seam, sealing it completely.
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-17-2009, 07:09 PM   #114
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: My 69 lonbed
Dude..Your doing a great job...I have not been to this side of the forum much since I got Sweet Pea done....But awesome work...Cant wait to see it all together.
bad6772 is offline   Reply With Quote
Old 12-17-2009, 11:59 PM   #115
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Very good point! I am doing Tig only on all our sheetmetal but it's still very difficult to keep from not getting small pin holes unless your metal is very clean. It's also a lot slower than mig, but it's still cheap.
BTW that desert trip looked like some serious FUN!
Old 12-18-2009, 11:05 PM   #116
sgaylord
Project collector
sgaylord's Avatar
Re: My 69 lonbed
Nice work!
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 12-25-2009, 11:07 PM   #117
brian69longbed
Re: My 69 lonbed
santa loved me this year
my 2 ton cherry picker, used for cab removal and install with ease,. oh yeah and for my engine too... ha ha
brothers urethane cab and core support body mounts
EZ wirings 21 circuit wire harness
i also have Marquez Designs tail lights in the mail and Nate from porterbuilt is sending me my new hood hinges
TIME TO GET MOTIVATED FOR 2010!
MERRY CHRISTMAS EVERYBODY!!!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-26-2009, 10:43 AM   #118
0331grunt
Now what??
0331grunt's Avatar
Re: My 69 lonbed
guess I wasn't as good as you .. Looks like you got some cool stuff. Hope it motivates you to get to work on it!
01 Tahoe- wifes
my, um, build
Old 12-26-2009, 01:01 PM   #119
orange71
Re: My 69 lonbed
Im giving you by the end of the day to have one of these parts installed!
orange71 is offline   Reply With Quote
Old 12-26-2009, 06:46 PM   #120
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
Man, nice set of parts. I'm going to be running the Marquez lights on mine as well....like how they give the frenched appearance.
Old 12-26-2009, 11:36 PM   #121
mcbassin
Still Learning
mcbassin's Avatar
Re: My 69 lonbed
Santa must have thought I was a bad kid, I didn't get anything like you got. Those are some nice looking parts! I would love to score a enging lift like that.
Old 12-27-2009, 12:42 PM   #122
brian69longbed
Re: My 69 lonbed
its a harbor freight lift, under 200. its a 2 ton and stores pretty small. a great deal
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-28-2009, 11:23 PM   #123
brian69longbed
Re: My 69 lonbed
CHRISTMAS IS OVER!!! finally i can focus again... ha ha
got a solid 3 hours on the front left fender today
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 12-28-2009, 11:26 PM   #124
VA72C10
VA72C10
VA72C10's Avatar
Re: My 69 lonbed
that's all you did in three hours???
j/k....looking good man
Old 12-28-2009, 11:27 PM   #125
brian69longbed
Re: My 69 lonbed
im going for a somewhat smooth look, maybe not, i'll move the emblems or have my buddy lazer some out for me... he he he
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
