Old 05-03-2010, 07:25 PM   #176
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Show your motor...
This is the only clean one I own.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 07-02-2010, 12:00 AM   #177
po_bird
po_bird's Avatar
MY NEWEST.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 07-02-2010, 12:23 AM   #178
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
how do you guys mask off everything so nice?!?!?
And whats the process for painting after you get it back from the machine shop? primer? if yes what kind?
John
1999 Toyota Tacoma 4x4
Old 07-02-2010, 01:52 AM   #179
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
I just did a cam swap and dressed my lil rat up a bit
Now
Name:  new timing chain.jpg
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Last edited by Camaro_nut2001; 07-02-2010 at 01:59 AM. Reason: Pictures didnt post
Camaro_nut2001 is offline   Reply With Quote
Old 07-02-2010, 01:58 AM   #180
Camaro_nut2001
Before
Name:  old_motor_ front.jpg
Old 07-02-2010, 02:57 AM   #181
greenbd71
greenbd71's Avatar
350 Original
greenbd71 is offline   Reply With Quote
Old 07-02-2010, 06:17 AM   #182
prairewolf
before pics, 67/327 and 72/402. at my speed these may be the after pics too
lots of inspiring pics on here though, thanks for sharing.
kent
eat,work,spend,sleep,repeat.
prairewolf is offline   Reply With Quote
Old 07-02-2010, 08:23 AM   #183
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
The monster of stock BB's..410 hp and 435 torque....I'm planning On shootiing it with another 100 so its waiting on the floor for some ching to buy a DS and exhaust...I added a set of yellow 8mm wires..the pic doesn't do it justice...wrinkle black and silver wheel paint...I was going for the harley engine look
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 07-02-2010, 08:49 AM   #184
eagleuh1
eagleuh1's Avatar
My 68 C20 with 5.3, just ran 1st time last night.
eagleuh1 is offline   Reply With Quote
Old 07-02-2010, 02:37 PM   #185
jgreene0717
Jason
jgreene0717's Avatar
Here's mine.
jgreene0717 is offline   Reply With Quote
Old 07-03-2010, 12:08 PM   #186
Bennett68C10
Bennett68C10's Avatar
Here's mine freshly painted,
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-03-2010, 05:32 PM   #187
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Got my 406 running sweet figured i would post a pic. Still have to go down a size on the carb spacer and put my taller air cleaner back on. Still got alot of goodies to put on. Just glad shes done....
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 07-03-2010, 05:46 PM   #188
Thealien
Thealien's Avatar
Just working out the last few bugs. Runs good though, finally.
Old 07-03-2010, 05:53 PM   #189
Fitz
before & after:
Fitz is offline   Reply With Quote
Old 07-03-2010, 06:25 PM   #190
Mia66GMC
Chevy 350!!!!!!!!!
Mia66GMC is offline   Reply With Quote
Old 07-03-2010, 07:57 PM   #191
Newtz67
Newtz67's Avatar
I use duplicolor engine paint from kragens. I spray 2 coats primer, 2 coats color, and 2 coats clear.
Newtz67 is offline   Reply With Quote
Old 07-03-2010, 08:12 PM   #192
Slick67
Sofa King Crazy!!
Slick67's Avatar
Update. 66 Vette block 327, 70 LT1 Bowtie/Snowflake high rise intake, Edel 600 carb, HEI, still needs a few things but she lives!!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-03-2010, 08:12 PM   #193
oldblue1968chevy
thanks newtz! I used reg. primer (non high temp) and ended up wiping rubbing scraping it off with brake cleaner lauqer thinner.
Then sprayed a few coats (mayve been thick i suck at painting anything). Its dried a day or so now. I can kidna scape at it and it comes off!?
Thanks Oh here it is
John
Old 07-03-2010, 09:53 PM   #194
weircc
weircc's Avatar
one more
weircc is offline   Reply With Quote
Old 07-03-2010, 11:00 PM   #195
Booya
Booya's Avatar
My little 350 I just finished up.
Booya is offline   Reply With Quote
Old 07-04-2010, 02:36 AM   #196
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
thanks booya!
I think most of us would be satisfied with a nice/solid/dependable small block like that,i know i would.
I'm doing my first small block rebuild this summer.
Those 406's and 572s are nice but i wouldn't have the slightest idea were to start. LOL
Lot's of serious engine builders on this thread/site!
I love stock!
Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine)
For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL
beebster is offline   Reply With Quote
Old 07-04-2010, 08:49 AM   #197
eagleuh1
eagleuh1's Avatar
The Alien, you got an air cleaner hooked up yet. Been thinking about using the stock intake tubing myself. I can't get the engine driven fan on with the rad hose where its at, and can't use the stock 5.3 upper rad hose with the intake tube i have on now. Also, how'd you go to the larger hose end on the upper radiator on drivers side. You'll really like how the truck runs with the Vortec in it. I know I do.
Old 07-04-2010, 09:56 AM   #198
k5hart
k5hart's Avatar
The little 350 in my Blazer.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 07-04-2010, 10:50 AM   #199
Thealien
Thealien's Avatar
Just using a 4" K&N on the factory intake tubing for now. I am awaiting a small bend to adapt something a little different. Eventually I will move the battery to the drivers side and I will try and use the stock airbox.
I had a local radiator shop change the inlet and outlet to the correct size and added a steam port so I could use the factory radiator hoses.
My clutch fan hits the shroud if I put even the slightest pressure on it. I may have a solution but don't want to say anything until I try it out.
I had a troublesome lean bank 1 code that nobody could diagnose. Most thought intake leak so we smoked the motor. Even with about 10 lbs there was no leak. Another tuner suggested an O2 sensor and there were some eratic O2 readings so I replaced it and still lean bank 1 **&^^%$$##%^&!! The local tuner said cylinders 1 & 3 were not firing. We were getting spark and an injector pulse. He was thinking an obstruction in the intake (maybe a rag or tape left on?). I replaced 2 of the injectors at the 1 & 3 location and this is what they looked like
They are pretty nasty inside also. I am going to replace the other 6 with the rest of the ones I got on ebay that look new and only have about 100 miles on them. Even with the two bad cylinders (and the other 6 can't be at 100%) it ran better than it ever has. Yesterday I drove it for about 50-60 miles after replacing those 2 injectors and it does drive nice. Plenty of power, sounds good, cruises at 80 at about 2500 RPMs.
If you have any other questions might want to PM after posting as I don't always go back to some threads and might miss it.
Old 07-05-2010, 09:28 PM   #200
Rafael505
Rafael505's Avatar
Motors not done yet.....
Check out my Photos
http://67-72chevytrucks.com/gallery/...ry.php?cat=769
L.L. N.M.
63 chevy c-10
67 chevy c-10
71 chevy Blazer 4x4
Rafael505 is offline   Reply With Quote
