Old 07-14-2010, 11:38 AM   #51
BGRAFX
Re: Project 91 Bsquared
The sun hit the sidewall just right to take a pic of the indy 500 logo on my firestone Firehawk 235/70R15 tires
BGRAFX is offline   Reply With Quote
Old 07-14-2010, 11:39 AM   #52
justpball
justpball's Avatar
Cool!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 07-14-2010, 02:03 PM   #53
BGRAFX
Hey is there a website where I can find out what a code means? I did the dianostic on my burb and got code 33 MAF/MAP sensor too high and code 43 Electronic Spark Control Failure
Old 07-14-2010, 03:45 PM   #54
Dropped84GMC
Dropped84GMC's Avatar
dug around alittle bit... found this hope it helps http://www.gmtuners.com/OBD1_DTC.htm
1984 GMC 1500 2WD
Big plans in the making
Dropped84GMC is offline   Reply With Quote
Old 07-17-2010, 10:35 AM   #55
scotts62
One day...
scotts62's Avatar
Well you get it running better?
Scott
93 crew cab build
Project 62
Old 07-17-2010, 10:43 AM   #56
BGRAFX
No! Matter of fact lastnight we had monsoon type storm blow through kansas city and I ran out to roll up my windows. I only got them halfway up then I lost power. I covered the windows with trashbags and waited 2hrs for the storm to move on.
Then I went back out and tried to get power back again, when I turn the key over nothing happens. So I thought maybe dead battery. I tried to jump it and got nothing.
I remember the Previous Owner saying he was having trouble with blown "fusas" so I'm on my way to auto parts to get fuses and battery tested. Also get some sensors and I will change spark plugs and wires today. I will let ya know how it goes.
Old 07-17-2010, 10:45 AM   #57
scotts62
One day...
scotts62's Avatar
darn the luck!
Cool hope all goes good.
Scott
93 crew cab build
Project 62
Old 07-17-2010, 10:58 AM   #58
RandyP
Getting Old; Going Broke
RandyP's Avatar
That'd be the same storm that rolled through here I bet yesterday evening. I forgot I left my windows cracked a little on my 05 due to the heat. I have vent visors but I guess the wind was blowing the rain hard enough that my seats got a little wet. As long as I don't get a musty smell it'll dry up by noon today and all will be good.
RandyP is offline   Reply With Quote
Old 07-17-2010, 03:04 PM   #59
JohnC
JohnC's Avatar
The battery may be causing some of the codes as well. If it's not putting out enough juice it could be affecting how the sensors are reading things. Just my guess. I don't know that for sure.
JohnC is offline   Reply With Quote
Old 07-17-2010, 03:24 PM   #60
BGRAFX
I check the battery and its ready correct voltage. I just finished changing spark plugs and wires. Its about 100* outside. But I'm determined to get it running.
Old 07-17-2010, 03:34 PM   #61
JohnC
JohnC's Avatar
Dang man it's so hot your camera can't get all the colors!
Old 07-17-2010, 03:59 PM   #62
BGRAFX
Hahahaha that's my girl iphone picture features.
Thanks to Joe for setting me straight on where my vacuum hoses were supposed to go.
Old 07-17-2010, 09:35 PM   #63
BGRAFX
Which wire is it?
Old 07-17-2010, 10:02 PM   #64
RandyP
RandyP's Avatar
I hope Joe can get you all hooked up on photos. I'm down here at the shop now (working in the night trying to beat the temps) and looking at my burb. It's basically worthless for photos that you need since we got the top of the engine torn down, front end off, no core support etc. I have a cluster of wires and hoses just laying there more or less.
Old 07-17-2010, 10:17 PM   #65
BGRAFX
Thanks Randy actually that picture somewhat helps with those wires and hoses on the firewall.
Old 07-18-2010, 12:08 AM   #66
RandyP
RandyP's Avatar
Well, film is cheap these days. Maybe some closer ones will do you some good. If not, smile and think "glad that is not mine!"
Old 07-18-2010, 12:37 PM   #67
JohnC
JohnC's Avatar
Originally Posted by BGRAFX View Post
Which wire is it?
Cut the RED one, no wait the BLACK one, no wait......
Old 07-18-2010, 01:07 PM   #68
RandyP
RandyP's Avatar
reminds me of....
Old 07-18-2010, 03:18 PM   #69
JohnC
JohnC's Avatar
That's awesome!
Old 07-19-2010, 07:21 AM   #70
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 07-21-2010, 02:26 PM   #71
BGRAFX
It finally stopped raining and my buddy came over to help out, apparently the previous owner paid a mechanic to "fix wiring" from the starter to the ecm. But after closer investigation all he got for $300 was some electrical tape on bad wiring job. So I've got the starter out and going to rewire some of the misc feeds that are coming off the main harness etc. The fusible link cable had a big chunk missing which maybe the cause of why I wasn't getting much power to my accessories. Only time will tell.
Old 07-21-2010, 02:38 PM   #72
RandyP
RandyP's Avatar
Wow, almost sounds like you're under the hood of my burb! Except its PO told me about it and told me what he did to "make it start". Basically involved some wire cutters, electrical tape, removing the fuseable links (starter and firewall) and jumping wires together here and there.
To be safe, I always undid the battery when I'd park it.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
Old 07-21-2010, 02:40 PM   #73
87 chevy silverado
is that y u have a bag over the back window?btw the burb is looking good
87 chevy silverado is offline   Reply With Quote
Old 07-21-2010, 02:47 PM   #74
BGRAFX
It actually scare the **** outta me, I was under the burb pulling on wires trying to see where they went and the starter arced and turned over. The key wasn't even in the ignition!
The previous owner did give me the receipts from his shade tree "machanic" but they say $160 to fix bare wires. Then 5days later he had it towed to the same mechanic and they charged him $120 to trace and repair wrong wires from battery to ecm. All they did was put some electrical tape on the wire from the starter and disconnect the fusible link.
You guys know how it goes, if ya want something done right, best to do it yourself.
I will be happy when my power windows and locks work properly again. The trash bag method worked well the past couple of days to keep all the rain out.
Old 07-21-2010, 03:13 PM   #75
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
This was also what was done to the wiring on my Dooley the wire from the alternator to starter had 8 of these conecters on less a foot of wire
every thing was hacked togther
thank god im a genuis with wirings
not allways true
i have seen alot of redneck stuff that has been plain an simple wrong
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
