Cops, ha, catch me if you can!
Brake Light.
I am going to assume the brake light on the instrument panel just indicates that the parking brake is on, I can't imagine that there are sensors for the brake system indicating there is a problem. The reason for me asking this is; I was driving in to work today and noticed the brake light was on (parking brake was off), the brakes work fine, so I am guessing it is just the switch for the parking brake that went bad. If some one can let me know if the light means something more then what I think, I would appreciate it.
Thanks, Josh.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() |
Between Trucks...
Re: Brake Light.
Brake light means there is something wrong. Check the fluid level in the MC, check for leaks in the whole system. Though it could be an electrical malfunction.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 06-04-2010 at 01:20 PM. |
Re: Brake Light.
I will check the fluid level.
Re: Brake Light.
If your truck has a brake proportioning/combination valve: there could be electrical content there. If you have a leak in the front half or back half of the system, it will "shuttle the valve" to close the offending side off - and - turn the light on in the dash.
Because most of the braking is done with the front, conceivably you could close the rear brake system off and not really even notice. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#5 | |
Re: Brake Light.
#6 | |
Re: Brake Light.
If the tan wire going to the prop valve is shorted to ground it will also cause the light to come on, a quick test is to disconnect it from the prop valve if light stays on problem is in the wiring if light goes out problem is in the brake system
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Re: Brake Light.
On factory dual/split systems, which I think is everything since 1967, there is a switch in the distribution block. This switch will light the brake warning lamp in the event of pressure loss on either side of the system. Unfortunately, it doesn't reset automatically. Disconnect the wire from the switch, and if the lamp goes out, that's where the problem is.
Ray |
Re: Brake Light.
If the problem turns out to be the Proportioning Valve, is it safe to drive it for short distances till I get time to fix it? The last thing I want is to lose my brakes and wreak my truck.
#9 | |
Re: Brake Light.
Are you talking about the the wire that plugs into the Valve body?
Re: Brake Light.
I only got this truck about a year ago and I don't know what kind of brake fluid the previous owner might have used, I am guessing DOT 3 is standard for these trucks, am I correct?
Between Trucks...
Re: Brake Light.
DOT 3 brake fluid, IIRC. The wire goes to the proportioning valve which connects to the master cylinder. I would figure this out before you go driving around.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 06-04-2010 at 07:32 PM. |
Re: Brake Light.
Re: Brake Light.
I think I found the problem, after looking in the engine compartment, I noticed brake fluid that had leaked onto my firewall, look at the MC and found that fluid was leaking out of the top from the rear reservoir. I took the cover off to inspect the gasket and noticed some dirt on it as well as on the top part of the MC, I cleaned them, filled up the rear reservoir and no more light.
Just want to thank everyone for the help. Josh.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() Last edited by gonzo6869; 06-07-2010 at 09:27 AM. |
Between Trucks...
Re: Brake Light.
Glad you got it sorted out. I would keep an eye on it just to make sure.
Beat it to fit, Paint it to match... ![]() |
#15 |
Re: Brake Light.
I will keep an eye on it. One question, would a bad seal on the back reservoir cause the brake light to come on, would that create low pressure for the back brakes? Well I guess thats two questions.
Thanks again, Josh
#16 | |
Re: Brake Light.
Hopefully, adding fluid restores the pressure to the rear, and the first "hard" depression of the brake pedal re-centers the combination valve, turning the light back off. That's how it's supposed to work, anyway - K
#17 |
Between Trucks...
Re: Brake Light.
If the seal was bad and it was leaking, yes.
#18 | |
Re: Brake Light.
Josh
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() Last edited by gonzo6869; 06-07-2010 at 03:14 PM. |
#19 | |
The Red Menace
Re: Brake Light.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
#20 |
Re: Brake Light.
I am experiencing a similar problem, except my brake light on the dash is flashing. It's never done this before, and everything appears to be okay. I checked the brake fluid, and the truck stops fine. The weird thing is that it also flashes when the ignition is on, but the truck is off. . .
1972 Chevy C-10 ~ 188,000 miles give or take |
#21 |
Re: Brake Light.
Isn't there a brake light switch on the parking brake? Or am I thinking of my Chevelles?
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#22 |
Re: Brake Light.
I think your right, I thought it came on with the parking brake, but now that the problem is fixed the light dose not come on with the parking brake engaged.
#23 |
Re: Brake Light.
Does anyone have any thoughts about why the light would flash??
#24 |
Re: Brake Light.
Dose it flash all the time?
I would not know why it would flash, but try unplugging the wire on the valve body and see if you still have the problem, if you do its electrical and not mechanical.
#25 | |
Re: Brake Light.
Do the test in post #6 if the light doesn't go out or stop flashing then that means the tan wire is shorting to ground. the tan wire also goes to the ignition switch to illuminate the light while cranking to serve as a bulb check.
Tags |
brake, light |
