Need help plz
i have a 71 c10 with power steering. my problem is that my power steering gearbox has gone out it leaks all the fuild out of it in a day i cant even drive it any more. so my question is can i put a newer model gearbox on it or do i have to seach though endless junkyards to try i find one. need help guys i want to keep this thing on the road. it doesnt deserve to sit and waste away. thanks for any help guys and gals.
71 c10 with a 305. new dd wohoo 1956 chevy bel air hard top with a 327. 1998 honda passport V6 old dd. |
Old member
Buy a rebuild kit for it. I have rebuilt mine and it holds up pretty good seeing it has over 300,000 on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Need help plz
Where would I get one and how much would it cost
Roadtrip!
![]() Join Date: Feb 2003
Re: Need help plz
I think the last one i bought was around $15-$20. Any parts store should have or can get one. I used to have to add to my 71 4x4 everytime i used it. Haven't added anything in a couple of years now since putting the kit in...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Need help plz
depending on what your time is worth, you can also just get a reman'd unit from parts store, right?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
Re: Need help plz
can any one give me a part # for a rebuild kit. im looking at some but im not sure if its what i want.
Re: Need help plz
I would check CCP, they have a close ratio or stock ratio box, i brought the close ratio one, i like it, been driving it for year,and has not leak yet, check out the web site www.classicperform.com.
Re: Need help plz
Re: Need help plz
You can remove the powersteering belt, and just loop the hoses together and drive it with out powersteering for a while. You just wont have power steering... I swapped a powersteering unit from a 1979 truck, it bolted right up.
Burnouts are therapeutic
Re: Need help plz
I just put a remanufactured one on my old car , I got it from o'rielly's for $40 with exchange. it was easy to do and hasn't leaked a drop since I put it on a couple months ago. it was pooring before. check there website, good luck ...... forgot to mention it comes with the reservoir all I had to do is put my pulley on it which you will need a pulley puller for.
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein Last edited by red69ss; 10-03-2010 at 01:27 PM. Reason: more info |
#11 | |
Re: Need help plz
Re: Need help plz
so what is confusing you?
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
Re: Need help plz
U said pull the pully off I don't need a new pump just the gear box. Can I buy just that from them.
Re: Need help plz
ok sorry, I misread your original post and thought you were talking about the PS pump . Yes looks like they have them also for $125 with your core. call them to verify, sorry for the confusion.
#15 |
Re: Need help plz
Its cool man thanks for the help
#16 |
Re: Need help plz
Advance Auto has the close ratio gear box for 124.99 and 20% off, and free shipping online. I put one on my truck last month, so far so good.
#17 |
Re: Need help plz
Wat do u mean by close gear. Like it takes less turns to go from full lock to full lock
#18 |
Re: Need help plz
3.5 turns lock to lock, verses 4.5 turns lock to lock.
#19 |
Re: Need help plz
Do u no the part number
#20 |
laying low
![]() Join Date: Mar 2001
Re: Need help plz
If your gear box doesn't have a lot of slop in it maybe try the seal kit first? I guess it only consists of an upper and lower shaft seal. Might need a puller to get the pitman arm off though.
This is something I need to do to mine also.
#21 |
Re: Need help plz
Part No. SG17501 Advance Auto parts web site. It does not say it is the 3.5. However I called their toll free number, they called Fenco and confirmed as 3.5. Installed and it is 3.5. Be sure to use a coupon, you can google advance auto coupons and find some good ones.
#22 |
Re: Need help plz
Alright thanks for the help
#23 |
Re: Need help plz
If it just leaking out the pitman arm shaft, thats a pretty cheap and easy fix. You can get just the pitman shaft seal for a couple of bucks. Pull the pitman arm off the shaft (leave it attached to the center link) remove the c clip that holds the seal /washer in place on the box, put the pitman arm back on snug, fill the p/s pump start the engine and turn it from lock to lock until the seal POPS and the fluid gushes. Remove pitman arm, washer and seal, clean and reinstall new parts. NOTE: this is a messy way of doing the job. but WAY faster that trying to dig that old seal out with a pick.
![]() ![]() ![]() 69 C10 Stepside ~ Project 79 K10 Shortbed 4X4 ~ Sold 72 Chevelle SS Clone ~ Sold |
Tags |
1971, gearbox, power steering problems |
