#26 | |
On a budget like Fred Sanford
Re: Which one is better? SBC 406 or 434?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
#27 |
I hate to say it but, I TOLD YOU SO. those probably flow as good as my 308 darts.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
#28 |
Champagne Taste on Beer Budget
I just bought a pair of Skip White aluminum heads, those are the ones I heard horror stories about. But these are SUPPOSE to be the revised versions and hopefully there are no more problems with these heads.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT Also bought some cool looking valve covers to go with them! http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT So I am excited to see how all this will perform in my 350. And later swap it out to a SBC 406 engine.
Coming Soon: Project 1970 Country Truck |
#29 |
[QUOTE=C20-67_N_MO;4090196]I just bought a pair of Skip White aluminum heads, those are the ones I heard horror stories about. But these are SUPPOSE to be the revised versions and hopefully there are no more problems with these heads.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT I like how the company basicalls said that those heads dont work past 510 lift and acted like they are just for medioker builds. Good luck but after reading their product description, i would think twice.
#30 | ||
[quote=ripdog28;4091094]
#31 |
I misread one thing but 488/510 lift was in their post. BUT, why does their flow number comparison say one flow # yet lower in their post of the head components it has a lower flow number? IMO, something updated from 2008 is not a new updated thing. THE BIGGEST KICKER, Why do they have .550 lift springs yet they show a flow chart with .600 and .700 lift numbers? They have too much info that comflicts if you read it more.
Also, why does every other Alum head company charge 2x what this company does? not just workers pay, possibly quality?
#32 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Chevrolet 406 Big Block - The Impersonator
Big-Block Torque In A Small-Block Package From the June, 2003 issue of Chevy High Performance: http://www.chevyhiperformance.com/te...que/index.html 434 Stroker Build - W-Engine Revival - Part Two Transform That Tired 348 Into A Tire-Smoker From the August, 2009 issue of Chevy High Performance: http://www.chevyhiperformance.com/te...ild/index.html
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#33 | |
For the money these are descent heads. Sure they are not AFR's but I just can't afford those right now either. Should work fine on my application under I get the bug for more horsepower. ![]()
Coming Soon: Project 1970 Country Truck Last edited by C20-67_N_MO; 07-16-2010 at 02:16 PM. |
#34 |
Registered Truck Offender
holee crap me too swb (ROTF,,, I just caught it) ,, talk about big ol pfhat fingers and blind! how about 245cc not 345. Someone bit*h slap me whan I do that will ya!!!!!!!!!!!!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#35 |
They still flow like big dogs. all that matters.
#36 |
Not trying to hikack the thread, but Ripdog are you running slicks and hooking up. I'm curious to know how the Detroit locker is holding up to that much torque. I'm changing my truck around some and will be throwing 660hp/580tq at a 9" with Detroit locker with a transbrake launch (was stalling the converter dead at the torque peak, but we'll see where it flashes with the new combination)
I've got a stupid amount of rubber on the back and could make the thing dead-hook with 500HP, but opted to take a little hit out of the 4-link and be easier on the old TH350, mild steel shaft etc. It's a Dyneer "No-Spin" Detroit locker w/ 33 spline Dutchman axles. I'm just unsure of what the locker is going to tolerate. If you've been launching a with the torque listed in your siggy,, I should be OK. Still going to drive this thing on the street is the only reason I'm not dumping the locker for a spool.
#37 |
Mean Green
C20-67_N_MO
Have you looked @ what a warmed over set of Vortech heads flow compared to the heads you bought. Just asking. A friend and I built a 6" rod 406 sbc solid tappet motor W/ the VT heads for his dads 63 short box and that thing was a bruiser. It would click off high 12.70's every time at the track. To keep the cost down a little trick you can do is drill the rocker arm studs and bosses and press in roll pins. Marv I'm so jealous of your heads. Those make my AFR 227s look amateur.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
#38 | |
![]() Quote:
Got Vortech heads and intake on my truck right now. So with this set I just bought hoping it will perform better than whats on it currently. Also have a flat tappet .488/.510 hyd. cam I am running with a two-plane intake and the same Holley carb that is currently on the vehicle. Just going to play with this setup before building up a nice 406 setup. I've heard they make some VERY high torque, very close to BBC numbers. So I can't wait to find that out even though it will be a while for that to happen.
#39 |
Mean Green
Nice. Don't let any one talk you out of building a 406 6" rod motor. They will run great for street and strip.
Here are some of the cast numbers to look for, these are 4 bolt and 2 bolt hi nickel blocks. 817,511,509. Marv is dead on as always on the spayed 4 bolt set up on the money spent for the caps and machine work compared to the aftermarket Motown or Dart blocks. The stock blocks are only going to be as good as the machine work. Make sure you have deck plugs put in the block. This will help with cylinder wall strength. If a guy wants to get a little radical he can also block fill up to the bottom of the freeze plugs. If this is done you should run a synthetic oil. The synthetic oil has a higher operating temp rang. Remember that none of us are rich$$$$. So if we have to save a little more and build it a little more bad ass it going to cost less money down the road. Enough is never enough. We always want more.
#40 | |
For whatever reason I was told to use the 5.7" rods for this setup. Yeah I had a nice 509 casting block but had to do some trading and let it go. But I am looking forward to building one after I trash this 350 thats in my '72 right now. lol
#41 |
![]() ![]() ![]() NC--1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block 1Bad62Pro/Street http://67-72chevytrucks.com/vboard/s...d.php?t=408630
#42 | |
Dunno if he answered you yet or not Marv, but I ran a detroit locker in my camaro for 2 seasons. It's a clutch car, 3900lb race weight (I know) and makes ~650-700rwhp on the jug. Left on the 2-step at 6500-7000rpm and it never skipped a beat. Put in a spool this year when I narrowed the 9" and the locker looked new still when I pulled it. I don't think you'll have any problems. ![]()
#43 | |
I sent Marv a PM but Currie Ent told me they are good for 800+hp when i bought mine.
#44 |
mini truck racer
I will be going Detroit locker also so this is good info .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 07-20-2010 at 12:57 PM. |
