01-22-2010, 08:27 PM | #76 | |
Still Learning
Re: 79 GMC Sierra LWB 6.0L swap
01-22-2010, 09:51 PM | #77 |
Ill see what i can find. 20 bucks is the lowest price that ive found. I go to alot of wreaking yards, scored a 99 F-body 5.7/6spd harness for 40 bucks last week.
01-22-2010, 11:15 PM | #78 |
6.0L power.........
Well it is slow but I think I have got everything together! Still need to send off my ECM and harness to Wait4me Performance, will try to do that next week. Just need a couple of warn days to pull the old engine out. But I am getting there.
What ever the mind of man can conceive......... he can achieve! My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914 1979 GMC Sierra 6.0 L 4L60E 1995 Mustang GT 347 |
01-22-2010, 11:32 PM | #79 |
Formerly- 1972SuperCheyenne
Awesome, dont forget the pics.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-24-2010, 01:57 PM | #80 |
6.0L power.........
Well I am just waiting on a good day to start. I took this pic because I love the way these engines look with the covers. Can't wait to see it sitting in the truck!!
01-24-2010, 03:42 PM | #81 |
Dern that engine looks clean. Looks like a good starting point.
01-24-2010, 09:16 PM | #82 |
looking good! be looking better in the frame rail!
but i'm not one in a position to say that!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
01-25-2010, 08:28 PM | #83 |
6.0L power.........
I asked this question in another thread but I will ask it here for those who are following this thread. Do I replace the oil cooler lines with the T-fitting for the oil pressure sending unit or do I tap the oil lines block?
01-25-2010, 08:53 PM | #84 |
Some people remove the oil pressure sending unit from the back of the engine and use a 16mm X 1.5 to 1/8NPT adapter and use that for their oil pressure line/sender. The PCM doesn't need the oil pressure sender (from what everyone tells me). I am having a T made for that location so I can have both (I believe a scanner, Tuner and things like an aeroforce gauge can read the stock sender)
This is the adapter fitting Aeroforce gauge Sorry I didn't answer your question, just trying to give you options.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 01-26-2010 at 11:24 AM. |
01-25-2010, 08:57 PM | #85 | |
6.0L power.........
Thanks I have the Dakota Digital gauges so I need to use the sending unit for that. Will the ECM give an error code if the original sending unit is not there?
01-25-2010, 09:09 PM | #86 |
I have been told no. Most of the harness people I talked to eliminate that connector.
Please don't take my word for it though and ask some others. Do you know what thread your gauge requires? I'm pretty sure there will be a 16mmX1.5 adater to whatever it is.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-25-2010, 09:12 PM | #87 |
I just looked on their site and their senders are 1/8 NPT so that adapter will work if you don't need the factory sender.
Who is doing your harness/tune. Ask them
01-25-2010, 09:15 PM | #88 |
6.0L power.........
Yes it is 1/8 npt. Wait4Me Performance is doing my harness and tune
01-25-2010, 09:34 PM | #89 |
you dont need the Oil pressure sending unit, the PCM does not throw a code.
I used said adaptor and mechanical gauge.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
01-27-2010, 09:30 PM | #90 |
6.0L power.........
Just a pic of the 4L60E.......
01-27-2010, 09:38 PM | #91 |
Mine doesn't look shiny like yours!!
01-27-2010, 09:48 PM | #92 |
sweet!!
01-28-2010, 09:30 AM | #93 |
It's awesome how many LS swaps we have going on right now. We're all going to have to take a road trip and meet up in the middle some day so we can all bask in the glory of our newfound LS POWAH!
01-28-2010, 01:12 PM | #94 |
6.0L power.........
It is amazing what a can of Gunk and Aluminum spray paint can do!
01-28-2010, 02:17 PM | #95 |
Yeah its on my I wish I could say "short" list
01-28-2010, 03:12 PM | #96 |
how did you paint the bottom?
01-28-2010, 06:59 PM | #97 |
6.0L power.........
Well......... I haven't yet. I will put it on my engine stand and roll it over to get the bottom.
02-03-2010, 06:17 PM | #98 |
6.0L power.........
Well the weather is warming up with no rain and the guy that is helping me pull the old motor....... OK I'm helping him, his mother is in the hospital and not doing very well so I sit and wait. Here are a few pic from my day at the local pull-a-part, got all this for $25.00 and the old guy thought he was ripping me off! I have been pricing this stuff on ebay and I could not get the air cleaner for that and this one also has the MAF sensor. Is any one else using the stock fuse box from the donor truck? Do I need this or is there something else that I should use?
02-03-2010, 07:34 PM | #99 | |
02-03-2010, 09:52 PM | #100 | |
Still Learning
