Old 03-31-2010, 09:16 PM   #26
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Originally Posted by glock35ipsc View Post
I'm bummed that you are downgrading to a carb. Although it will be very different when the hood is up. The TV cables are just as easy to hook up on a DBC throttle body as it is on a carb.
They make same hp and tq. I will only have one or two days to swap everything from gen 1 engine to gen 3. And want the ease of tuneing my self.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-31-2010, 09:24 PM   #27
85burb
85burb's Avatar
Down grade? The only diff is i will get a little less mpg. But i will be getting more then i am now. It will have same power. And look bad ass.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-01-2010, 09:33 PM   #28
85burb
85burb's Avatar
update.....Motor was dropped off at my work again today. Will look at it monday i hope. If it is the right engine this time i will have more pics.
Was wondering if i put l92 heads on it the only manifold they sell is for 3500-7500 rpm. I will have a 670 holly on it. Have not picked out a cam yet. I have a 1800-2000 rpm converter on it. was woundering how bad it will kill the low end if i use the big manifold compared to the 1500-6500 rpm one. But the low rpm manifold does not work with the l92 heads. I need help on this. thanks
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-05-2010, 03:19 PM   #29
85burb
85burb's Avatar
Finally The right one YAY..Going to get it on stand today i hope. should have more pics soon.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-06-2010, 10:01 AM   #30
justpball
justpball's Avatar
Sweet!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-06-2010, 10:44 AM   #31
85burb
85burb's Avatar
Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-06-2010, 11:07 AM   #32
Cherub
Cherub's Avatar
bet your glad its finally there
Cherub is offline   Reply With Quote
Old 04-06-2010, 11:14 AM   #33
85burb
85burb's Avatar
And they managed to send the right one this time!!! But they sold the power steering pump off of it when it was waiting to be shipped. But they sent one to me in mail. The sails man guy said this is the hardest sale they have ever had.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-06-2010, 11:16 AM   #34
bigdnew
Never Satisfied
bigdnew's Avatar
that make it even more worth it when you get it in and running.
1973 4x4 Blazer- Parting Out
1986 LWB Silverado Undergoing LQ4/4L80E Swap
'86 Build Thread:http://67-72chevytrucks.com/vboard/showthread.php?t=390566
bigdnew is offline   Reply With Quote
Old 04-06-2010, 03:06 PM   #35
85burb
85burb's Avatar
Oh yes it will. Hope to have it done buy end of the year.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-12-2010, 06:37 PM   #36
85burb
85burb's Avatar
Got carb in mail. YAY... But now i have to get it to pass the state safty inspection. First place failed me for missing 1 of 8 lugnuts and if you floor truck with e brake on it moves a little. It has a 4;10 rear end and a 3.xx first gear and a 2000 stall converter in it. Not a hole lot is going to stop it. dand sure not a 30 year old drum brake... second place failed me for power steering drip. It leaks maybe 3 dropps a month. just want to get on with motor swap and not deal with small stuff.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-12-2010, 11:13 PM   #37
85burb
85burb's Avatar
If any one needs carb tuning just let me know i know a lady that is pretty darn good
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-13-2010, 09:34 AM   #38
justpball
justpball's Avatar
dang I am so glad we dont have inspection in AL...LOL
87 Crew SWB
Build for the crew
90 burb 2wd
Old 04-13-2010, 01:33 PM   #39
85burb
85burb's Avatar
Ok went to non-crybaby place and it passed. Its back on now.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-13-2010, 10:39 PM   #40
menace121978
menace121978's Avatar
right on man... keep at it!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-14-2010, 01:04 AM   #41
85burb
85burb's Avatar
Oh it is going to happen. I will be ordering some parts this week. Not sure what tho. Maybe mounts and fuel pump and some fuel hose. Or maybe the control box. Just not sure.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-15-2010, 10:40 PM   #42
85burb
85burb's Avatar
Just put in an order for my hole fuel system, 105 GPH fuel pump, 20 feet of Braided Stainless Steel, -6 AN hose, lots of fittings, fuel log with same hose and fittings, regulator, PSI gauge, hose holders, and last but not least a hose barb. Should look very nice all together.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-20-2010, 07:40 PM   #43
85burb
85burb's Avatar
Was able to get some work done on engine. Removed intake, exhaust, accesory brackets, and looked under valve covers. All looks pretty good. Just dirty on out side. Next time i work on it i plan on painting it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-20-2010, 07:41 PM   #44
85burb
85burb's Avatar
Got some bling in mail today....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-20-2010, 07:42 PM   #45
85burb
85burb's Avatar
Also will sell stock motor mounts that came with it and AC bracket and intake manifold assembly.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-24-2010, 08:37 PM   #46
85burb
85burb's Avatar
Latest pic... She is showing me how to "fisk" my speedo cable.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-24-2010, 09:01 PM   #47
nlped
nlped's Avatar
^^^That picture is awesome!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-24-2010, 09:22 PM   #48
85burb
85burb's Avatar
She also knows Hollys well. Trying to get her to get all the way under so she can get to all the tight spots for me.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2010, 11:42 PM   #49
85burb
85burb's Avatar
Not a hole lot going on this week. Trying to figure out what flywheel/spacer combo to use. Any ideas?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-26-2010, 11:50 PM   #50
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I can't help yet....I ordered the GM one but haven't recieved it yet.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
