mini truck racer
71'-72' Master on 67'-68' booster ?
Will a 71'/72' disc brake master cylinder and proportioning valve mount and work properly in place of a 67' drum brake master and distribution block ? I have the disc master and the drum brake booster is on the truck . I am wanting to keep the factory booster .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Its a Truck Thing......
Re: 71'-72' Master on 67'-68' booster ?
Are you changing the front to Disk? If so, it should work just fine. Some one chime in if I am in left field...The only difference I know is that the brake lines run different on the frame rails between those years and may need massaging to get to the Dis Block.
If your not running disks dont change it. Smitty Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#3 | |
mini truck racer
The catalog shows two different part numbers for the boosters, maybe because of size, but there is a difference for some reason, I am not an engineer so I would say after finding out about the different sizes of boosters to call MP Brakes or a company that specializes in brakes to see if its safe. Thats the key,make sure its safe.
The way I read your post was that you were changing the whole system not splitting it(my fault). Why not just put a complete 72 setup on the 67? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 12-18-2009 at 09:22 PM. |
70 Chevrolet=Obsession
If I was you I would forget that 67 booster and install a new or rebuilt 72 booster. Don't take a chance on safety with some old raggedy 67 booster. JMHO.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
mini truck racer
Well the master cylinder will be new , but either booster will be used . It is my understanding that even if the booster fails i will still have manual brakes .
![]() Join Date: Jan 2002
Hey Hotrod 80
The master cylinder and p- valve will work fine on the booster. Two different companies made the boosters. Bendix and Moraine ?? I think. I have used them on both through the years.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
Damage Inc
Same setup i did..cool
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold 01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame 04 RCSB-joe gibbs clone,22in billets 68 stepper build http://67-72chevytrucks.com/vboard/s...d.php?t=332337 |
