Old 08-15-2010, 10:31 PM   #26
higgiec10
higgiec10's Avatar
Re: My 86 build
good looking truck man like the ling bed
higgiec10 is offline   Reply With Quote
Old 08-16-2010, 04:58 PM   #27
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
Originally Posted by gmclowsierra View Post
nice job on the dash how exactly did you do it. did you use fleece or did you use the chop mat?
Thanks....I used a woven fiberglass cloth, I think it's used for boat repair, came in like a 4x6 sheet, about $35. I tried the fiberglass mat, too hard to keep lying flat always wanted to clump up when brushing on the resin. The weaved mat stayed flat and flowed with the contours of the dash, and soaked up the resin easily... It almost looked like it was carbon fiber when I was done. I even thought of painting it faux carbon fiber......
mooseknuckles is offline   Reply With Quote
Old 08-16-2010, 05:02 PM   #28
mooseknuckles
Re: My 86 build
Thanks.....
Old 08-17-2010, 07:33 AM   #29
OLDIRON69
Re: My 86 build
Dash is sweet for sure. My Charger dash is cracked..never thought about glass. Will see how it goes.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-17-2010, 09:38 PM   #30
mooseknuckles
Re: My 86 build
Yeah..I'm glad I did it now, it wasn't too hard to do just took some time, and I had lots of that... I have a little over $100 bucks in it, and well worth it IMO. It should look even better when painted.....My buddys charger's dash is probably in the same shape as yours. I'll likely end up doing it for him, it will be easy its only a small strip across the top
Old 08-18-2010, 08:00 AM   #31
OLDIRON69
Re: My 86 build
With all the talk of the square body gauge pillar's you could mold your gauges in your dash..??
05 2500HD 6.0 excab
Old 08-18-2010, 09:23 AM   #32
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: My 86 build
looking good
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-18-2010, 11:51 AM   #33
palposity
palposity's Avatar
Re: My 86 build
Wow! Awesome job on that dash!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 08-18-2010, 04:53 PM   #34
mooseknuckles
Re: My 86 build
I thought about molding some pods in the dash for air guages and such, but I think i'm goin with the smoothed look.
Old 08-18-2010, 04:57 PM   #35
mooseknuckles
Re: My 86 build
Thanks....it stll needs some work tho....
Old 08-18-2010, 08:10 PM   #36
SS Delux
SS Delux's Avatar
Re: My 86 build
How much did you lower it the first time around? or did you go straight to bags ? I am running the same rims and i think mine looks a bit too tall. Where in ontario are you located ? cant wait to see it with the new rims.
SS Delux is offline   Reply With Quote
Old 08-18-2010, 08:26 PM   #37
mooseknuckles
Re: My 86 build
I did the flip in the back, 3" drop spindles and cut the coils in the front. I think I cut a full coil off. that gave me roughly a 4.5/6" drop. I knew I wanted to bag it anyway so I wasn't about to waste money on lowering coils....I live in a little ****hole town west of Ottawa....Yeah I can't wait either 2-3 more weeks hopefully and they will be here
Old 08-19-2010, 04:37 PM   #38
bctom
Re: My 86 build
" trying to paint a cat. "
That cracks me up. Truck looks good, nice tail gate work too. On the dash did you just scratch up the vinyl or did you go down to the foam padding before adding the cloth and resin? You may have developed the last fix for these cracked dashes.
I'm originally from southern Ontario, (now in BC). I have to admire anyone that takes on rust in Ontario.
Currently looking here for a short wide 4x4 driver, most here are flogged pretty hard in the mud.
bctom is offline   Reply With Quote
Old 08-19-2010, 05:24 PM   #39
mooseknuckles
Re: My 86 build
Thanks bro....no I left the vinyl on and just roughed it up with the sander to give the resin some bite....well It worked for me, no way I was paying that much money for a new dashpad, and the cheaper ones are just that...cheap!
Old 08-19-2010, 10:08 PM   #40
mooseknuckles
Re: My 86 build
Originally Posted by mooseknuckles View Post
Just got word today that my wheels will be 4-6 weeks from now.Turns out the order was missplaced. It took two weeks to find this out?....oh well more time to save $$.
....thinking of going with nitto nt555's 295/45/zr18 and 245/45/zr18 just wondering if the 45 series is "too" low profile....i like a bit of sidewall!
Old 08-19-2010, 10:15 PM   #41
mooseknuckles
Re: My 86 build
I had plans to work on my truck this weekend, but i'm being kidnapped and forced to go to "mopar-fest" against my will!...maybe get somethin done sunday.
Old 08-22-2010, 03:12 PM   #42
mooseknuckles
Re: My 86 build
I survived moparfest....lots of cool cars tho....got some looks at some tires, and some connections for ls1 swap!...at a dodge show, who knew?
Old 08-22-2010, 04:15 PM   #43
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: My 86 build
I had thought bout glass'n my dash, after see'n yours I'm definatly go'n to now. the tail looks good too ! good job on all of it !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-22-2010, 04:41 PM   #44
SevenSeries
Re: My 86 build
Hey man, what did you do for the cracks on the dash? Mine pop up like hell, did you sand it all flat then do it? Just curious cause this looks WAY better then buying a stock looking one.
With enough time and money, you can do anything
Quoted from my father
1976 C-10 Project
SevenSeries is offline   Reply With Quote
Old 08-22-2010, 05:14 PM   #45
mooseknuckles
Re: My 86 build
I just broke off piece's of the vinyl till the dash was somewhat level around the cracks and just roughed up the surface to make the resin stick, and wiped everything with wax and grease remover. The speaker holes were all busted out so I covered them up with some aluminum tape, and where the trim piece was, I cut a piece of cardboard to fit in the opening and taped it in. I also made piece to fit where the VIN number opening is to make the defrost vents look the same and save some work.
Old 08-22-2010, 05:23 PM   #46
mooseknuckles
Re: My 86 build
Thanks....I definately recommend trying it!...like I said I had nothing to loose, my dash was cracked and split, and a replacement was too expensive and this way it gives it a custom look.
Old 08-22-2010, 05:29 PM   #47
mooseknuckles
Re: My 86 build
I can't take all the credit, This is where I got the idea from....
Old 08-23-2010, 03:07 AM   #48
nightglide
nightglide's Avatar
Re: My 86 build
Somebody needs to do a how-to on fiberglassing the dash!
nightglide is offline   Reply With Quote
Old 08-23-2010, 06:56 PM   #49
mooseknuckles
Re: My 86 build
.......wish that I would've taken more pics when I was doing it.
Old 08-23-2010, 06:59 PM   #50
silvereagle07
silvereagle07's Avatar
Re: My 86 build
That looks sweet! I like the dash. How long did it take?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
