03-27-2010, 05:30 PM | #1 |
Hood to cowl seal and alignment
Hello all,
I just installed a new hood to cowl seal. The new seal is standing straight up and the old seal rolled over the cowl screws. Which is correct? I also am noticing my hood passenger side is sticking up in the back and getting worse. Is this a bad hinge or an alignment issue? Thanks in advance, |
03-27-2010, 05:34 PM | #2 | |
Re: Hood to cowl seal and alignment
03-27-2010, 05:50 PM | #3 |
i had/ have the same exact problem with the one from LMC....
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
03-27-2010, 05:51 PM | #4 |
03-27-2010, 05:55 PM | #5 |
Between Trucks...
They take a little bit to break in. You can adjust your hood by loosening the bolts to the fender, pushing up on the hood when it's open and retightening the bolts.
Beat it to fit, Paint it to match... |
03-27-2010, 06:35 PM | #6 |
Firefighter
That is how mine looked when I first put it on it stuck straight up, but now it is rolled over like the old one was. It's fine.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
03-27-2010, 06:47 PM | #7 |
The quality ones are already folded like the factory. Plus if you do purchase one from GM you don't have to do the little cut outs. If you Purchase Quality repro you will have to cut them.
Sounds like the other mentioned company was selling a cheap piece of flat rubber. |
03-27-2010, 07:03 PM | #8 |
Roto Reuter thats the name...
Hey I was installing an aftermarket one today too, but mine seemed to sit down a bit better and it has the cutouts. My issue is that there seems to be a big gap between the cowl and bottom (where seal goes). On each end where there is no seal there's a big gap. Is there supposed to be something else in there that I'm missing?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
03-27-2010, 07:34 PM | #9 | |
03-28-2010, 02:19 PM | #10 | |
This LMC part is not going ot work, half of it folds over when the hood is close, the other half pinches and folds in. I can't believe LMC would sell this thing. I've got it folder over with painters tape now so I can close my hood. Classy. |
03-28-2010, 02:35 PM | #11 | |
UH last time I looked we sell them but you can buy them here http://www.gmpartsdirect.com/restora...tocategory.cfm We have them in stock to |
03-28-2010, 03:23 PM | #12 |
18 Till I Die
Yes the repo ones are L shaped and the GM ones are bent back. I had this on for 2 years now and it still does not lay flat. My hood also gets pushed up because of this so I went and bought a GM one. I dont have the part Number but the 2nd pic is Gm correct. I will get around to instaling it this spring...
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
03-28-2010, 05:43 PM | #13 | |
They make the repro ones just like Gm its just these guys aren't buying them. The repros are just like GM except the little squares for the screws are not cut out and the GM have a few little ribs in them. Also a little lip on the flat edge. The other repros are not even close to a reproduction. Here is a picture of a repro not the flat rubber stuff |
03-28-2010, 05:45 PM | #14 | |
03-29-2010, 05:49 PM | #15 |
HickTown
does anyone have a direct link to the GM made ones???
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ |
07-28-2013, 08:40 AM | #16 |
I guess I should have done some research on here before I bought mine.Got one from lmc as well.It fits so badly its letting rain water on my cap and coil causing a no start.
04-13-2015, 10:05 PM | #17 |
I bought the cowl hood seal from LMC and wrestled with many of the issues mentioned here. My final solution (factory correct or not) was to fit the ribbed/lipped portion of the 90˚ rubber seal under the cowl, i.e., between the cowl and the body. When the hood drops, the rubber does a natural bend and seals against the top inside edge the hood.
10-18-2015, 05:05 PM | #18 |
I am in the middle of doing a screen under the cowl and the seal is shot so if anyone has a GM number please post it! FYI my seal was between the cowl and cab.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
10-18-2015, 07:55 PM | #19 |
Help!
10-21-2015, 10:09 PM | #20 |
Bump -----> Mine didn't have a cowel seal when I bought it... never knew it was supposed to, which explains a 'couple things. I am also having difficulty finding a source other than LMC.
1970 CST long bed Fleetside |
10-21-2015, 10:16 PM | #21 | ||
"I ain't nobody, dork."
About halfway down this page. $9.99 for the seal.
http://www.classicheartbeat.com/rubb...atherstrip.htm I bought this seal from Classic Heartbeat (site sponsor) and it fit just fine in my 1972 GMC. Gary
10-22-2015, 08:39 PM | #22 |
Ordered mine tonight from Classic Heartbeat. The freaking shipping was almost twice the price of the seal! Really! Anyway better be good. I'll let you all know.
10-22-2015, 09:36 PM | #23 |
Subscribed, I need this seal too
10-22-2015, 09:42 PM | #24 |
6>8 Plugless........
I'd like to know if it works too. I installed one from LMC on mine and ended up removing it. It's just another thing on the list to finish.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-26-2015, 06:33 PM | #25 |
Have not got it yet but Wes from Classic Heartbeat e-mailed me that I ordered 2,my mistake and I don't know where else you would get that kind of service!
