04-25-2010, 10:44 PM | #1 |
Pate Swap Meet Stuff - Dallas
I don't have a spot but I will be there Saturday and can deliver any of this stuff...need it out of my garage. If anyone is interested let me know and I can meet you Saturday. Everything below is from a 1971.
Original gas tank with sending unit and in cab sending tube. Looks almost new...$75 Doors - Come with all glass and hardware but need a lot of work. $50 each or $80 for the pair Radiator - Not sure it's an original but it didn't leak when I pulled it. She's not pretty....$75 Seat Frame - What can I say...need it out of the garage. $25 I am looking for a cab dolly and some nice inner fenders. Thanks Jonathan jdpkelley@yahoo.com |
04-25-2010, 10:54 PM | #2 |
Re: Pate Swap Meet Stuff - Dallas
I don't want to sound noobish but would that gas tank fit a 65? I know in my 69 the gas tank has the fill tube, and the fill tab thing included on it, and it's approximately the same size. I live in El Paso, shipping would suck, but I might be able to meet half way?
04-25-2010, 11:20 PM | #3 |
A '65 is definitely a different tank. You might be able to make it work...but even halfway to El Paso is a looooooong way.
You can probably find a good one in a salvage yard in the dry air out there. Good luck! |
04-26-2010, 12:14 AM | #4 |
Jonathan, The radiator appears to be the original 4 core and has the places to hook up automatic transmission lines.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
04-26-2010, 01:01 AM | #5 |
Thanks for the info! I think what I'll do is try to find the 67-69 tank, cut off the fuel neck with the gas cap arrangement thingamajig, and have it welded onto my 65's tank. My 65 has a brand new tank anyway
04-26-2010, 10:06 PM | #6 |
04-26-2010, 10:26 PM | #7 |
is that drivers side door rusted at the bottom?
04-27-2010, 10:03 PM | #8 |
Yeah, I would recommend putting a new bottom on both of them.
04-27-2010, 10:35 PM | #9 |
I bought a set of buckets off ebay and the drivers seat brackets didn't have the slide lever or mechanism. I will reasearch to see if your bench seat lever and catches will work, if so, I will buy it Saturday.
04-28-2010, 01:59 PM | #10 |
Let me know ahead of time as I am not bringing anything that isn't sold prior.
The rails have a little bit of surface rust but should clean up pretty nicely. |
04-30-2010, 03:05 PM | #11 |
Hello, interested in the Radiator. I have a 67 1/2t swb w/ I6 250 also standard 3 speed, will it work in my ride? Does have any leaks or defects that require repair? I need one that ready go in and work only. Thanks, Chris.
05-01-2010, 04:21 PM | #12 |
Sorry for the delay in responding. I am not sure if it will work on your ride. You many need to do a little research. It was working when I pulled it but I only drove it around the block. I never really heated her up. It did seem to hold water though.
