03-31-2010, 09:47 AM | #1 |
Re: Driveline Vibration
some vendors sell the angle shims cheaply that go under the saddles
another thing to check is make sure the drivshaft tyoke isnt going too far into the tranny// when i lowered 4" i trimmed about 3/8" off the yoke to b sure
03-31-2010, 10:55 AM | #2 |
Thanks. How did you trim it? On a band saw?
------------------------------------------------- Jim Garage fillers... 85 Chevy C10 Silverado LWB 07 Nissan Altima 2006 Mini Cooper S |
03-31-2010, 12:01 PM | #3 |
Just curious, does the vibration go away in neutral?
03-31-2010, 03:05 PM | #4 |
It is significantly reduced when the driveshaft is loaded, either accelerating or decelerating. When I'm cruising and feathering the throttle to maintain a constant speed is when it's the worst. Most of the time above 55-60 though I have a light rhythmic vib.
After looking at a buddies trucks (3) and seeing how much his slip yoke was sticking out of the trans tailshaft (about 5/8" - 3/4") I'm pretty sure that mine is either bottoming out or close to it. I don't have any stickout whatsoever. I took it back over to the driveshaft shop to get shortened about 5/8" and have a brand new slip yoke put on it just to be sure that isn't the problem. Cdowns, will it bottom out on the inside or the outside of the slip yoke? And just out of curiousity are there any shims or washers in between where the shafts bolt together?
04-01-2010, 11:20 AM | #5 | |
The light rhythmic vibration is called a "boom/beat", and that means there are two vibrations going on at the same time, canceling and adding in amplitude as they go in and out of phase. It is very likely the driveline (u joints are a second order of driveline, that is, they give you a "kick" two times for every time the shaft goes around) phasing with engine firing frequency. 1) Does the rhythmic vibration go away if you chose a different gear (while maintaining the same speed)? 2) Did you say what engine you have? V8 firing is four times per rev (4th order), I'd have to check to see what it is for an L6. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-31-2010, 12:24 PM | #6 |
just used a chop saw with a fiber cutoff blade then dressed the cut with a good file
