05-27-2010, 04:52 PM | #1 |
2 1/2" ram horn exhaust manifolds? Or something better?
I want to swap out my headers (Hooker Competition) for some 2 1/2" ram horns. (Or is there something better that won't leak?)
Anyone know the best place to order a set? Once done anyone who wants my old headers can pick them up free of charge. |
05-27-2010, 07:38 PM | #2 |
Re: 2 1/2" ram horn exhaust manifolds? Or something better?
Bigeasy -
I switched to 2 1/2-inch ramhorns a while back after giving up on getting my headers to seal. Best mod I ever made. I can get you the Dorman part numbers for the right and left units if you want. Think they were like $90 a piece, but I could be wrong, its been a while. You could try to find an actual GM set, but that could take a while and cost you more. |
05-27-2010, 08:23 PM | #3 | |
Love the numbers if you get a chance...I'm so ready for a leakless exhaust.
05-27-2010, 08:27 PM | #4 |
I made the swap 10 years ago and consider it one of the best mods I have made. I also went to Dynomax Hemi turbo mufflers and leave the throaty sound and almost stock noise level at idle. Here is a link to one I found, I used two of these and just bandsawed the alternator mount off and ground the sharp edges.
http://www.autopartswarehouse.com/de...1&apwidWRp8aH1
05-28-2010, 11:26 AM | #5 |
Dorman 674-504
Get two of these: Amazon.com: Dorman OE Solutions Exhaust Manifold... There is also another thread discussing this above this one.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
05-28-2010, 03:53 PM | #6 | |
That is 2 of the left hand sides correct? These do not have the heat tubes on them? And you just grind off the alt. mounts? Correct? Thanks for the link BTW.
05-28-2010, 04:34 PM | #7 |
urban fourwheelin
Use these remflex exhaust gaskets. i use them on every car I can.
http://catalog.remflex.com/ They will seal your headers up. I've got hooker comps that I put on 8 years ago with these gaskets. I re-tightened them at 500 miles. 8 years later no leaks.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. Last edited by RED72blazer; 05-28-2010 at 04:35 PM. |
05-28-2010, 04:41 PM | #8 |
Correct.
05-28-2010, 06:02 PM | #9 |
Speedway motor has them for $60 each. Part # 930-0327-Side. Specify L or R.
05-28-2010, 06:38 PM | #10 | |
05-28-2010, 06:43 PM | #11 | |
urban fourwheelin
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
05-28-2010, 06:50 PM | #12 |
05-28-2010, 09:32 PM | #13 |
urban fourwheelin
probably, I've had some success with bending them back on other vehicles as well.
If I was going to redo everything I probably would have gone with ram horns 2nd time around. Stock appearing is more my style now.
05-28-2010, 11:28 PM | #14 |
Agreed ...I'm going the ram horn route less worries and its a PITA to remove drivers side.
05-29-2010, 04:52 PM | #15 |
13lazers' blazers
I am also using the 2-1/2" ram horns and I love them. I also wanted to be able to remove them easy so I could work on my heads if necessary. I cut my exhaust pipes on each side just behind my motor and I installed a ball and socket exhaust connector like the ones that were on fox body mustangs and hipo thunderbirds. I don't have the problem of trying to tighten the three bolts at the bottom of the manifold in such a tight space anymore.
1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat almost all exempt from california smog laws intentionally. |
05-29-2010, 05:47 PM | #16 | |
05-29-2010, 06:17 PM | #17 | |
05-30-2010, 12:09 AM | #18 |
13lazers' blazers
Here are a couple of pics I just took. I cut the socket off a 1990 ford t-bird with a hipo motor. The 1987-1993 mustangs also have the same type of flanges on the H-pipe.
05-30-2010, 12:23 AM | #19 | |
Nice Bass!
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-30-2010 at 12:24 AM. |
12-04-2012, 11:46 PM | #20 | |
But Found Her 25yrs Later!
Old thread. - Great Tip.
09-02-2014, 01:30 PM | #21 |
Old thread with good info on Rams Horns.
1971 K20 Suburban 2012 LS1500 4WD Suburban 2003 Honda Accord LX V6 (don't tell anyone) MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915 |
12-22-2014, 02:30 AM | #22 |
12-22-2014, 12:53 PM | #23 |
Active Member
i have a set locally but im not sure if these part numbers are correct. I would like to put an original set back on my blazer but would these work?
3733976 (LEFT, LH) and 3747038 (RIGHT RH) |
12-23-2014, 09:58 AM | #24 |
Original manifolds were 2 1/4" outlet. The 2 1/2" flow significantly better and look the same for the most part, not sure about your part numbers.
08-23-2015, 05:54 PM | #25 |
zombie thread revival.
Bigeasy, which manifolds did you end up going with? Dorman? How do you like them after all this time? Thanks |
