Old 06-09-2010, 03:32 PM   #1
Malibob
Malibob's Avatar
Does this work???
I saw this while searching for ideas today and I was shocked. This has to be unsafe even if it was welded. Am I right or would something like this work?
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 06-09-2010, 04:22 PM   #2
66coffin
66coffin's Avatar
Re: Does this work???
Looks a bit sketchy to me, i wouldn't drive it with out boxing the whole section in front and behind the cut. Even that, i don't know how strong it'd be.
'66 c10ish straight 292 power!
66coffin is offline   Reply With Quote
Old 06-09-2010, 04:25 PM   #3
daverod
SSN 706
daverod's Avatar
I guess it would depend on what your definition of safe is. Kinda like I never had sexual relations with that girl. I don't see a problem as long as it welded good, put some gussets on the side and box it in. I'm sure thats not the final product. I hope not. It will be intresting to see what people say.I like it.
daverod is offline   Reply With Quote
Old 06-09-2010, 06:36 PM   #4
shark66
I would put some type of cross member between the two upper frame rails to keep that thing from twisting up.
shark66 is offline   Reply With Quote
Old 06-09-2010, 07:12 PM   #5
raycow
I was going to say I wouldn't wish that on my worst enemy, but on second thought, I probably would.
Ray
raycow is offline   Reply With Quote
Old 06-09-2010, 07:47 PM   #6
CSGAS
optomistic ah-so
CSGAS's Avatar
That's one of the steps in beginning the strongest way of Z'ing a frame, but like the previous posts pointed out it must be completed with plating, boxing, reinforcing plates, etc.
From the existence of Vise-grips, rod, and calipers in the pic I am very sure the builder does not consider the job done yet, so I will not judge the builder while the work is in progress.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 06-09-2010, 09:02 PM   #7
Malibob
Malibob's Avatar
I was also assuming it was a work in progress. He did say it was bolted though. I was wondering if the process or idea was a decent one. I would hope the guy isn't driving around with vised grips holding the back half of his truck together.
Flickr
frame, notch, z-ed
