Old 05-22-2010, 04:37 PM   #1
Goldfinger
Goldfinger's Avatar
Is frame damage common on an 85 c10?
Early last year i went mudding and I think I bent my frame under the Cab right behind the Tranny mount. It appears to be warped. the other side is bent up from slipping off a jack at walmart while the tires where being balanced. Their jack collapsed under the weight of my truck. Give me any ideas on a fix. I have welding and fabrication experience but if i torch it it will forever be weakened. Any ideas?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-22-2010, 05:13 PM   #2
73chevyman
73chevyman's Avatar
Re: Is frame damage common on an 85 c10?
looks to me you came down hard on something..... they are known for cracking at the steering box
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-22-2010, 05:16 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
The spot that looks to be warped down is normal. They're all like that.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 05-22-2010, 05:31 PM   #4
Goldfinger
Goldfinger's Avatar
would that cause the tranny mount to bend as well because it did a 90 degree The driver side of the mount is vertical
Old 05-22-2010, 05:38 PM   #5
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
mine has that same warp in the frame, i was hoping it was normal.
staggerd86c-10 is offline   Reply With Quote
Old 05-22-2010, 05:39 PM   #6
73chevyman
73chevyman's Avatar
no you probably snaged on to somthing while backing up i see what your talking about now
73 C10 Fleetside
Old 05-22-2010, 05:49 PM   #7
78 Chevyrado
The part bent on the frame where is starts to bend up is normal. It's there to clear the catalytic converter. My 77 and 87 both came that way brand new. Looks like the crossmember is bent badly though.
78 Chevyrado is offline   Reply With Quote
Old 05-22-2010, 06:15 PM   #8
Goldfinger
Goldfinger's Avatar
That would describe the heat-shield thats doing nothing right above it
Old 05-23-2010, 03:06 AM   #9
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=281521
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 05-23-2010, 03:20 AM   #10
ElGracho
ElGracho's Avatar
Here's another...
http://67-72chevytrucks.com/vboard/s...ad.php?t=60525
Joe
1985, c10, frame, square body, truck
