Old 12-29-2006, 06:01 PM   #101
chopper103in
chopper103in's Avatar
Re: Autometer Cluster Projects
cool---- now i need my wife to see what kind of employee discount she can get on gauges for me
chopper103in is offline   Reply With Quote
Old 12-29-2006, 06:46 PM   #102
bad72c10
bad72c10's Avatar
So, do the Autometers come with sending units? if they don't can you use what you already have? And they are mechanical, right?
bad72c10 is offline   Reply With Quote
Old 12-30-2006, 01:15 AM   #103
Mudder
Mudder's Avatar
They do come with sending units and they can be had mech or elect.
Mudder is offline   Reply With Quote
Old 02-15-2007, 04:02 PM   #104
Putter
More Cowbell....
Putter's Avatar
Mine were all electric, but DID come with the needed sending units....excluding the speed-o-meter. The sender is seperate, because you may have a GM, Ford, or Dodge tranny.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 02-15-2007, 04:46 PM   #105
franky69c10
chevy runs deep
franky69c10's Avatar
so when u order them it come with all the sending units u need to make it work...
franky69c10 is offline   Reply With Quote
Old 02-16-2007, 03:31 AM   #106
cojnit
Nothing clever
cojnit's Avatar
So Putter, how much to have a set of dem made, including the gauge prices?
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 02-19-2007, 09:09 PM   #107
alemck
What are the size's of the speedometer and tach area, do you know if autometer makes the cobalt in that size? I put the 2 3/8 in the four gauge that cross the bottom, looks great, so great that I have to do something with the speed/tach/fuel gauges
Bryan
1971 Chev Shortbed Fleetside Blown 355 605 hp 528 ft lbs torque
1970 Chevelle SS454 LS5 (numbers matching so I have to leave it alone)
2006 Chev Z06
I used to be schizophrenic but we're all better now []
alemck is offline   Reply With Quote
Old 02-27-2007, 10:34 AM   #108
76bonanza
76bonanza's Avatar
I am setting my guages now is there any trick to get the smaller ones as close to the bezel as possible for better angle viewing? I have removed the little ribs around the back of the holes. Is there anything else I can do?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-27-2007, 12:49 PM   #109
Putter
More Cowbell....
Putter's Avatar
Franky - YES. Excluding the speedo, they will come with the needed senders.
Cojnit - 'Dey ain't cheep. I have just over $600 in mine (all electric), all new parts.
Alemck - Speed & tach are 5", temp (center) is 3-3/8". And if memory serves me, you can get ALL the gauges in the sizes you need with the COBALT series.
76bonanza - I have seen a few guys actually remove the trim ring from the gauges and set it behind the factory lens. Other than that...I don't have any suggestions. (sorry)
Old 02-27-2007, 01:01 PM   #110
Chevy_Man
Tightwad
Chevy_Man's Avatar
Hey Putter, i think that is some great work there...wish i was as good as you...maybe in due time....not....Rob should really like that set you got together for him can't wait to see pics of it installed
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
Old 02-27-2007, 03:35 PM   #111
1fun71
1fun71's Avatar
Here's the fuel guage I want! http://
1fun71 is offline   Reply With Quote
Old 02-27-2007, 07:35 PM   #112
76bonanza
76bonanza's Avatar
Hey putter is it worth the effort or can you see the smaller gauges good when the dash is mointed in the truck?
1968 c10
lowered 3" 4"
Old 03-08-2007, 05:14 PM   #113
76bonanza
76bonanza's Avatar
I am draging this thread out again with a feew more questions
First, does the bezel and cluster tilt when mounted in dash looks like it mounts at a angle.
second, I got one of those pin conectors from the shack. Seems ok but when I pull the plugs apart it pulls the wires forward some and I have to reset them am I doing somthing wrong?
1968 c10
lowered 3" 4"
Old 03-08-2007, 05:55 PM   #114
As2rd
As2rd's Avatar
Does anyone know of a tach that can fit in the center hole of the without cutting plastic glass?? I have the Three Hole Cluster and want to have a tach. If not, do you know of a tach that can fit on my steering column (which id rather do) ---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
As2rd is offline   Reply With Quote
Old 03-08-2007, 07:32 PM   #115
SCOTI
SCOTI's Avatar
....And if memory serves me, you can get ALL the gauges in the sizes you need with the COBALT series.
I checked the Autometer site & they showed the Cobalt speedo/tach available in 3 3/8 but I didn't see any 5" P/N's. They did list a 3 3/4" & 5" 'pedestal mount' tach.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2007, 11:13 PM   #116
rin68
rin68's Avatar
Not Autometer, Stewart Warner. I like that the SW's are different than what everyone else has.
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 02-19-2010, 11:56 PM   #117
austinstocker
austinstocker's Avatar
Has anyone had any luck finding any 3-3/8" Autometer gauges for the center hole lately? I want to run a 5" Speedo & 5" Tach, and would prefer a fuel level gauge in the 3-3/8" Hole. Just wondering if anyone has any advice on finding one, cause I'm sure not having much luck.
____________________________
1967 C10 SWB Big Block 4 Speed
austinstocker is offline   Reply With Quote
Old 02-20-2010, 12:13 AM   #118
djracer
djracer's Avatar
You need to search any autometer you can find in the 3 3/8 size then buy the rest to match. Autometer doesn't make them anymore.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-20-2010, 01:56 PM   #119
austinstocker
Yeah... It's not easy to find anything in that size. Unless it's a tach or speedo, but that would leave an empty 5" hole. I'll keep looking. Or maybe i will leave the center hole blank and use it for some turn signal, high beam and brake light indicator setup
Old 02-20-2010, 02:57 PM   #120
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Heres a picture of the cluster Putter did for mine. He IS DaMan
Tom Vogel is offline   Reply With Quote
Old 02-20-2010, 04:03 PM   #121
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Man it's too bad they don't make the3 3/8" fuel gauges!
Those look great!!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 02-20-2010, 05:38 PM   #122
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Tom Vogel View Post
Heres a picture of the cluster Putter did for mine. Hi IS DaMan
Sweet! Those fuel gauges are worth they're weight in Gold!
Hart_Rod is offline   Reply With Quote
Old 02-20-2010, 07:42 PM   #123
djracer
djracer's Avatar
Wasn't there a list of all the 3 3/8 part numbers some where on the board.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-20-2010, 08:02 PM   #124
kgt
Is it rude to ask what something like that costs?....If so i understand. It looks fantastic!!...
kgt is offline   Reply With Quote
Old 02-20-2010, 08:10 PM   #125
Hart_Rod
Hart_Rod's Avatar
WATER TEMP - 3 3/8" mechanical Part #5507
Fuel Gauge -3 3/8" electrical Part #5514
Oil Pressure - 3 3/8" mechanical Part #5505
