Old 12-16-2009, 09:30 PM   #76
78-5.3
78-5.3's Avatar
Re: LS1 into a 73 cheyenne
Originally Posted by smokedat View Post
btw, what mount plates are you going with for the LSx?
the motor mount plates are from S&P, allows you to bolt LS-1 to original V-8 motor mounts[/QUOTE]
ls1 & vortec 4.8 -5.3-6.0
78-5.3 is offline   Reply With Quote
Old 12-18-2009, 04:08 PM   #77
nlped
nlped's Avatar
You are moving right along!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-18-2009, 04:42 PM   #78
Shon
I am using F-body Rad and double fans, only 1 fan ever runs, it keeps it as cool as I want it. I have the first one on at 210 and it gets up there and cools right down, had it at 180 but it stayed on alot and it is consistantly at 194 while driving around.
I am also using fuel injection rubber lines every where.
I used transdapt plates like the S&Ps and poly stock style motor mounts with the stock mounts on the frame side.
The new power will be fun!!!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-18-2009, 10:19 PM   #79
smokedat
smokedat's Avatar
Update, today i got my AC kit and PS pulley and new belt, I test fitted everything and it sure looks perty The compressor has the rear exit hoses.
It got dark so tomorrow I will take some pics but Here's a few of today's progress.
smokedat is offline   Reply With Quote
Old 12-19-2009, 09:16 AM   #80
JohnC
JohnC's Avatar
looking good man.
JohnC is offline   Reply With Quote
Old 12-19-2009, 09:22 AM   #81
menace121978
menace121978's Avatar
X2 looks sweet buddy. things are coming together real nice!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-19-2009, 10:05 AM   #82
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
OOOOOH, shiney! Lookin good.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-19-2009, 10:35 AM   #83
Thealien
Thealien's Avatar
Looks great! If you don't mind me asking what did that whole setup cost. Just trying to compare with a couple of options that are out there.
If you don't want to post it for some reason please PM me.
Old 12-19-2009, 01:28 PM   #84
smokedat
smokedat's Avatar
No problem Alien the polished wide style A/C kit was $736
the rear exit hoses option was additional $50 so total was $786
NOTE: the PS pulley was extra not part of the A/C kit that one was $120
Old 12-19-2009, 06:38 PM   #85
Thealien
Thealien's Avatar
Thanks. I may have to relocate my AC compressor on my swap and just looking at options. There are some options that are a few hundred dollars and use your original comp to whole accessory set ups that run $2500-3000. Thanks for the pics and info!
Old 12-19-2009, 08:25 PM   #86
menace121978
thanks for the info! alien, what other options are out there?? please pm or even post up in my build for others
"Dennis the Menace"
Old 12-20-2009, 12:07 PM   #87
Thealien
Thealien's Avatar
I will but be patient with me LOL. I have about 100 pages bookmarked and 10-20 different folders all related to my/an LS swap. All unorganised at the moment. AC is way down on my list right now as I am having crossmember issues (I think resolved) with putting a 5.3 into my stock height 4X4 72 Jimmy. I will have my factory AC hooked up to the LS engine somehow but that is as I said way down my list at the moment. If I haven't posted anything within a week please PM me a reminder. I have a couple of different options bookmarked.
Old 12-20-2009, 12:37 PM   #88
Thealien
Thealien's Avatar
All right here are 2. There is another inexpensive one that uses the pancake style compressor but I can't find that link right now. If and when I do I will add it.
THE EXPENSIVE ONES BUT???
A LESS EXOENSIVE SOLUTION BUT USES AN EXPENSIVE SANDEN COMPRESSOR
AND HERE IS THE THIRD OPTION
Old 12-20-2009, 01:42 PM   #89
smokedat
smokedat's Avatar
thanks for the links very helpful
Old 12-20-2009, 01:51 PM   #90
rongstad
Future: 86 on GenIV power!
x 2...........thanks
rongstad is offline   Reply With Quote
Old 12-20-2009, 07:30 PM   #91
Manbearpig
Manbearpig's Avatar
Nice!
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 12-20-2009, 08:51 PM   #92
menace121978
right on man! thank you big time!! i'm just relieved to see other options out there besides the fancy s&p brackets.
"Dennis the Menace"
Old 12-20-2009, 09:25 PM   #93
mcbassin
Still Learning
mcbassin's Avatar
Me too, I would like to design a set of brackets for mine to use the compressor that came with it.
Old 12-21-2009, 12:54 AM   #94
qu1cks1lver56
qu1cks1lver56's Avatar
These trucks look so good in white, I almost wish I woulda painted mine white.
Truck's lookin good man, should be killer when you get that LS1 in there.
qu1cks1lver56 is offline   Reply With Quote
Old 12-21-2009, 01:43 AM   #95
smokedat
smokedat's Avatar
thanks, after I finish the swap I will concentrate on the body and paint and ulpostery. Luckily it has very few rust spots. After a few sleep less nights I finally settled on Jetstream Blue Metallic PPG code 512Q, to compliment the paint color I plan on doing a 2 tone interior with blue and white.
sample pictures
Old 12-21-2009, 01:44 AM   #96
smokedat
smokedat's Avatar
more samples
Old 12-21-2009, 09:28 AM   #97
JohnC
JohnC's Avatar
That's an awesome color, and the two tone interior will look sweet!
Old 12-21-2009, 09:34 AM   #98
rongstad
nice color combo!!!
Old 12-23-2009, 02:45 PM   #99
smokedat
smokedat's Avatar
Update, Im currently waiting on parts. Need the A/C compressor billet cover, spark plugs, air intake, intake filters, and thermostat housing. I will be replacing it with a CSR straight up and a 160' thermostat. Also waiting on my fuel rail covers. Trying to compliment the engine compartment with some blue wherever i can.
Old 12-23-2009, 05:44 PM   #100
JohnC
JohnC's Avatar
I love the finned look on those. That is sweet!
73c10, c10, cheyenne, ls1, swap
