Old 01-14-2010, 09:43 PM   #201
litebulblsc
litebulblsc's Avatar
Re: Project: Agent Orange
I was hoping you were talking about a dirt bike, not a jeep or a ford.
litebulblsc is offline   Reply With Quote
Old 01-14-2010, 10:25 PM   #202
msgross
msgross's Avatar
cool, you got a jeep and I got a Ford...
that rink is very cool...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-17-2010, 07:15 PM   #203
vtblazer
vtblazer's Avatar
Okay, got the heep done enough to kick it out of the K5 space.
Time to get somethin' done!
Took some passenger side header pics while I was out there today, the headers fit the frame well but look to be uber tight exiting towards the bell housing.
vtblazer is offline   Reply With Quote
Old 01-21-2010, 10:54 PM   #204
Wildstreak
"something witty here"
Wildstreak's Avatar
why cant I find those headers for sale anywhere? I went to see if the headers I had would fit and passenger hits the tranny, so Ill be needing a new set, and I remembered these looking good. do you know anywhere that sells them?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-22-2010, 06:59 AM   #205
vtblazer
vtblazer's Avatar
http://www.sandersonheaders.com/prod...roducts_id=199
Add $150.00 for the ceramic coating.
Old 01-22-2010, 09:29 AM   #206
hgs_notes
GEARHEAD
hgs_notes's Avatar
Can you get a ratchet on all of the spark plugs? Looks like #6 might be tight.
hgs_notes is offline   Reply With Quote
Old 01-22-2010, 12:41 PM   #207
Wildstreak
Wildstreak's Avatar
thanks man you are my savior!
57 chevy 4x4
68 burb 2wd:
Old 01-22-2010, 04:14 PM   #208
vtblazer
vtblazer's Avatar
They're always tight...
The bigger question in my mind is, "will it burn the plug wires"
Had a set on the blue one that were literally impossible to stop from burning through and arcing out.
Old 01-22-2010, 04:30 PM   #209
hgs_notes
GEARHEAD
hgs_notes's Avatar
Just curious because I was looking at those for my C-10. They have shorty plugs available but want to avoid that if I can.
Old 01-22-2010, 04:41 PM   #210
Wildstreak
Wildstreak's Avatar
would those spark plug wire kevlar boots help prevent burning?
57 chevy 4x4
68 burb 2wd:
Old 01-22-2010, 04:48 PM   #211
vtblazer
vtblazer's Avatar
I have pics somewhere...
I spent big money with a company called 'Live Wire' for wires that are "gauranted" not to burn...yep they burt.
I used those boots on my blue blazer with the 2.5" rams and after time, even the center two would burn through.
I just saw an add where Accel is making some with ceramic ends, I think I'll be looking into a set of those.
Old 01-22-2010, 05:28 PM   #212
Wildstreak
Wildstreak's Avatar
just checked out the accel set you were talking about, theyre around 150 a set. I would need the 90 degree ends for those headers right?
57 chevy 4x4
68 burb 2wd:
Old 01-22-2010, 05:59 PM   #213
hgs_notes
GEARHEAD
hgs_notes's Avatar
If the ceramic boots are hard, they might not have the flexibility needed to fit over the end of the plug when you put them in. I'll let someone else spend the $150 to find out.
Old 01-22-2010, 07:31 PM   #214
vtblazer
vtblazer's Avatar
Got a link?
Old 01-22-2010, 07:39 PM   #215
Wildstreak
Wildstreak's Avatar
from summit, pretty much the only place other than jegs or mopac I order fromhttp://www.summitracing.com/parts/ACC-9001C/
57 chevy 4x4
68 burb 2wd:
Old 01-22-2010, 09:06 PM   #216
vtblazer
vtblazer's Avatar
Maybe we should share a pic.
Thanks for the link.
Old 01-25-2010, 07:43 PM   #217
Wildstreak
Wildstreak's Avatar
One more question on the headers. How does the shift linkage from the column to tranny clearance look? are the headers interfering?
57 chevy 4x4
68 burb 2wd:
Old 01-25-2010, 09:21 PM   #218
vtblazer
vtblazer's Avatar
Didn't really study that area, plans are to use a cable shift.
Installing a 4spd tilt, so there's no linkage there.
Old 01-25-2010, 09:51 PM   #219
Wildstreak
Wildstreak's Avatar
well Im ordering a flaming river column tilt too and have a 700r4 as well so i was just worried about the linkage. Ive never hard of the cable shift before I was just going to order the lokar linkage. ill have to take a look into these cable shift.
57 chevy 4x4
68 burb 2wd:
Old 01-26-2010, 01:29 AM   #220
cleszkie
cleszkie's Avatar
The headers run pretty close to the firewall. What is the temperature rating of the lizard skin? Will it withstand the heat in the engine compartment without cracking, shrinking, or burning? I've never seen it used in that area.
cleszkie is offline   Reply With Quote
Old 01-26-2010, 07:49 AM   #221
vtblazer
vtblazer's Avatar
Mine is a factory 4spd column, so I can't give you any info on the Flaming River part other than I hear they're pretty dayum nice.
As for the cable shift, I got it through Summit and it's made by Lokar.
Note that this is not what I'm using this time, the pic is from the blue blazer which had a factory column.
The Lizard Skin is a two part application with the 1st layer being a sound control and the 2nd being heat protection.
Taken right off of the container stating what it will do:
*Reduce engine and solar heat transfer by 25-30 degrees or more
*Reduce noise by as much as 10-12 decibels
*Protect sufaces from moisture and corrosion
*Withstand temperatures to 500 degrees F (260 C)
*Class 'A' fire rated, does not support combustion
The stuff is made for 'exactly' this application.
Old 01-26-2010, 02:19 PM   #222
drunkbus
New Member
drunkbus's Avatar
Here's a set I have with 90 degree ceramic ends. I believe these are made by Taylor. Might be cheaper than the Accels.
drunkbus is offline   Reply With Quote
Old 01-26-2010, 02:47 PM   #223
Critter
Future TOTM Winner
Critter's Avatar
I love how VT can refer to them as "the blue blazer" or "the orange blazer" or "the green blazer" and everyone in North America and most of the Northern Hemisphere knows EXACTLY what he's talking about. That's pretty much the definition of building BAD@SS stuff!
Your engines looking good, always loved those valve covers.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 02-18-2010, 11:20 AM   #224
Big J
Its lookin' like a Blazer!
Big J's Avatar
Can't wait to see some progress...
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-18-2010, 12:33 PM   #225
tjsblazer
tjsblazer's Avatar
Originally Posted by mdunn View Post
Put my new 383 in a few months ago. Stock valve covers were close to the firewall, tall valve covers for the roller rockers have the same clearance yours do. Was still able to get them on and off for the valve adjustments. Didn't like the clearance either, but couldn't bring my self to hitting the stock firewall either.
Do you post some pictures of your valve cover to firewall clearance. I'm going that route and would like to see what you ended up with.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
