Old 06-18-2010, 09:36 PM   #1
AirSpeed
AirSpeed's Avatar
What tool to turn tie rod adjusting sleeve?
I need to adjust the tie rod adjusting sleeve on my 72 GMC 4X4, I tried a pipe wrench but it would only pinch the sleeve closed when I put pressure on it, I did get it to turn once by using a big flat screw driver in the split area but that sucked and took forever for one revolution, I need to turn it 2 or 3 more times. Any suggestions on the correct method?
Thanks! Aaron
AirSpeed is offline   Reply With Quote
Old 06-18-2010, 09:42 PM   #2
71swb4x4
71swb4x4's Avatar
Re: What tool to turn tie rod adjusting sleeve?
I always thought you turned the tie rod itself, but I could be wrong.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-18-2010, 09:54 PM   #3
Crazyz28
I've always used channellocks at work, for those muddy/dirty/rusted ones I've just used a big screw driver. Vicegrips with a rounded grip head may work better too due to more gripping surface with the rounded grip.
'72 Chevy Longbed 327 w/ 3 on the Floor-soon to be DD
'71 GMC Longbed (originally bought project, now parts truck for '72)
'94 Camaro Z28 cam/exhaust/gears
'02 Chevy Impala-DD for now
-Ryan, GM Master Technician
Crazyz28 is offline   Reply With Quote
Old 06-18-2010, 10:13 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I sprayed mine (rusty) with Liquid Wrench and let it soak in. Then vise grips worked for me too but had to slowly work it back and forth to loosen all that dirt and rust.
68gmsee is offline   Reply With Quote
Old 06-18-2010, 10:30 PM   #5
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
pipe wrench. LOL
seriously, just get a "bolt" the same size as the tie rod about 1/2 in. long.
turn the bolt into the adjusting sleeve til it bottoms out then the adjusting sleeve should start turning with it.
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 06-18-2010, 10:59 PM   #6
AirSpeed
AirSpeed's Avatar
Originally Posted by beebster View Post
pipe wrench. LOL
In order to put a bolt into the end of the tie rod adjusting sleeve I would have to pop the tie rod end out of the steering arm then remove the tie rod end from the sleeve, this would defeat the purpose wouldn't it? I am trying to adjust the tie rod ends, they have opposing threads so that when the sleeve is turned the tie rod assembly gets longer or shorter depending on the direction I turn it. I need to keep the assembly together in order to test it's position until I get the truck to steer equally as possible.
Old 06-18-2010, 11:07 PM   #7
AirSpeed
AirSpeed's Avatar
The threads on the tie rods are very clean, like I said I tried a pipe wrench but I also tried channel locks, the problem with those is they squeeze the adjusting sleeve making it so tight against the threads that it won't turn, there must be a method that makes it easy.
Old 06-18-2010, 11:29 PM   #8
geezer#99
geezer#99's Avatar
If there's a bolt and nut on the end to tighten it down when your final adjustment is made use a box end wrench on the bolt to swivel it around. Worked for me.
Old 06-18-2010, 11:44 PM   #9
AirSpeed
AirSpeed's Avatar
I even tried that! It worked for about a half turn then just kept popping off. Maybe I should clarify the part I'm working on, it's the drag link that connects to the pitman arm and then the left spindle. I am a little apprehensive to experiment with the steering components, every time I work on them I freak myself out later second guessing myself that I tightened everything up! Thanks! Aaron
Old 06-18-2010, 11:48 PM   #10
AirSpeed
AirSpeed's Avatar
This is the part I'm working on, it's assembled though.
Old 06-18-2010, 11:50 PM   #11
beebster
beebster's Avatar
Instead of pulling your hair out and fighting with it, you could have popped the tie rod out, removed it,handled your business w/ the adjusting sleeve and had it back together again. LOL
I love stock!
Old 06-18-2010, 11:54 PM   #12
AirSpeed
AirSpeed's Avatar
Not really, I would have had to do that repeatedly until I got it centered, even if I popped the tie rod out I would still need to turn the adjusting sleeve, it would probably been even more of a pain with the end flopping around.
Old 06-18-2010, 11:56 PM   #13
leddzepp
Moderator
leddzepp's Avatar
It might be cross threaded if the threads are clean and it is that difficult to turn.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-19-2010, 06:36 AM   #14
ERASER5
ERASER5's Avatar
I stick a screw driver in the slot and twist. There is a tool that will hook into the slot and connects to a ratchet. It works a bit like a crows foot. I prefer the screw driver method.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-19-2010, 06:52 AM   #15
68C15
blood type; Retumbo
68C15's Avatar
http://www.otctools.com/products/popular.php
the one on the bottom left is the one I use most.
check with local parts stores (NAPA), some may even have it in stock.
68C15 is offline   Reply With Quote
Old 06-19-2010, 09:05 AM   #16
LONGHAIR
What you need is the Proper Tool for the job. Here is a picture for reference, but you should be able to get one locally. Try a NAPA store or a specialty tools store if you live in a big enough city.
It "Hooks" in the slot and actually pulls in the opposite direction of the crushing that happens with pipe wrenches or other gripping tools. You turn it with a ratchet or breaker-bar.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-19-2010, 09:20 AM   #17
68gmsee
Active Member
68gmsee's Avatar
If it's clean and free of rust and grime and it's that difficult to turn, there's something else wrong with it. As someone suggested it may be cross threaded. I've never had a problem turning them with pliars or vise grips.
I'd suggest to take it to a shop to have them do it, but if there's something wrong with it, you still will have to come up with the bucks to fix it plus their labor costs.
As another post said, it's probably better to take it off and see what's wrong with it.
Old 06-19-2010, 09:54 AM   #18
71tahoe
71tahoe's Avatar
You say it's free of rust and crud. Are you trying to bring it closer together or adjust it apart? You may either be out of threads or the ends of the tie rod ends are jammed together. If you loosened the bolts on both ends of the sleeve it should turn.
71tahoe is offline   Reply With Quote
Old 06-19-2010, 10:20 AM   #19
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
i took a nut that just slid over the sleeve, cant remember the size? anyways, i centered the nut on the sleeve and stitched it on with my mig. now a guy can get a wrench on it when adjustments need to be made. you can buy similar ones...... but kinda pricey?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 06-19-2010, 12:11 PM   #20
90\87Formula
90\87Formula's Avatar
Took me about two hours to find it.
Here's your proper tool. It's about 8" long. Don't remember where I got it, but I've had it for years.
Works great.
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 06-19-2010, 12:43 PM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I can guarantee that an alignment shop doesn't pop the tie rod out of the spindle or centerlink and turn it in or out and then put it back in. They turn the sleeve only... with the proper tool. Which has been shown above.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-19-2010, 01:30 PM   #22
AirSpeed
AirSpeed's Avatar
Works great.
Thanks! Sorry it took so long to find it! I guess it's not something you would use everyday! I am going to head to my shop and make one, looks pretty simple. Thanks again! Aaron
