Old 09-21-2010, 04:31 PM   #1
xs-style
xs-style's Avatar
73/74 grill swap
This topic is now an FAQ- "73/74 grill swap"
I just finished up this swap for my '78. Ive seen posts on the board where folks have told others how to do it, but Ive never seen a write up with photos before. That said, I figured Id go ahead and put one together. This should fit 75-79 trucks, and later models with older sheetmetal lol. Hope this helps someone along the way since this seems to be a popular swap right now.
To get started you need the 73/74 center support and two side supports.
I didnt take a pic of what the grill looked like originaly. If your truck started as anything like mine, you know what a chevy grill looks like when its missing about 20 teeth lol. Just remove the 8 screws holding that old busted up grill on and toss it aside. That will leave you looking at your center grill support. Heres a picture of the 75 and up grill support in my parts truck
Now this is the center support youll need from the 73/74 donor truck.
Swapping the center supports out was a pretty simple. 8 bolts and your done.
Heres the side support brackets (pic 1), the 73/74 grill (pic 2), and the side brackets attached to the grill
To mount the side supports youll need to drill four holes, two on each side. If you look just to the inside edge of the headlights, youll see Chevy provided dimples where the side brackets need to mount.
The pre-drill shot of the dimples didnt come out as well as I would have liked, but the after shot shows up better.
In my own case here I drilled the holes a little large, and used washers with my bolts. I figured my chances of getting it exactly right on the first try were slim to none. Doing it this way will allow me to adjust the gaps.
Heres an after picture with the grill installed.
Now your down to re assembling everthing and viewing the finished product.
As it turns out, Ive still got some adjusting to do. Im off about 1/4 inch to the left. I still need to make something up for the center mounts too. Aside from those little details the swap is done though. As it turns out this is probably one of the easiest things Ive done to the truck. Hope this helps someone along the way.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 09-21-2010, 04:33 PM   #2
xs-style
xs-style's Avatar
Re: 73/74 grill swap
This swap did leave me with one question. Ive asked this to a few 'chevy' guys that I know, and none of them could give me an answer. If those dimples where the side mounts bolt on were only necessary for the 73/74 side mounts, why did they carry them on into later years?
Events attended:
Spring GOG 2011
Old 09-21-2010, 05:21 PM   #3
S10Fan
Old Heap Driver
Probably so the same core support could be used for all year trucks?
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod.
S10Fan is offline   Reply With Quote
Old 09-21-2010, 06:50 PM   #4
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
so that replacement core supports can be offered from 73-80 i assume.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 09-21-2010, 08:36 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-21-2010, 10:58 PM   #6
xs-style
xs-style's Avatar
That would make sense. My thought process was that since that person, or piece of machinery was no longer needed, that it would be eliminated from the assembly process.
Events attended:
Spring GOG 2011
Old 09-21-2010, 11:06 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I love the 73-74 grill, so you know I dig the conversion. It looks to me like the gap around the trim is a bit wide. Anyone got a good pic of a 73-74 front end to compare?
BTW- What about the internal hood latch. Will this work alright with that?
Articles-
"Refining Sierra"
Old 09-21-2010, 11:19 PM   #8
Walts_restoration
hows two of them?
Old 09-21-2010, 11:23 PM   #9
Walts_restoration
My 73 cheyenne
I cannot find pics of my other trucks though. we have a green 73 white 74 and maybe another one or two i cant remember anymore haha.
Old 09-21-2010, 11:40 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
So maybe I am wrong but I still think the gap is a bit wider. According to LMC the trim is all the same, so maybe its just me.
Thanks for the pics.
Articles-
"Refining Sierra"
Old 09-21-2010, 11:49 PM   #11
Walts_restoration
his trim does look a little off to me n2trux, but i think its the headon style photo.
Old 09-22-2010, 10:38 AM   #12
xs-style
xs-style's Avatar
Ive not done the latch swap. I didnt need to with the external latch, but from what I can find on here changing them out isnt hard. You would still have the spot for an external latch on the grill though.
I noticed the gap too, but I figured there wasnt much to be done about it unless I got a grill stretcher
Events attended:
Spring GOG 2011
Old 09-22-2010, 12:26 PM   #13
bigblock73
yeller
bigblock73's Avatar
That gap is about right, looks like mine.
bigblock73 is offline   Reply With Quote
Old 09-22-2010, 01:23 PM   #14
c10sport
c10sport's Avatar
yes it does. I put a 1973 grille (also my fav, your truck would be my (future) truck's twin if you do it) in my 1978 K10 with an inside hood release.
Jay
2001 Pontiac Aztek GT
c10sport is offline   Reply With Quote
Old 09-22-2010, 01:27 PM   #15
Walts_restoration
How did your hood release work out with the 73-74 center? i am thinking about doing this to my 78 with inside release as well.
Old 09-22-2010, 01:39 PM   #16
c10sport
c10sport's Avatar
Perfect fit. Didn't bind up or hit the grille.
Jay
Old 09-22-2010, 06:03 PM   #17
jlmerie
jlmerie's Avatar
I really like that grille. Is the 73/74 grill being reproduced?
James
jlmerie is offline   Reply With Quote
Old 09-22-2010, 06:06 PM   #18
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
73' grill on a 77' front clip
Grande Rojo is offline   Reply With Quote
Old 09-22-2010, 09:33 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
You guys are tempting me to make some changes. Can't call them updates, maybe "upgrade" would be a better description.
Articles-
"Refining Sierra"
Old 09-22-2010, 10:01 PM   #20
c10sport
c10sport's Avatar
do eeeetttt!
Jay
Old 09-23-2010, 08:57 AM   #21
xs-style
xs-style's Avatar
I dunno.... I think your truck looks pretty good as is. Mine needed more help than most lol
Events attended:
Spring GOG 2011
Old 02-28-2011, 01:09 AM   #22
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thanks man! This write up was all i needed!
y5mgisi is offline   Reply With Quote
Old 02-28-2011, 02:52 AM   #23
KAC
KAC's Avatar
Hows this, its a better view to compare with.
1974 Chevy Shortbed Stepside
1985 Chevy SWB <--- My Donor Truck
1991 Ford F-150
2007 Pontiac G6 GT
2008 Dodge Grand Caravan
My Photo Album
'74 Round Eye Stepside Project
KAC is offline   Reply With Quote
Old 02-28-2011, 05:56 PM   #24
73gmc454
73gmc454's Avatar
Yep this was a easy swap,I did the same thing, as for the center mounts here is what I did , took the 73-4 mounts and cut the top about 2 1/2" down , then bent the mounting part down about 3" to meet up with the staight up style core support , added gussets in the void , heres a pic
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 02-28-2011, 06:16 PM   #25
73gmc454
73gmc454's Avatar
I should have added this was for a GMC, I'm also not sure if the GMC is different than the Chevy, I think that the chevy didnt have the bolt on brackets ,
