Old 10-02-2010, 08:31 PM   #1
white71chevy
white71chevy's Avatar
Need help plz
i have a 71 c10 with power steering. my problem is that my power steering gearbox has gone out it leaks all the fuild out of it in a day i cant even drive it any more. so my question is can i put a newer model gearbox on it or do i have to seach though endless junkyards to try i find one. need help guys i want to keep this thing on the road. it doesnt deserve to sit and waste away. thanks for any help guys and gals.
71 c10 with a 305. new dd wohoo
1956 chevy bel air hard top with a 327.
1998 honda passport V6 old dd.
white71chevy is offline   Reply With Quote
Old 10-02-2010, 08:49 PM   #2
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Need help plz
Buy a rebuild kit for it. I have rebuilt mine and it holds up pretty good seeing it has over 300,000 on it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-02-2010, 09:18 PM   #3
white71chevy
Re: Need help plz
Where would I get one and how much would it cost
Old 10-02-2010, 11:15 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Need help plz
I think the last one i bought was around $15-$20. Any parts store should have or can get one. I used to have to add to my 71 4x4 everytime i used it. Haven't added anything in a couple of years now since putting the kit in...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is online now   Reply With Quote
Old 10-02-2010, 11:26 PM   #5
GMCBubba
GMCBubba's Avatar
Re: Need help plz
depending on what your time is worth, you can also just get a reman'd unit from parts store, right?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 10-03-2010, 11:48 AM   #6
white71chevy
Re: Need help plz
can any one give me a part # for a rebuild kit. im looking at some but im not sure if its what i want.
Old 10-03-2010, 11:52 AM   #7
RCbowtie69
RCbowtie69's Avatar
Re: Need help plz
I would check CCP, they have a close ratio or stock ratio box, i brought the close ratio one, i like it, been driving it for year,and has not leak yet, check out the web site www.classicperform.com.
RCbowtie69 is offline   Reply With Quote
Old 10-03-2010, 12:04 PM   #8
Davetopay
Re: Need help plz
That's what I did. Saved me a bunch of labor hours because I didn't have time/space to do it my self.
Davetopay is offline   Reply With Quote
Old 10-03-2010, 01:04 PM   #9
tonypaul
tonypaul's Avatar
Re: Need help plz
You can remove the powersteering belt, and just loop the hoses together and drive it with out powersteering for a while. You just wont have power steering... I swapped a powersteering unit from a 1979 truck, it bolted right up.
tonypaul is offline   Reply With Quote
Old 10-03-2010, 01:23 PM   #10
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Need help plz
I just put a remanufactured one on my old car , I got it from o'rielly's for $40 with exchange. it was easy to do and hasn't leaked a drop since I put it on a couple months ago. it was pooring before. check there website, good luck ...... forgot to mention it comes with the reservoir all I had to do is put my pulley on it which you will need a pulley puller for.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 10-03-2010, 01:42 PM   #11
white71chevy
Re: Need help plz
I'm sorry but I'm not understanding what u mean by the that all I need I'd the gearbox everything else is fine n the system.
Old 10-03-2010, 01:57 PM   #12
red69ss
red69ss's Avatar
Re: Need help plz
so what is confusing you?
1969 CHEVELLE SS
Old 10-03-2010, 02:00 PM   #13
white71chevy
Re: Need help plz
U said pull the pully off I don't need a new pump just the gear box. Can I buy just that from them.
Old 10-03-2010, 02:12 PM   #14
red69ss
red69ss's Avatar
Re: Need help plz
ok sorry, I misread your original post and thought you were talking about the PS pump . Yes looks like they have them also for $125 with your core. call them to verify, sorry for the confusion.
1969 CHEVELLE SS
Old 10-03-2010, 02:28 PM   #15
white71chevy
Re: Need help plz
Its cool man thanks for the help
Old 10-03-2010, 02:43 PM   #16
Blake B
Re: Need help plz
Advance Auto has the close ratio gear box for 124.99 and 20% off, and free shipping online. I put one on my truck last month, so far so good.
Blake B is offline   Reply With Quote
Old 10-03-2010, 03:04 PM   #17
white71chevy
Re: Need help plz
Wat do u mean by close gear. Like it takes less turns to go from full lock to full lock
Old 10-03-2010, 03:27 PM   #18
Blake B
Re: Need help plz
3.5 turns lock to lock, verses 4.5 turns lock to lock.
Old 10-03-2010, 03:41 PM   #19
white71chevy
Re: Need help plz
Do u no the part number
Old 10-03-2010, 03:54 PM   #20
Boog
laying low
Boog's Avatar
Re: Need help plz
If your gear box doesn't have a lot of slop in it maybe try the seal kit first? I guess it only consists of an upper and lower shaft seal. Might need a puller to get the pitman arm off though.
This is something I need to do to mine also.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-03-2010, 04:59 PM   #21
Blake B
Re: Need help plz
Part No. SG17501 Advance Auto parts web site. It does not say it is the 3.5. However I called their toll free number, they called Fenco and confirmed as 3.5. Installed and it is 3.5. Be sure to use a coupon, you can google advance auto coupons and find some good ones.
Old 10-03-2010, 05:52 PM   #22
white71chevy
Re: Need help plz
Alright thanks for the help
Old 10-03-2010, 06:05 PM   #23
Little Red
Little Red's Avatar
Re: Need help plz
If it just leaking out the pitman arm shaft, thats a pretty cheap and easy fix. You can get just the pitman shaft seal for a couple of bucks. Pull the pitman arm off the shaft (leave it attached to the center link) remove the c clip that holds the seal /washer in place on the box, put the pitman arm back on snug, fill the p/s pump start the engine and turn it from lock to lock until the seal POPS and the fluid gushes. Remove pitman arm, washer and seal, clean and reinstall new parts. NOTE: this is a messy way of doing the job. but WAY faster that trying to dig that old seal out with a pick.
Some days your the bug some days your the windshield!
69 C10 Stepside ~ Project
79 K10 Shortbed 4X4 ~ Sold
72 Chevelle SS Clone ~ Sold
Little Red is offline   Reply With Quote
1971, gearbox, power steering problems
