Old 04-19-2010, 07:42 PM   #101
lowdownstar
big guy
lowdownstar's Avatar
Re: Dropmembered trucks
it was my daily driver till about two months ago! s-10 with ralleys lowerd
Ray
lowdownstar is offline   Reply With Quote
Old 04-19-2010, 08:50 PM   #102
drewfever1020
ok im wanting to dropmember my truck but am i gonna have to notch the front of the frame?
and say i do get a drop member front will all the stock parts fit on it?
drewfever1020 is offline   Reply With Quote
Old 04-19-2010, 09:06 PM   #103
texastrendz
yea i grew up with smiley, how do ya say it"we are from the same hood" he was in the mini truckin set also, i also had a feature in mini truckin , stone toy was the name of it. i used air shocks on the front with the torsion bars, god it was ghetto fabulous. i had the whole walk thru with the camper and everything.
texastrendz is offline   Reply With Quote
Old 04-19-2010, 09:22 PM   #104
SCOTI
SCOTI's Avatar
Yes, the frame has to have c-notches welded in for R&P clearance. Later model a-arms (73-87) arms can be used (or Porterbuilt/Ride Tech style tubular arms) & stock or dropped spindles w/factory brakes.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-19-2010, 09:50 PM   #105
drewfever1020
so my stock arms on my 71 wont fit?
am i gonna have to relocate all the lines like brake likes that run on the stock cross member or will they fit like the stock trucks come?
Old 04-19-2010, 10:05 PM   #106
SCOTI
SCOTI's Avatar
The older DM's would work w/the pre-73 a-arms w/some modifications. His newer versions need the post-73 arms because of the style of bushings & how they mount.
I'm not sure on your brakeline question. I'm using 73-80 style lines w/some tweaks on mine.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2010, 10:07 PM   #107
lolife99
67-72 parts collector,…
lolife99's Avatar
I just fabricated new lines for the front brakes. Alot easier than trying to make your 40+ year old lines work. (my opinion)
Keith
Convert to disc brakes.
Old 04-19-2010, 10:37 PM   #108
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You can do it Drew. If your not a welder, just take it to a welding shop and have the notches welded in. Or get in the texas section. Lots of good guys I've met down there could probably help you out.
I dont have the PB, but the SD raised crossmember, and I will tell you that Nate is a very stand up guy and will make sure that you are running everything right. He's helped me out a lot even though I've never bought anything from him.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-19-2010, 11:38 PM   #109
DZL1
One day.....
DZL1's Avatar
Originally Posted by GVizzle View Post
Did it involve wet wipes?
Yes, and lots of them.
DZL1.
DZL1 is offline   Reply With Quote
Old 04-20-2010, 12:08 AM   #110
andrewmp6
Do you have to cut the trans cover on 73-87 trucks ?
Old 04-20-2010, 12:28 AM   #111
molinehotrod
molinehotrod's Avatar
dropmember looks great, but i like to do every thing my self. stock cross member moved up 2 narrowed stock a arms, drop springs with coil cut off, drop spindals. Alot of work but $50 in gas and wire.
molinehotrod is offline   Reply With Quote
Old 04-20-2010, 01:37 AM   #112
PBFAB.COM
PBFAB.COM's Avatar
Nope... no cutting on the 73-87 cab floor.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-20-2010, 08:07 AM   #113
drewfever1020
how did u move ur dropmember up a little?
Old 04-20-2010, 08:30 AM   #114
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Drew, Moline moved his factory cross-member up. His whole post is in reference to modding his stock parts and drop springs as an alternative to the dropmember. It solves the problems of getting low and investing time in place of money but not sure if it would correct the steering box issues or bump steer that are the real benefits to Nate's piece.
Josh
and to be fair and disclose- Hell yeah, I rock a dropmember.
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 04-20-2010, 11:18 AM   #115
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
dropmember looks great, but i like to do every thing my self...
I do too, I Zed my frame and sectioned my crossmember myself so I know I can do it. I ordered a Dropmember myself because Nathan can do it better than I can
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-20-2010, 03:13 PM   #116
bruce bruce
Here's a couple of mine. Still have to cut some stuff off the bottom of the frame to lay it all the way out.
bruce bruce is offline   Reply With Quote
Old 04-20-2010, 03:47 PM   #117
m6z
m6z's Avatar
Nice. I can't wait to start making progress on my new project.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 04-20-2010, 04:01 PM   #118
67cheby
67cheby
67cheby's Avatar
really like the wheels , nice job
67cheby is offline   Reply With Quote
Old 04-20-2010, 04:06 PM   #119
Dinos63
chevy only
Dinos63's Avatar
Originally Posted by way2lo2 View Post
here is mine, been driving it for a few weeks now, i purposely left the drive train and front clip on it while doing the dropmeber so it wouldn't escalate into another unfinished personal project.
borris that truck is so sic!! Hows my old truck coming ?
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 04-20-2010, 04:14 PM   #120
Dinos63
chevy only
Dinos63's Avatar
THANKS NATE ! ALL 3 OF MY DROPMEMBER TRUCKS WORK KILLER!!! AND I HAVE THE VERY FIRST ONE AND TWO AND I THINK 3 ALSO VERY PROUD OF YOU KAT!!!
Old 04-20-2010, 04:25 PM   #121
noonzor
swweeeeeeeeet. man i cant wait to get mine installed!!!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 04-20-2010, 06:59 PM   #122
drewfever1020
bruce bruce what setup do u have on your truck?
u have stock crossmember?
Old 04-20-2010, 07:21 PM   #123
Dinos63
chevy only
Dinos63's Avatar
Few more
Old 04-20-2010, 07:22 PM   #124
Dinos63
chevy only
Dinos63's Avatar
AND THE WHITE SUB IS NOT MINE , ITS ROBS
Old 04-20-2010, 07:44 PM   #125
scotts62
One day...
scotts62's Avatar
Awesome rides guys!!!
Scott
93 crew cab build
Project 62
