Old 09-12-2010, 03:54 PM   #51
53GMC
53GMC's Avatar
Re: Freddy's '52
love the dash and gauges....awesome work!
1953 GMC/S 10 Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=357365
53GMC is offline   Reply With Quote
Old 09-13-2010, 10:58 AM   #52
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Originally Posted by RootBeer 6117 View Post
Great lookin truck! Sorry off the subject but I was wondering if you could tell me what motor mounting brackets you used for your LT1? I want to mount mine in the same location,I don't know what happened to my original S10 transmission cross member, I am going to try to use the one for the throw out bearing and mount it in the same spot.Any help is greatly appreciated
Joe
I used the Trans Dap or Dept? s10 adapter mounts from Jegs. If I had to do over again I would use a aftermarket tranny cross-member cause I had to cut a channel for my exhaust on the drivers side. I also thought about using the throw out bearing mount.
1952ssr is offline   Reply With Quote
Old 09-15-2010, 10:23 AM   #53
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Well hinges went easier than I thought, I only had trouble with one and it was my fault. So, now doors are hung and man what a differance. Then I went crazy ..... I had to put it together "sort of" to see it. Here's an idea of what it's gonna look like. Probably the only thing to change is to find a used chrome grill and front bumper to add a little "rat bling".
Old 09-15-2010, 10:34 AM   #54
sdailey
The Few, The Proud
sdailey's Avatar
Re: Freddy's '52
That thing looks wicked buddy. Keep up the good work.
Shannon
sdailey is offline   Reply With Quote
Old 09-15-2010, 10:45 AM   #55
a5Ben
Re: Freddy's '52
Looks good Freddy, any info on that gas tank? I need to find a tank, maybe a blazer tank for my S10 project..... What straps did you use etc?
Thanks,
Ben
a5Ben is offline   Reply With Quote
Old 09-15-2010, 10:52 AM   #56
blitz'd
vintage car junkie
blitz'd's Avatar
Re: Freddy's '52
Are you running wheel spacers on the front?
1950 chevy truck, s10 swap, bagged, v8, 18s
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761
blitz'd is offline   Reply With Quote
Old 09-15-2010, 12:13 PM   #57
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Thanks,
Ben
Tank is from the '94 Z28 my LT1 came from. I wanted the complete "setup" so I knew fuel pressure would be right. Straps are basic stainless from ACE hardware. A blazer tank would have worked, alot depends on where your bed floor will sit. Here's a couple of pictures of my setup, the neck almost came out to far back to have the neck come out the fender.
Old 09-15-2010, 12:14 PM   #58
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Yes, running 2 1/2 inch
Old 09-19-2010, 02:43 PM   #59
56ClassicTruck
Re: Freddy's '52
Hey your truck is coming along really nice!!!! I toke a brake from mine to thing about it.. Good to see you are still at it nice..
1996 Dodge 3500 4x4
1977 F250 Camper specal 4x4
1956 Chevy 3100 truck
56ClassicTruck is offline   Reply With Quote
Old 09-19-2010, 10:20 PM   #60
solidaxel
solidaxel's Avatar
Re: Freddy's '52
Nice work !!
Did you fab the rear shackles or buy them?
Hpw much clearence will you have from the frame to the spring eye when the spring is defelected all the way?
Those look like I can get my truck 1" lower in the rear by simpley changing out the shackles!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-20-2010, 12:48 AM   #61
nomas54
Re: Freddy's '52
On the gauges all I can say is WOW that is what I hope to do to mine. Oh and by the way you truck looks great.
Robert
nomas54 is offline   Reply With Quote
Old 09-20-2010, 04:20 AM   #62
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Freddy's '52
Sweet looking Truck. Love the Patina!!
ChuckDriver is offline   Reply With Quote
Old 09-20-2010, 11:21 AM   #63
1952ssr
1952ssr's Avatar
Re: Freddy's '52
THANKS for ALL the comments guys.
Solidaxle, the shackles are stock S-10 chassis ones. Took the front clip back off and I got my front cowl patch panels placed Saturday now just need to weld them in place. For you guys doing S-swaps save as many of the c-clip nuts & bolts you can I have found they come in real handy putting the AD back together. If you'll notice the RF fender may look a little darker. I took acetone to that one cause I had spraybombed some primer on it, so I plan on doing the rest of truck. Plan to order window/door seal kit this week, got a 20% off discount coupon from Classic industries burning a hole in my pocket. Vacations coming up next week so maybe I can get some good things accomplished this week.
Old 09-20-2010, 03:17 PM   #64
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Freddy's '52
The truck is looking awesome!
Ryan
1969 Chevy milk truck
Old 09-20-2010, 05:58 PM   #65
BlueJeep
BlueJeep's Avatar
Re: Freddy's '52
Don't get too excited about that, I ordered that kit from them in March and I'm still waiting....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-21-2010, 09:47 AM   #66
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Are you serious!
I ordered the same item in March too... then money got tight so I cancelled it. I guess I would still be waiting.
Old 09-21-2010, 09:28 PM   #67
BlueJeep
BlueJeep's Avatar
Re: Freddy's '52
Are you serious!
Yep, the only reason I haven't cancelled it yet is because I haven't found anyone else with a "complete kit" like that that might have it in stock. Almost ready to start looking harder though...
What's the overall diameter of your tires and how high to the bottom of the running boards in front? Truck looks good!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 10-07-2010, 11:10 AM   #68
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Need HELP....can anyone tell or show me how to install the headlight trim rings. Thanks
Got a little work done, but no pictures. A/C compressor and Alt mounts for the LT1 are made, running boards matted to the rear fenders, gas filler in rear fender and steering column mounted to the cab. I love progress.
Old 10-07-2010, 12:37 PM   #69
52 Rat
52 Rat's Avatar
Re: Freddy's '52
Nice build project. It is good to see another 52 AD build. I need to update my project thread.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 10-07-2010, 04:56 PM   #70
1952ssr
1952ssr's Avatar
Re: Freddy's '52
What's the overall diameter of your tires and how high to the bottom of the running boards in front? Truck looks good![/QUOTE]
Not sure about the diameter, the size is 255-35-20 & 225-40-18. I know there is a site that figures that info for sizes but not sure the name. I measured the back and it was 5 1/2 - 6 inches front is maybe +/- 1/2 inch lower.
Old 10-07-2010, 07:04 PM   #71
RootBeer 6117
RootBeer 6117's Avatar
Re: Freddy's '52
Cool! I would love to know more about your a/c alt brackets.I got my LT1 on the frame today and got it to fire. A Kid standing next to the open manifold jumped a foot I wish I had video.
RootBeer 6117 is offline   Reply With Quote
Old 10-07-2010, 07:38 PM   #72
chev3600
chev3600's Avatar
Re: Freddy's '52
Concerning the tires, check out the tire size calculator at this site. The interface is great. Lots of sites will give measurements, but the overlay picture is a better visual. www.miata.net/garage/tirecalc.html
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 10-08-2010, 09:17 AM   #73
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Yep, that's the site i was thinking of. Thanks 3600
Old 10-08-2010, 09:24 AM   #74
1952ssr
1952ssr's Avatar
Re: Freddy's '52
Nothing fancy, I'm using the factory alternator rods and using 3/4 square tubing for the base mounting to the front of the head. Two pieces of tubing together is almost exactly the width of spacing needed, just a washer or two will dial it in perfectly. A/C rest at the drivers side right at the top of the header and valve cover. I put some pictures up Monday of what I did.
Did you go with an aftermarket wiring harness or us the existing one?
Old 10-08-2010, 05:26 PM   #75
RootBeer 6117
Re: Freddy's '52
52ssr
I have the factory wiring on it I have the entire cars harness laying on the frame right now, I will narrow it down. I teach Auto Tech class, the students are doing it.
I would love to see pictures of your brackets for the AC/ ALT, a picture is worth a thousand words. I had a photo copy of your engine to help me and the students decided were to put the engine on my frame. I love plain and simple I want to do as much with used parts and fabrication as I can
Thanks Joe
