In-rad. trans cooler question
Being away from my trck right now, could anyone tell me whether the trans lines going into the radiator exit from the top or bottom? I'm trying to plan out a secondary external cooler
'72 cheyenne super step, '05 long bed gmc |
"the other guy"
Re: In-rad. trans cooler question
top is in and bottom is out
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
thank you sir
Also, do you know the fitting sizes?
I believe the fittings are 5/16 flare (1/2 - 20 thread). Someone correct me if I'm wrong.
Retired Navy 1972 C10 Cheyenne fleetside 350 sbc, 700r4, 3.42 rear |
I was worried when I saw the metal plate in the middle behind the grill shell (forgot that detail), but turns out there's plenty of room for a 40k gvw cooler on the back of the condenser and it makes the hose routing even cleaner. sweeet. SHould keep a 3k stall happy
'72 cheyenne super step, '05 long bed gmc Last edited by '72customdeluxe; 09-21-2010 at 10:51 PM. |
that is correct, I just had to order some
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
