Old 09-09-2010, 09:29 PM   #1
caviness
help on fuel tank
need to know what kind of fuel tanks will work the easyest and cheap if posible,shortbed truck one with fleetside and one with new model style bed if that makes a difference,was thinking about van or blazer or surb and going with external pump and filter,dont want to cut frame if possible but trimming is ok
caviness is offline   Reply With Quote
Old 09-09-2010, 10:18 PM   #2
gopokes
gopokes's Avatar
Re: help on fuel tank
I am using one out of a 99 Camaro. Got the idea from Ackattack's build thread, he used the same one. Has the internal fuel pump already in it. I picked mine up for $50. You do have to move the rear crossmember back and trim the bottom of the frame rails to get it to fit. I don't plan on ever towing with my truck so cutting the frame wasn't an issue for me. Here are some pics of it mocked up.
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224
gopokes is offline   Reply With Quote
Old 09-10-2010, 02:01 AM   #3
caviness
that looks like it hanges pretty low
Old 09-10-2010, 09:25 AM   #4
gopokes
gopokes's Avatar
I don't think it is any lower than the Blazer tanks. My frame is sitting on the axle right now, it is about 5 inches from the ground, but that won't be the ride height.
Old 09-10-2010, 09:41 AM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
What year of truck?
If that side view is the installed position of the Camaro tank, that is scary.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-10-2010, 12:16 PM   #6
gopokes
gopokes's Avatar
Originally Posted by glock35ipsc View Post
What year of truck?
My truck is a 71, that position is a couple inches lower than it will be when fully installed, it is just mocked up in that pic, and my bags are completely aired out, so it will be fine at ride height.
Old 09-10-2010, 02:29 PM   #7
glock35ipsc
I was asking the OP what year his truck is.
Bob
Old 09-10-2010, 10:48 PM   #8
caviness
one 67 and one 72
Old 09-11-2010, 10:38 AM   #9
glock35ipsc
The 25 and 31 gallon Blazer and Suburban tanks fit like a glove in the 67-72 frames, no frame trimming necessary. If you can find a used one from an 87-91, and you can run a factory pump in-tank, and it will have the sump that the pump sets in to keep fuel from sloshing away from the pickup.
A factory in-tank pump for that setup will run about $70.
I'm running 87 saddle tanks (with the sumps) and OE fuel pumps for my 5.3L.
Bob
Old 09-11-2010, 02:58 PM   #10
caviness
so i get a blazer or surb 87 to 91 and it will work,will i need to change the in tank pump or will it support 6.0,lookin to be stock motor on one and 400 to 500 on the other.also do u have any pics or sum links to them i havent found any yet,thanks.
Old 09-21-2010, 11:26 PM   #11
caviness
any more help,maybe sum pics would hep to,thanks.
2000 camaro SS,built
2006 GTO stock
1984 chevy 4x4
1967 chevy frame off rebuild under way,with 6.0,4l65e
1969 GMC 6.2 diesel th400 3:73 rear
