Old 01-30-2010, 08:29 PM   #1
winchster
winchster's Avatar
Question Door Handle Modification
I've searched, if I missed it point me in the right direction and I'll just go from there. I found one thread but the answers weren't really definitive.
I have a '49 and I hate the turn down handles. Can I install the pushbutton handles from '52 up on my '49 doors?
I will be, most likely, putting in bear claw latches also.
Any and all feedback is wholeheartedly welcomed. Thanks.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 01-30-2010, 10:22 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Door Handle Modification
http://www.jalopyjournal.com/forum/s...ad.php?t=77555
this should be very helpful
Old 01-30-2010, 10:30 PM   #3
winchster
winchster's Avatar
Originally Posted by dwcsr View Post
You are correct, that is very helpful. However it doesn't answer the question:
Can I use pushbutton door handles from '52 up on my '49 door?
Old 01-31-2010, 11:06 PM   #4
FiftyTwo
FiftyTwo's Avatar
Switching the outside handles isn't going to be very easy.
The doors are actually different. '47-'51 use a single hole to mount the outside door handle, while '52 on up use two holes.
The inside door latch is also different. '47-'51 the rod on the door handle trips the door latch when you turn it down, '52 on up the latch is tripped by pushing the button on the door handle. Two totally different ways of doing the same thing.
Lastly, the catch on the cab post is also different between '47-'51 and '52 on up.
With that said, anything can be accomplished with a little creative cutting and welding. You could just shave the door handles, install bear claw latches and some solenoids and be done.
Good Luck.
FiftyTwo is offline   Reply With Quote
Old 01-31-2010, 11:15 PM   #5
winchster
winchster's Avatar
Maybe I should rephrase.
If I wanted to can I put ALL the hardware from '52 up door/cab on a '49 door/cab?
Old 01-31-2010, 11:33 PM   #6
FiftyTwo
FiftyTwo's Avatar
I'm not positive, but I think the doors are different enough that the inside latch isn't a bolt in swap. Your current doors also have the key lock which later doors don't have. My suggestion would be to get some used '51 on up latches and a handle and see what fits and what doesn't and go from there.
I know that you can put complete doors from later years onto earlier cabs, but you still need to change out the latch on the cab post.
Hope this helps.
Old 01-31-2010, 11:51 PM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
No not easily the doors are different, The skins do not have the proper hole and the inside reinforcement and latches are different. Not saying that its not possible, just not probable. Find some 52 up doors, it just works and is scads easier. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-31-2010, 11:52 PM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
To answer the question, No. the mechanism is not the same or in the same place or mounted the same.
Old 02-01-2010, 12:01 AM   #9
winchster
winchster's Avatar
Ok, so the answer is yes I can if I really want to.
Sorry about the whole thing I guess I should have just asked if the doors would fit, cause if the doors fit then the latch change will work.
I want pushbuttons with bear claw latches. So the latching mech's don't really matter to me. Now I just gotta figure out how to make the pushbuttons work. Sounds like I should probably just find doors and swap, but I don't want vent windows and I have brand new glass.
Old 02-01-2010, 12:18 AM   #10
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
The bear claw latches is kind of an important detail.
You're going to be figuring out how to make the mechanism inside the door work regardless of what doors you use, and you're going to be changing the striker plate to match the bear claws.
I think with those assumptions you might as well just put '52 up pushbutton handles on your early doors. Changing to later doors only saves you drilling the holes to mount the handles and filling the lock hole on the passenger side.
Steve@OldSub.com is offline   Reply With Quote
Old 02-01-2010, 12:29 AM   #11
winchster
winchster's Avatar
I said so in the original post. My main concern, and I obviously screwed this up, was are the doors physically the same except for the hardware.
Thanks for all the input guys, anybody got any details on how to make the pushbuttons work with bear claws?
Old 02-01-2010, 11:03 AM   #12
BlueJeep
BlueJeep's Avatar
I'm working on doing bear claws in mine right now, but I'm trying to keep the turn down handles with them. If I can't make that work, I'll switch to the pushbutton style and do it with them. If you're capable of doing the fab for the bear claws, switching handles is no big deal. Search for bearclaws on this site and you'll come up with a couple different ways of doing it with pushbuttons...one was Houston54's. Handles are also the same through the TF series, so that opens up your search criteria a bit for used handles.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-01-2010, 01:57 PM   #13
Steve@OldSub.com
I think they are actually the same through '66 aren't they?
Old 02-01-2010, 05:51 PM   #14
1952ssr
1952ssr's Avatar
I understand your dalima, I had the same issue. I had originally bought a '52, and then found out the floor was gone. So I found a '51 cab w/doors that was in better shape except the door bottoms. I didn't like the turn down handles either so I switch doors but, they didn't fit the cab very well. So after much looking at both doors and what kinda time and effort changing the handles would take I'm leaving the turn down handles even if the bottoms aren't as good as the other doors. I think it could have been done but, it would have taken alot of time.
1952ssr is offline   Reply With Quote
Old 02-01-2010, 06:51 PM   #15
dwcsr
Hollister Road Co.
dwcsr's Avatar
I know 52 to 59 are the same, to 66 looks the same but I have a different part number for them
Old 03-20-2018, 06:37 PM   #16
Scott2
I know this is a real old post but since I know the answer now and this thread popped up in a search I thought I would share.
The answer is yes you can swap pushbutton door handles on to turn down handle doors. You just need to weld up the old handle mount holes, swap the reinforcement plate inside the door for the pushbutton type ( i found donor doors and cut these parts out), and drill new holes. I used Altman latches for '52-'54 and the latch plates for my '51. Works great. Pics in my build thread if you need more details.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 03-20-2018, 09:36 PM   #17
MARTINSR
MARTINSR's Avatar
I am so torn on this for my truck, it's a 48 and I have had it for 44 years. I LOVE the twist handles, but the theme of the truck on this build is a Motorama truck from 1952 (GM shows where the Corvette was introduced) and I want the push button handles because that is where style was going and the twist handles were HISTORY at that time. But damn I want the twist, for my memories. I have NOS latches and handles, perfect NOS parts. But I have gotten NOS push button latches and planned to do it, but I am not sure if I can go through with it damn it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 03-21-2018, 01:28 AM   #18
dsraven
Brian,
how about you just set up 2 complete door sets, one with twisties and one with push buttons. no problem right? going to a show? swap in the push buttons. slipping through traffic near home-twisties. OR, put one style on the driver's side and the other style on the passenger's side. just show one side at a time. easy peasy. (hey, you're the one who had to chop the roof.....)
just kidding you, man. go with what YOU like.
Old 03-21-2018, 10:33 AM   #19
MARTINSR
MARTINSR's Avatar
Originally Posted by dsraven View Post
Brian,
I am already bending the theme big time by leaving the split windshield. I plan on putting a car center strip which is much narrower to at least lean in the direction of the one piece windshield. It's really hard because I want to really follow the theme, that is what makes any build fun, and a better finished product.
Brian
1948 Chevy pickup
Old 03-21-2018, 11:55 AM   #20
dsraven
how about the seamless look where the 2 pieces of glass are bonded in the middle, or whatever they do nowadays when 2 pieces of glass meet and seal with no frame. the glass would also be glued into the opening I assume so that may negate the theme right there I guess.
never mind, brain babble.....
Old 03-21-2018, 12:13 PM   #21
MARTINSR
MARTINSR's Avatar
Nope, that wouldn't work at all because it's been dated into the 1980's when people started doing it.
No, the only thing I can do outside of using the passenger car center moulding is to cut the whole windshield out and put a 54-55 in.
Brian
1948 Chevy pickup
Old 03-21-2018, 04:25 PM   #22
_Ogre
_Ogre's Avatar
very old thread
RIP steve
shop air compressor timer
Old 03-21-2018, 04:47 PM   #23
mongocanfly
mongocanfly's Avatar
Martin, you made mention of using a 54-55 1pc windshield...I'm sure you know there's a difference in the cab sheetmetal around the windshield...pre54 has a little crown...post54 is smooth....nothing that couldn't be modded and overcome though...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-21-2018, 06:18 PM   #24
MARTINSR
MARTINSR's Avatar
Yeah, thanks, I know that. It would be a piece of cake compared to the other mods! Hell, I even thought of a chopped wrap around like a 55 2nd series or something like that, just to get that Motorama look but I have decided against going that far.
But honestly I don't think I can do it, then it wouldn't be "my truck" at all, you know what I mean?
Brian
1948 Chevy pickup
Old 03-21-2018, 06:26 PM   #25
MARTINSR
MARTINSR's Avatar
The whole "Theme" thing I believe makes for more fun if nothing else. My "Theme" is that Harley Earl (the manager of the design dept at GM at the time, he was responsible for many cars including the first Corvette.) brought his personal truck into the studio and let them have a little fun with it.
He did something very similar with his son Jerry Earl's 56 Corvette that he raced.
Stock 56 Corvette;
Jerry Earl's the "SR-2"
So I figure I can steal that idea and my truck is his and he let the design studio make the first "Cameo" with a Corvette 235, that's my story and I am sticking to it!
Brian
1948 Chevy pickup
