08-17-2010, 12:20 AM | #1 |
LS Swap Guys- In Here Please!
Anyone added up how much they were into the swap not including the engine and trans? I'm wondering how much it would cost with all the odd and end parts to do the swap. Mounts, wiring harness, etc.
Thanks, Anthony
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 |
08-17-2010, 11:31 AM | #2 |
Re: LS Swap Guys- In Here Please!
All together I guess mine would be around $800. without the eng and trans. I replaced some other parts not related to the eng swap though ( brake lines, prop valve, wiring harness, etc.).
I also had a bad motor to deal with too, so I had to pull and replace once too.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-17-2010, 11:51 AM | #3 |
I'm ballparking around $3500 for mine, not including engine and trans. But I am going with an aftermarket ECM and harness that includes a DBW pedal that runs about $1800. My headers will be around $600 and my mounts will run around $500. And my drive shaft will be around $600. And I'm not sure what my shifter linkage will cost.
Smoke Tires, not Drugs |
08-17-2010, 10:02 PM | #4 |
Addicted to Rust
Looks like about 32-3500 on mine thats projected. I have spent 28 so far and am not quite done. That include the engine and trans. I still have to shorten the driveshaft,run exhaust. I am sure that there will be some other assorted items left to buy.
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
08-27-2010, 01:36 PM | #5 |
Formerly- 1972SuperCheyenne
Not including the 6.0/4l80e (which I bartered for!) I have $500 in mine for the harness. But even that was overcome by selling parts I removed to do the swap in the first place! It's the rest of the frame off I'm doing thats killing me.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-27-2010, 04:47 PM | #6 |
Carbed 5.3L in a '50 chevy, could use the same parts for a later truck. Not including trans stuff.
5.3L Engine $400 Accessories $200 MSD 6010 $300 Demon Carb $250 Intake $270 Mounts $90 Headers $200 Fittings $40 Fuel pump $100 PS Hoses $40 Rad Hoses $40 Other Crap $100 Total $2030 Pretty cheap for 300+ RELIABLE, Leak-free ponies.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
08-29-2010, 10:50 PM | #7 |
GM ONLY BABY!!!
I'm afraid too!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
08-29-2010, 11:51 PM | #8 |
Truck and auto performance nut
I never plan on selling the truck...so I didn't keep track, partially because I didn't want to know either!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-30-2010, 01:55 AM | #9 |
You can do it the more inexpensive stock way, or you can do it the more stupid radical way..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-30-2010, 06:33 AM | #10 |
I purchased the truck with no motor for 2500, 5.3 w/ all the accessories and wiring harness was 850, misc parts probably another 750-1000, I did all the rewiring of the harness myself to save some money, I also already own HP Tuners for my other car, so I can do all my own tuning as well. All together I should get out of it for just under 5k including the cost of the truck!
08-30-2010, 10:07 AM | #11 | |
I don't think everyone wants to go with used (non-rebuilt-as pulled) equipment. I know I didn't.
08-30-2010, 10:27 AM | #12 |
Judging by his signature, I think he's ribbing himself for blowing all his dime on engines I don't think he meant that as a knock to built LSx engines.
08-30-2010, 01:27 PM | #13 | |
Right.. But I'm in the really stupid catagory now.. The little forged 347 had me in the stupid catagory, but obviously moved the truck well and I didn't even use the second stage. But now there is a 418 ci motor with AFR 225 heads waiting to go in. That put's me in the really stupid catagory.. Most the swaps you will see will be mild in comparisson to what I have in mine. Most will be a stock rebuild if any at all, retaining factory pistons/rods and maybe a rering/bearing job and stock tq converter with maybe a 3.73 gear. They might go with a mild 224ish cam, again retaining stock heads and intake. Mine in comparison has ported heads, 243/250 .610/.612 lift cam, Super Victor with a dominator throttle body, 4500 rpm verter and 4.56 gears. The new motor is even worse and is most likely going to make me change the verter and gear set to optimize the new combo.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 08-30-2010 at 01:32 PM. |
08-30-2010, 02:52 PM | #14 |
Super, you can't be that stupid, I have done that to my daily driver!!
How many people do you know that drive a faceplated tranny to work everyday...... |
08-30-2010, 09:13 PM | #15 |
I was curious where he was going with that. Guess I'm stupid too.
well my cams not too far off that mark lift wise, but short on duration....223/231 @.050 - .610/.617 - 112LSA. Since your trucks not much different weight wise (stock) and I'm guessing you've had lots of runs with it....with a new 6.0L w/L92 heads, cam listed above w/patriot gold spring kit, GMPP LSX d/p intake and 750 Street HP carb, 200-4r, 2500rpm stall, 3.73's, and some 315/60-15 MT ET streets (not sure of headers yet)...care to make a 1/4mi. prediction? HP has been estimated at 500+hp... but have been told not to be surprised if I see closer to 550-600hp. Hoping for some high 11's ...but I'll take low 12's.
08-30-2010, 09:31 PM | #16 |
With 3.73's that exact tire and my 4,500rpm verter, I went 11.96@113mph with a 1.67 60' running the 347ci 11-1 motor with the mentioned cam and intake at 3800lbs (including me). You should have a bit more bottome end TQ, but that verter might slow things down a bit. I think you'll be close to your goals.
08-30-2010, 10:42 PM | #17 |
Thanks for your thoughts. I figured I might as well start with a dual plane and lower stall converter for the street...until I start dialing it in and getting more involved in taking it to the track. The plan has always been to drive it there and back, so I'll be beefing up things as I make it faster. I will say tho that for a dual plane intake....its certainly a high rise, or at least the tallest I've seen.
08-31-2010, 06:59 AM | #18 |
I know it is not a truck, but you guys have me beat in the weight department. It might give you an idea of what to expect once you get her together. To give you some more of an idea, my car weighs 3995 with me in it, i run a 26" slick with a faceplated t56 trans. The motor is a stock bottom end ls2 with a 232/234 cam .598 lift i/e, kooks headers, and a FAST intake, the motor made 434hp/404tq at the wheels, on motor the car went 11.71 @ 115mph, on a 50shot it has gone a best of 11.31 @118 and on a 100 shot with the clutch slipping in 4th it went 11.18 at 122. It has gone 126 before but without the 60' to back it up.
