Old 12-01-2009, 01:58 PM   #26
SCOTI
SCOTI's Avatar
Re: Installing a T-56
Originally Posted by 68jewel View Post
Me personally, I wouldn't bore a block .60 over. You've taken the cylinder walls to it's thinnest boundaries. Therefore, heating issues become a problem as far as the amount of heat produced within the cylinder walls by the pistons and this affects the tolerances of heat in your block. I know alot of people do bore .60 over but, it's just my opinion.
That's why quality machinists are worth their money. An .060 over-bore is do-able if the block has decent wall thickness & can handle it (some blocks can, some cant).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2009, 03:10 PM   #27
68jewel
On the path to financial ruin!
68jewel's Avatar
I agree with you totally...some blocks can, some can't. An owner also has to know what shape their block is in to know if it can handle it. And unless you know your machine shop guy pretty good, most will just do the bore just as you asked and send the block right on out the door. Now todays aftermarket blocks can handle a .60 bore with no problem because they are built with thicker cylinder walls.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 12-01-2009, 03:59 PM   #28
smoky02
Location: Sunny, Florida, some might call it South Alabama
Thank you guys for your advice. My block is a newer one piece rear main seal block. My machinist assures me that it will be no problem and I will address that again when i drop the block off at the machine shop. So no one has anymore experience or information about installing a T-56 into a C-10?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-01-2009, 04:48 PM   #29
68jewel
68jewel's Avatar
I'm no expert, but that's pretty much as far as the installation of the T56 goes. It's a relative easy swap in todays times. Now 5-10 years ago, there was no info and it was all a custom job. Now, there are so many guys doing these swaps it's a simple one. Check out this link for our trucks and the T56 swap......http://www.hurst-drivelines.com/inde...204&Itemid=155
Old 12-01-2009, 05:24 PM   #30
smoky02
Called them and they are supposed to call me back.
Old 12-01-2009, 06:31 PM   #31
68jewel
68jewel's Avatar
They are very knowledgeable and have a great tech support team. They can help you from beginning to end on your install.
Old 12-01-2009, 06:50 PM   #32
Wideopenracing15
Wideopenracing15's Avatar
Definitly subscribing to this. I plan on doing this in the future.
Wideopenracing15 is offline   Reply With Quote
Old 12-01-2009, 08:31 PM   #33
ozman3803
x2 I'm on the subscribing list
ozman3803 is offline   Reply With Quote
Old 12-02-2009, 01:35 AM   #34
BossHogg69
motor exploder
BossHogg69's Avatar
i don't have a T56, but I do have a TKO 500, and had to fab up a hydraulic clutch and the shifter is pretty far back on the TKO, but not as far back as the T56. Here's a link to a thread with some pics in it.
http://67-72chevytrucks.com/vboard/s...d.php?t=364326
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-02-2009, 10:04 AM   #35
smoky02
Isn't there a place that you can move the shifter to on the t-56? I think I read something about it before but now I can't seem to find anything. But on the transmission there is a plate about a foot up from the stock location of the shifter plate, I was wondering if that was an optional shifter location.
Old 12-02-2009, 10:43 AM   #36
68jewel
68jewel's Avatar
Smoky, the Tremec TKO 500's & 600's had 3 different shifter locations to mount the shifter base/plate. The older T56's don't. Now I think you can turn the shifter plate around on the older T56 to get a few inches difference which won't really help you much. You may need to verify what I said about inverting the shifter as I'm not to sure, but I think you can. Now the "new" T56 Magnums have another shifter mounting location. But I don't think you have or will be getting the new T56 will you? If so, then shifter position won't be a problem
Old 12-02-2009, 12:20 PM   #37
smoky02
Deleted
Old 12-02-2009, 12:21 PM   #38
smoky02
I wish I could afford the T56 Magnum, no sir the transmission that I am getting came out of a 96 Camaro Z28. Do you know how much farther back the shifter is on the 6 speed compared to your TKO?
Old 12-02-2009, 05:41 PM   #39
smoky02
Would I have to remove my bench seat? Or is there a shifter that would fit around it? Or is there another style seat I can use that is still considered a bench with a little more clearence?
Old 12-02-2009, 06:24 PM   #40
BossHogg69
motor exploder
BossHogg69's Avatar
i flipped my shifter around on the Tremec and ordered a Hurst stick for a bench seat car. I'm pretty sure that the shifter is even farther back on a T56, but don't quote me on that. Even with mine the way it is, it's pretty close to the seat in 2, 4, and R. I'm sure any vendor that sells T56's or TKO's will be able to tell you how far back or what the difference is.
not sure about another bench style seat that would clear a T56. Jeg's sells a bunch of different Hurst sticks, that's where I got mine. I looked up the dimensions on Hurst's website and did some measuring from my floorpan to the seat and just found something that was close enough.
Adam
Old 12-02-2009, 06:36 PM   #41
smoky02
That makes good sense...thanks...
Old 12-02-2009, 06:39 PM   #42
Custom 68
Custom 68's Avatar
Finally found this. There is a way to move it forward. I am not sure how tough it is...
http://67-72chevytrucks.com/vboard/s...d.php?t=300892
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 12-02-2009, 07:02 PM   #43
68jewel
68jewel's Avatar
I'm no transmission guru, but that looks tough enough. I think a job like that isn't for the average DIY'er. I would have a transmission guy do that and yet still hopefully they can do it right. LOL!
Old 12-02-2009, 07:08 PM   #44
68jewel
68jewel's Avatar
This is a good thread to reference. As I thought, but was unsure, you can invert the shifter on the T56. You may want to print this thread out for directions.
Old 12-03-2009, 11:21 AM   #45
smoky02
This is great information, thank you very much.
Old 12-03-2009, 01:26 PM   #46
Custom 68
Custom 68's Avatar
I looked at mine again last night and I think for it to work right I will need to move this forward but I am not sure it is something I want to tackle and chance messing up my 1000 dollar transmission. Good luck with yours.
Dave
Dave
Old 12-03-2009, 03:57 PM   #47
smoky02
I'm calling a few of the tranny shops around here and see if they can do it.
Old 12-20-2009, 07:51 PM   #48
ozman3803
did anybody get a quote on the t56 magnum yet? It's sunday and long ways down the road for this install but just curious.
Old 12-21-2009, 02:19 PM   #49
68jewel
68jewel's Avatar
I got mine from Jegs for $2795. Forgot how much freight was, but I think it was around $120 shipping. No tax because of out of state.
Old 01-27-2010, 11:02 PM   #50
dan468
dan468's Avatar
What questions did you ask them? Did they get back with you? I'm hoping to be able to just buy the parts I need from them.
Thanks for any updates on your trans project...
Dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
