Old 09-04-2010, 06:34 PM   #1
FL71C10
Did they make 3/4 ton shortbeds
Does anyone know if they made 3/4 ton shortbeds? Thinking of buying a decent 3/4 ton longbed truck for $1500 but I really want a shortbed. I thought I could shorten the frame and install a short bed on it down the road.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 09-04-2010, 06:35 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Did they make 3/4 ton shortbeds
no
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-04-2010, 06:46 PM   #3
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Did they make 3/4 ton shortbeds
no but that would be *****en !!
QKENUF4U is offline   Reply With Quote
Old 09-04-2010, 06:56 PM   #4
Pop's C-10
Pop's C-10's Avatar
I agree
Pop's C-10 is offline   Reply With Quote
Old 09-04-2010, 07:03 PM   #5
vectorit
What?
vectorit's Avatar
I am thinking about doing that to a 1970 SWB K10.
I prefer a full floater over a 6 lug 12 bolt any day.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-04-2010, 07:07 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Does this mean you bought it?
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-04-2010, 07:16 PM   #7
vectorit
What?
vectorit's Avatar
Bought what? I know nothing of what you say bought it?
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 09-04-2010, 07:59 PM   #8
FL71C10
So a short bed 3/4 ton wouldn't be strange? I suppose I could put a 1/2 ton 5 lug front and rear suspension in it. Are the frames the same?
Old 09-04-2010, 09:00 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Early Classic Enterprises has done 8-lug to 5-lug conversions, and sell what it takes to make it happen (or they used to).
As far as making a short bed chassis out of a long bed chassis, there's a bunch of those on the road or under construction. Basically, it just means you take 12 inches out of the chassis, between the back of the cab and the rear axle.
Member Nr. 2770
Old 09-04-2010, 09:45 PM   #10
capev86
why do you want to build a 1/2 ton short bed? they made plenty of those. i thought this thread was about a 3/4 ton short bed? if i had a good C20 long bed i'd probably leave it alone, but if was buying a bunch of parts i'd love to put together a SWB C20 just like the factory "would have done it."
capev86 is offline   Reply With Quote
Old 09-04-2010, 10:17 PM   #11
72lb4x4
I know where there's a shortbed that's had the front wheels off for a few years while it sits in the driveway on jackstands. Its not mine, shows no signs of being for sale, and its a bit of a ride from FL. I just wish they'd fix it so I don't have to be sad for it as I drive by on the way to the Lowes/HD...
72lb4x4 is offline   Reply With Quote
Old 09-04-2010, 11:35 PM   #12
Boyd
Resident Lurker
Boyd's Avatar
In the early 90's I built a 3/4 ton short bed. Basically, I shortened a '72 lwb 3/4 ton, bolted on a set of 8 lug 16.5" chrome wagon wheels with 31x10.50 tires on all 4 corners. I loved that truck. Sold it to help pay for a move.
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252
"Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken
Boyd is offline   Reply With Quote
Old 09-04-2010, 11:44 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not long before I bought my K20 in 1977, I looked at a beautiful powder blue & white private-party '71 or '72 SWB 4x4 with 8-lugs -- I never knew they didn't exist, and it was above my price range anyway. Knowing what I do now, I sometimes wish I would have stretched the budget and bought it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-05-2010, 12:13 AM   #14
Notrodder
Save yourself the trouble and buy a truck that suits your needs in the first place. You'll have enough to do with maintainance and repairs without having to hunt down and replace things that you could have bought originally.
Notrodder is offline   Reply With Quote
Old 03-14-2011, 11:12 PM   #15
foxchevy
I just bought a 3/4 ton shortbed 1984 chevy truck. GM did make them, they were special order. Go figure, I looked up the numbers and bam! THey match. IT rides a little stiffer than a 1/2 tom truck but pulls like a 3/4ton.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
foxchevy is offline   Reply With Quote
Old 03-14-2011, 11:32 PM   #16
Rooster's 67
Rooster's 67's Avatar
Foxchevy, they did not produce a 3/4 ton Short wheel base in the 67-72 body. But might have been available in the square bodies
And welcome to the board
Last edited by Rooster's 67; 03-16-2011 at 12:34 AM. Reason: i can't use spell check before hitting submit
Rooster's 67 is offline   Reply With Quote
Old 03-15-2011, 06:53 AM   #17
Blazer1970
Blazer1970's Avatar
They did not build 3/4 ton short beds in the '73 - '87 body style either.
Blazer1970 is offline   Reply With Quote
Old 03-15-2011, 07:57 AM   #18
x2. I hear people say they did but they are misled. There were no 8-lug shortbed square bodies or 67-72s. There has always been a heavy duty spring option and at some point in the '70s GM started calling 10-series with this option "Heavy Half" and some started calling them 5/8t,still not a 3/4t (nor 5/8t). They never called a 3/4t with HD spring option "Heavy Three Quarters" or 1t...nor 7/8t,for that matter.
I've never known of a 60-66 SWB 3/4t except for 4wd Panels. I have known of SWB 3/4t pickups in the 55-59s. The one my friend had had 8-lug 15" split rims
Old 03-15-2011, 08:04 AM   #19
no moa
no moa's Avatar
Guy up here did that, shortened the frame and used a 90 stepside bed. It looks really cool with the 8 lug wheels. The cab still has the c20 badges on it.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-15-2011, 11:23 AM   #20
shaneschevys
Its always something!
shaneschevys's Avatar
I had a friend of mine shorten a 3/4 ton for me. It was a 72 with a 402/th400.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 03-15-2011, 04:07 PM   #21
kwmech
I've built a couple of them myself. I kept breaking axle shafts and had a problem stopping the truck until I went with a full floater and 13'' drums.
Old 03-15-2011, 06:54 PM   #22
haysonj
haysonj's Avatar
Heres one that has not been shortened, Started with a 69 CST short bed and added a 72 3/4 ton dana 44 in the front and a 73 14 bolt in the rear. T400 and a Gear Vendors OD
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 03-15-2011, 07:09 PM   #23
John Fabris
TOTY 2006
John Fabris's Avatar
?? Did you build the frame? that looks like a blazer wheelbase? That is not a factory short wheelbase frame when looking at the pictures...
As for wanting to end up with a 4x4 3/4T shorty, yes, you can do this by either getting a 1/2 4x4 and add 3/4 ton running gear, or getting a 3/4 ton 4x4 long bed and shortening the frame to short bed. Lots of threads here on others that have shorten. Like said before, you have to section the frame in front of and behind the the rear wheels.
good luck in your search, and we will be here to help you along with your project!!
John
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 03-15-2011, 07:11 PM   #24
lakeroadster
Here are cut sheets for a '67.
C10 shows long and short bed wheelbases:
C20 is only long wheelbase:
lakeroadster is offline   Reply With Quote
Old 03-15-2011, 10:05 PM   #25
treveiger
treveiger's Avatar
Monday night i was thinking if my truck ever got into a accedent and part of the frame was shot id take my 3/4 ton frame and shorten it and make a 3/4 swb. and keep everything else a 3/4ton truck.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
