03-15-2010, 10:07 PM | #1 |
It'd be alot cooler if you did
My whole braking system - thinking out loud
Alright guys, my current braking system (whats left of it) is stock.
For the rear, I want to do a disk conversion, and use the wilwood d52 calipers. Whats the most ecomical kit to get me there? I am not opposed to putting my own kit togehter or scabbing parts from the junkyard, but I deffinatley want the pretty calipers. In the front, I'm thinking of sticking with the stock rotors for now, and also going with the wilwood d52's. Now, that being said, I need to figure out the rest. What brakelines do I need to run? What prop valve should I run? Should I just toss the stock prop valve and get an adjustable one? My M/C is under the dash, and leaves no room for a booster. I currently have a stepped bore M/C from a 85 c10 with manual brakes. Is this going to work or is there something I can step up to that will really make a difference? That ought to be enough questions to get the conversation started... |
03-17-2010, 04:45 PM | #2 |
Re: My whole braking system - thinking out loud
hmmmmm
03-17-2010, 08:45 PM | #3 |
i am interested in the same thing.
03-17-2010, 10:07 PM | #4 |
Happy to be here
What size wheel you goning to run?
03-17-2010, 10:15 PM | #5 |
me? 20 x 8.5 fornt 20x10 rear.
03-17-2010, 10:26 PM | #6 |
Happy to be here
I feel that if your after aesthetics as well as performance, 13" rotors would "look" better than 12" rotors. I have been contemplating a rear disc conversion for quit some time, and wanting a 13" rotor "and" an E-brake has been a big dilemma for me.
03-18-2010, 03:57 PM | #7 |
Who makes a 13" kit that fits the rear and how much is it? Using the method I descibed, I'll have about $700 into the rear. I am not concerned with an e-brake. I would also like the calipers to be "eye catching".
Also my concern with the 13" up front is that I would loose my 3" drop spindle in favor of the 2.5 modular spindle. I am not thrilled to give up that 1/2" as my truck sits perfect (control arms about 1/4" off the ground) with my current set up. |
03-18-2010, 08:06 PM | #8 |
Did you see what SSBC has for the c10's? I havent looked but was putting together a kit for my 1500. i would have to use the cadillac style for the rear conversion,,,calipers are ugly. There are some nice caliper and rotor upgrades for the front though. I'll see what they offer for the c10 and get back w/you. The best I could come up w/was $3K for front/rear.Not even B/Bs....
I think you will need a booster and maybe a 1.25 bore master cyl to push fluid to those rear disks. Last edited by Inverter; 03-18-2010 at 08:10 PM. |
03-18-2010, 09:17 PM | #9 |
I won't be using the seville calipers because of the looks, which is why I want to sub them for the d52 wilwoods. If I recall, the m/c I have has a huge bore for the rear,, I think it actually is 1.125.
If I absolutley have to I will run a booster, but that is going to make things way more difficult. (like remote master cylinder difficult) |
03-19-2010, 12:22 AM | #10 |
So you are going to use the cad style rear conversion and sub a d52 for the caliper?
If so, all you need is some cross drilled ( standard size ) rotors, another set of d52s and your done. How is it that you have manual brakes? Big brakes are great but 4 dual piston calipers and drilled rotors will be plenty for a short 1/2 ton,,especially w/good driving habits. Last edited by Inverter; 03-19-2010 at 12:29 AM. |
03-19-2010, 12:34 AM | #11 | |
Kind of what I was thinking.... plus I think it will look at least half way decent. What kind of rotors should I be looking at? |
03-19-2010, 01:45 AM | #12 |
I'm not sure but Im looking at getting some standard size that are cross drilled/slotted. There are quite a few brands,Be sure to get lefts and rights.
Standard diam. , of course.the site says the d52 is a direct replacement? It will look B/A and you'll gain at least 25% more stopping power over oem. I can't help you w/the prop valve thing.I'm still worried I might have to redo my setup. I need to get it worked out before paint.You know what brake fluid will do to the finish..?... Last edited by Inverter; 03-19-2010 at 01:51 AM. |
03-19-2010, 02:04 AM | #13 |
Actually for the money this kit doesn't look to bad. Any opinions?
http://www.summitracing.com/parts/WIL-140-10094D/ |
03-19-2010, 02:22 AM | #14 |
I was just looking at the Willwood site and noticed they make the D52 in two different piston sizes... which ones would be better for the front and rear? Also, I know I have the 1.25 rotors up front, is that what the rears would be with something similar to a black bird kit?
http://www.wilwood.com/CaliperList.a...0Dual%20Piston and while I'm posting links, anyone ever used this stuff or have any opinions on it? http://store.fedhillusa.com/ Last edited by smashingchuck; 03-19-2010 at 02:25 AM. |
03-19-2010, 05:30 PM | #15 | |
http://www.wilwood.com/BrakeKitsProd...no=140-10093-D |
03-19-2010, 05:38 PM | #16 |
gets board easy.......
i run 4 wheel disc on my nova with out power assist and it worked pretty good
03-19-2010, 06:03 PM | #17 |
Well here it what I have figured out. All the Wilwood kits have an internal "shoe" parking brake built into them... so thats a no go on a wilwood kit. So basically what I have figured out is that I want to do is this:
Wilwood Calipers Slotted and drilled rotors no parking brake What application are you guys using to buy the drilled rotors? |
03-19-2010, 11:35 PM | #18 |
my buddy with a street rod uses a line lock and a caliper on his drive shaft for his
e-brake thought it was cool and wanted to share |
03-22-2010, 08:17 PM | #19 |
Well here is what I have figured out so far. For the front, I'm going to run the Wilwood D-52 calipers PN 120-10936-RD. CPP currently has these on sale w/free shipping aand they come with the lines. For rotors I'm going to use the Summit Racing brand drilled and slotted rotors. Thats wraps up the front.
For the rear I'm planning on using another drilled and slotted rotor from Summit. The application is for a 95 Impala SS. The rear calipers will also be the D-52 (PN 120-10938-RD) but will have the smaller bore size. I still need to find a source for rear caliper brackets. People are not very fourth-coming with information about their brackets (so far no one has told me they make a bracket to fit this caliper) and they really dont want to sell "just the bracket". So I might be on my own with that one. If any one has any ideas on who might make a rear bracket that would really help at this stage!! |
03-22-2010, 09:45 PM | #20 |
Resistance is Futile
I was reading this and thought I'd let you know that Captainfab makes disc brackets for the rear. Maybe check the 60-66 parts section. He is always posting in the 60-66 forums. Not sure about the caliper type.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 03-22-2010 at 09:46 PM. |
03-22-2010, 10:01 PM | #21 |
He told me that they wouldn't work.... ?
03-23-2010, 12:51 AM | #22 |
This may not help but it's all I could think of. They're weld on.
www.1speedway.com/Brackets.htm Last edited by Inverter; 03-23-2010 at 12:54 AM. |
03-23-2010, 01:03 AM | #23 |
60-66 Nut
That is correct.....the rear disc brackets that I currently make won't work with the d52 calipers. I told you that before researching the calipers, which I shouldn't have done.....my appologies. Since the d52's are a direct replacement for the full size GM calipers, a set of brackets shouldn't be difficult for me to design and fabricate.
You say that you are wanting to go with the Impala SS rotor. I've got one of those to work with, so I'll have to look into getting one of the d52 calipers. Give me a day or two to get something going on this....I'll post back here when I have an update.
03-23-2010, 10:00 AM | #24 | |
03-23-2010, 10:57 AM | #25 | |
Believe it or not this leads me to another question... I noticed on the current brackets you make it looks like it mounts the caliper at the 3 o'clock position. Is it possible to clock it slightly upwards so it "matches" the position of the front caliper? Thanks a million for getting something going on this... |
