#1 | |
Conversion Truck Addicted
Cummins 6BT Swap
i have been think about it and have found a import place here where i almost can get them thown at me the are from marine and semies
my truck has a stock 6.2 Non turbo with only 79xxx miles on it run sweet would i get anything by replacing it with a cummins 6bt or am i better of with the 6.2 and add a turbo to it what im looking for is not HP but lb-tq and Millage i would really like some imput on this to or not to do its a Chevy C-30 Crew Cab 1 Ton Dually 1984
Thomas Quote:
Re: Cummins 6BT Swap
ya the 6bt is rated at 302 hp and in the range of 500-600lb tq so it would be doubling the 6.2s power while taking of 2 cylinders
if you do find one with a tranny behind it its easier that way
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I love GM trucks. Period. BUT, if I had the oppertunity I would swap the 6.2 out for a 6BT. You would be silly not to. The 6BT is a million times better than the 6.2 If anyone telly you otherwise it is because they have not owned both and dont really know the difference.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
1000 lbs of motor and very tall engine i was going this route but decided against it !
yeah the adapters behind the wonder bread vans are not very good there on an angle!!!
#6 | |
Here is one i have been looking at
this is alost a copy of what i have in mind for my own what kind of tranny would you guys recound for me if i do a swap like this would i be able to use the clutch, bellhousing and tranny from my 6.2? tranny is a SM465
Thomas Quote:
no you wouldnt be able to use your bellhousing but the th tranny you could just different clutch and bellhousing find one with a nv4500 behind it
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s Last edited by munger; 12-22-2009 at 06:02 PM. |
How about a 4-71 Detroit, supercharged, turbocharged, and intercooled backed by a Roadranger 13 speed trans?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
ok pre runner that is a tease. i need to see more pics.
I couldn't agree more!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
BAD BOW-Silverado XST
Diesels rock
http://forum.neow.net/index.php?show...862&hl=cummins If it can fit in a S10 why not your truck! ![]() ![]() Search Youtube. You'll find some great 6BT videos. |
You can use a NV4500 5spd or a NV5600 6spd from a Cummins powered dodge, the autos too exept the 07.5 and up aisin & dodge trans. I say go with a Cummins, milage is just as good with better power & no glow plugs to deal with, better injection pump, & they go 700,000 miles easy (i dont know what that whould be in KM)
#13 | ||
woundering if a Detroit 6V53 would fit
Thomas Quote:
#14 | |
He is a member here as well but not very active. His user name is Aramp1. Here is his build thread on ColoradoK5. http://coloradok5.com/forums/showthread.php?t=212269 But I will post a few more pics. ![]() ![]() ![]() I have always liked his truck... but it just keeps getting better and better.
#15 |
Your best bet is to get a Complete cummmins dodge manual drive traind and convert your truck to hydraulic clutch (87 and up) had hydraulic. You will loce the Overdrive from the NV4500.
This route will also be the least expensive as the adapters are quite expensive. There are places that sell the mounts ( http://www.autoworldmt.com/ ) The stock power will be far beyond the 6.2 will ever be capable of modified. The 94-98 12V have hydraulic clutch, I am not sure about the 1989-1993 12V. |
#16 |
Thanks, Thought I had seen that before.
#17 |
4btswaps.com has all the info on this looking to do the same thing
#18 |
#19 |
did you ever take the plunge?
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
#20 |
Why would someone want to waste a truck on a 2-stroke Detroit?
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
#21 | |
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
