Old 04-30-2003, 08:32 PM   #1
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
engine temp
ok, gotta really dumb question. I was having issues with the temp sender, so I replaced it, now the gauge runs constantly to the right. It shows as if it was over heating, but its not. It use to run just to the left of straight up and down. My question is
1. where does your temp gauge run?
and
2. is there more than one temp sender for a factory gauge? as in do they have different resistances or outputs.
thanks
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 04-30-2003, 09:03 PM   #2
70c10
67-72 Addict!
70c10's Avatar
My truck has an aftermarket gauge. I installed a 180° thermostat bit it runs around 195° on the gauge.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-30-2003, 09:27 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
as far as i can recall ( but im rusty) thres only one sender and it is possible to get a defective one double check your connection to the sender and if it stilll screws up bring it back as defective
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-30-2003, 09:40 PM   #4
Gordo
Smile
It's possible they sold you a sending unit for an idiot light and not a gauge.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-30-2003, 09:42 PM   #5
mikep
Used to have a truck
mikep's Avatar
Theres probably a few dozen different senders with different resistance values that will fit your sender hole. You probably got the one thats made for an idiot light. You need the one made for the temp gauge.
No truck :-(
mikep is offline   Reply With Quote
Old 04-30-2003, 10:36 PM   #6
Southpa
Southpa's Avatar
Wow, I can't believe how many people have been thru the same dang thing, including myself. The number of variable resistance sensors in my toolbox can give you an idea. I finally gave up and went with an aftermarket mechanical, all-in-one gauge/sensor system. I figure my truck has grounding issues and therefore, won't allow electrical temp. system to run. OR my gauge is kapoot.
First, check all your ground connections, which include straps from engine block to frame and from frame to firewall. Don't use teflon tape when installing the sensor. If that doesn't work I can't help ya further. Go with the aftermarket mech. gauge/sensor. Its nice to see actual numbers anyway.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-30-2003, 11:17 PM   #7
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Where is the sensor located, at the water neck, or in the cylinder head?
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 04-30-2003, 11:26 PM   #8
marcuspboldt
Registered Abuser
marcuspboldt's Avatar
Mine is located on the drivers side head a little towards the front
marcuspboldt is offline   Reply With Quote
Old 04-30-2003, 11:28 PM   #9
oldyeller
oldyeller's Avatar
sensor is in the drivers side head, and the gauge is oem. my uderstanding of theidiot light sensor is it's either open or shorted, hence the light on or off. so I didn't think the gauge would even read with a idiot sensor, unless it got too hot.
I guess I'll take this one back as I have checked everything else...
Anna, Texas
Old 04-30-2003, 11:32 PM   #10
cali_surfer
cali_surfer's Avatar
This just happened to me too!! I am going through and trying to get all my stock gauges hooked back up. Went and bought a temp sender from NAPA of all places, hooked up my sender wire, turned the key on and it pegged all the way to the right. So that means its for an idiot light dash? It ticked me off to say the least.
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 05-01-2003, 03:08 AM   #11
oldyeller
oldyeller's Avatar
Yeah cali yours sounds like its for a idiot dash,and its working backwards possibly, or you got a short in the wiring somewhere.
Anna, Texas
Old 05-01-2003, 08:18 AM   #12
Blue Beard
Blue Beard's Avatar
I had a truck with two sending units, but had two separate gauges in it.
PO installed them...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 05-01-2003, 12:47 PM   #13
cali_surfer
I immediately thought about the grounding out of the wire, but that shouldn't be the case since I have a new painless wiring harness. Sounds like I need to get a different sender then and hopefully my luck will turn around.
Old 05-01-2003, 09:41 PM   #14
Blue Beard
Blue Beard's Avatar
Even with new wiring, don't count out a bad ground. Even paint under the connectors can be bad...........
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
