Old 02-27-2010, 10:26 AM   #76
1949gmc
Re: MY 1971 Jimmy Build Thread
You know, I'm not surprised... this is very common in these. Much nicer, though, to have the light yellow truck sitting outside that has the pieces on it that I need.... just have to cut them off.
1949gmc is offline   Reply With Quote
Old 02-27-2010, 01:37 PM   #77
lks dcvn
lks dcvn's Avatar
Looks pretty good to me...almost exactly what I am working through on the blue one...
well worth the purchase price - even if they look solid in pix now - I know there will be rust hiding on these trucks...
lks dcvn is offline   Reply With Quote
Old 02-27-2010, 11:47 PM   #78
1949gmc
Actually, it's not that bad. The plan in my head has it going back together fairly easy. This is the kind of truck I wanted back when I got the other one... straightforward repairs and you know you've got a strong solid truck when you're finished.
Any word on that Jimmy yet, Tom?
Old 02-27-2010, 11:51 PM   #79
1949gmc
This is how rocker and floor repairs should be done! Hell, this is how changing your oil should be done!!
Old 02-27-2010, 11:54 PM   #80
1949gmc
Old 02-27-2010, 11:57 PM   #81
1949gmc
Old 02-28-2010, 09:22 AM   #82
lks dcvn
lks dcvn's Avatar
No word on the Jimmy yet...but I won't need to do anything with it until spring so that is fine by me.
Looks like you are moving along pretty good - nice lift.
It can be a pain to do all this work on the ground [sore back, legs, etc.].
Appears to be all the normal rust spots...
These pix would be a good 'where to look for rust on blazers?' answer.
I am hoping to get some welding done today - we will see how that goes.
Old 03-03-2010, 05:38 PM   #83
lks dcvn
lks dcvn's Avatar
bump for an update....and I was wondering - are you going to be using these patch panels from the old truck that are pictured below [labeled Right C-2 - not the other one pictured that holds the torsion box end cap]?
I was going to buy them in the Spring and figured I would see if you were going to use them before looking around elsewhere.
Let me know when you have a minute.
Thanks.
Old 03-03-2010, 06:18 PM   #84
1949gmc
Yep, I'm going to have to use them on the new one. The bottoms of the b pillar on both sides were completely rusted away. Should be welding the whole right side together tonight actually. Sorry I couldn't help ya.
Old 03-03-2010, 07:18 PM   #85
lks dcvn
lks dcvn's Avatar
No worries - figured I would ask.
I will just order a set later this month and get them welded in...when the time comes.
Old 03-03-2010, 10:08 PM   #86
jaros44sr
jaros44sr's Avatar
Not that my opinion matters much around here, but, I think it was a wise choice to get a new tub. When I did mine, after all the rust was gone, so was most of my body! Left with 2 bedsides and a winshield/cowl. Time wise, you are way ahead of the game.
Keep plugging away its lookin' good
Liking that old Chevy truck in the corner of the shop
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-04-2010, 04:31 PM   #87
1949gmc
Aww, c'mon Jim. Your opinion matters around here. Don't get so down on yourself. And thanks, I like having the new tub, too. Your truck sounds a lot like the one I started with. I had grand illusions, but when it came right down to it, like you said, there just wasn't much truck left.
Old 03-04-2010, 04:42 PM   #88
jaros44sr
jaros44sr's Avatar
The reason I continued down that path was I got tired of hearing guys badmouth the repop metal. I wanted to see for myself if there were issues. I've blended,OEM, old stuff, and repro stuff with out any problems. The one I do have is probably my fault for not paying attention
SAFETY FIRST
AS usual, off topic
Jim
Old 03-14-2010, 11:26 AM   #89
1949gmc
The right side is pretty much finished up. Just have to weld the rocker on permanently and weld in the patch for the floor.
Old 03-14-2010, 11:30 AM   #90
1949gmc
I did a little sanding last night.... put a full 12 hours in on this thing. Man, if I could put 12 hours in on this every day, it would be done in no time.
Old 03-14-2010, 02:25 PM   #91
lks dcvn
lks dcvn's Avatar
Nice progress - don't wish for every day to be a 12 hour day...I put way too many hours into my truck so far - at least I am almost done with the rust repair...if every day was a 12 hour day on these trucks - I might not like them as much -
I am taking a break from mine right now - been out there for 5 hours already today [trying to get the floor wrapped up]...
Hoping to get the driver side buttoned up today - not sure if I can do it - I already lost an hour [thanks to DST].
I will then turn my attention to the area behind both b pillars to get that wrapped up as well.
Imagine if you were still trying to fix that rust on the other tub - you would be cursing a LOT more...
Old 03-14-2010, 08:01 PM   #92
1956cameo
1956cameo's Avatar
That blazer is looking good! Keep us posted.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 03-22-2010, 12:05 PM   #93
1949gmc
One step closer
Got a little primer sprayed yesterday afternoon- zinc chromate. I remember my dad spraying this stuff on the sides of buses when I was a kid. I didn't think of that until I saw the color, though, then I was like, 'Oh yeah. I remember this stuff.' It went down real smooth.
Old 03-22-2010, 01:36 PM   #94
lks dcvn
lks dcvn's Avatar
Wow that looks pretty good!
Old 06-04-2010, 01:21 AM   #95
1949gmc
New pics!
Old 06-04-2010, 01:24 AM   #96
1949gmc
Old 06-04-2010, 01:25 AM   #97
1949gmc
Old 06-04-2010, 01:29 AM   #98
1949gmc
Old 06-04-2010, 01:31 AM   #99
1949gmc
Old 06-04-2010, 08:14 AM   #100
hgs_notes
GEARHEAD
hgs_notes's Avatar
It's wearing the coat of many colors. That's a lot of good work there.
hgs_notes is offline   Reply With Quote
