Old 09-18-2010, 03:04 PM   #1
Vandals909
Swap questions before spending $
I'm getting ready to purchase a l92 and 6l80E to install into my 1967 c10. I have read through all of the forum, but I'm still confused.
1. Are there engine mounts that work better then others? For example being able to run the AC compressor in the stock location?
2. Which header would be best with the above recommended mounts?
3. Will I have to modify the firewall or can I remove the trans tunnel for a 4x4 one to make the transmission work?
4. Lastly the engine and trans I'm looking at is complete with factoring wiring harness, who is best to go to, to get it reworked to work with my truck and run A/C and electric fans?
Sorry guys I have a million more questions but thought I would start with these so I know what I'm getting myself into.
Vandals909 is offline   Reply With Quote
Old 09-18-2010, 03:39 PM   #2
Shon
Re: Swap questions before spending $
1) I dont have AC on mine so I dont know.
2) right now the Doug Thorley swap headers are the only option unless you want to cut frame and bend up the tubes of new headers, there is possibility that DT is going to coming out with a larger tube header (1 5/8" now).
3) Why do you need to modify your firewall?
4) I use Current Performance out of FL for the wiring harnesses.
3. While I have to modify the firewall or can I remove the trans tunnel for a 4x4 one to make the transmission work?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-18-2010, 04:28 PM   #3
Vandals909
I changed my word on the firewall. I wanted to know if I will need to modify anything to fit the larger 6l80e?
I have seen current performance for awhile. I was thinking about using then about 8 years ago. I'll have to send them an email for a price quote to modify the existing harness.
I thought I saw a post were DT was making the headers already? Anyone know what size the Street and Performance headers are? Anyone ever use them?
Thanks for the reply.
This looking for an answer on the MOTOR MOUNT question.
Old 09-18-2010, 04:42 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
The ECE mounts look great and would keep your motor forward, allowing more room for that larger trans. They also allow for 2 height settings...which may or may not work for the a/c.
That said...there are other mounts/brackets available...some universal, other specific to the vehicle.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-18-2010, 05:36 PM   #5
Shon
check out MAST motorsports truck, they run the 6l80 trans I believe....
Old 09-18-2010, 08:40 PM   #6
Vandals909
Just found this. It is a good read for someone looking to do a similar swap.
http://www.ls1tech.com/forums/conver...ng-hauler.html
Old 09-25-2010, 02:07 PM   #7
Vandals909
Still cant find a definite answer if stock A/C location can be kept with any of these aftermarket motor mounts.
Can anyone who has installed maybe the ECE mounts chime in? Thanks!
Old 10-03-2010, 04:08 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I was able to use the stock a/c compressor on my 6.0 install. However, I didn't complete the install with the ECE mounts, I sold them because engine set so far forward not allowing me to run the LS fan and factory shroud, so I didn't hook up the a/c lines to the compressor so I cant absolutly verify if it can be done.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 10-04-2010, 04:24 PM   #9
MONTEZ
90e but same difference on the size. You will have to use the 4x4 trans tunnel on a 67-72 but 73-87 trans tunnels are big enough from the factory.
Good Luck on your build, I have the same set up going in my 85. I can tell you from first hand experience that the MAST truck moves.... Even faster now that they changed it over to a LS3 with spray.
Smoke Tires, not Drugs
MONTEZ is offline   Reply With Quote
Old 10-04-2010, 05:01 PM   #10
67C10BUB
67C10BUB's Avatar
Check out my build thread in my sig. I put a lot of info in there to help others.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 10-06-2010, 01:52 AM   #11
love my 72
love my 72's Avatar
I also strongly recommend Current Performance out of Florida. he know his stuff! i would highly encourage you to ditch the oem wire harness and just go with a new one from current performance. although the can modify the oem harness (witch is what i had done) its not worth the savings over a new one.
I really really really wish i would have just waited a little longer to just buy a "new one"
I too have spent many hours with the search feature of our site looking for a motor mount adapter that will let you run the a/c compressor in the stock location but nothing yet. i know some one here has the awnser is just a mater of asking the right person
51 Chevy 3100 Deluxe Cab(SOLD)
65 **stang 6cyl
70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD])
72 C10 Short Bed Fleetside
73 Blazer 2WD Catalina Blue White Top(Needs Love)
73 Blazer 2WD Work in progress LT1/4L60E
83 Grand National (SOLD)
94 Blazer K1500 Silverado (SOLD)
96 Impala SS All original (NEXT IN LINE 2 B SOLD)
99 Tahoe 2DR, 2WD
love my 72 is offline   Reply With Quote
Old 10-06-2010, 02:43 PM   #12
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I sent John at speartech my original harness, he modified it, added performance tune and matched speedo to rear gear and tire size, removed rear o2s vats egr etc. About 5 wires to hook up and done.
Old 10-06-2010, 03:36 PM   #13
Vandals909
Is the only option to make your own motor mounts to get the A/C to fit in the stock location without cutting the frame?
Old 10-06-2010, 07:33 PM   #14
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Some company makes high mount a/ c comp brackets.
Old 10-06-2010, 09:33 PM   #15
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Here are some options. I found these in Thealiens LS swap info sticky at the top of this forum. http://c1pulleys.com/lschevyvictoryseries.html
http://www.kwikperf.com/lsx_ac.html
http://www.novak-adapt.com/catalog/a...cation_kit.htm
Old 10-07-2010, 11:21 AM   #16
Vandals909
Does anyone have experience with running either one of those setup?
I remember reading another members post were he used a street and performance a/c relocation bracket and he has been through 3 belts. He was looking for a different setup
Old 10-07-2010, 12:16 PM   #17
faribran
you might contat HARTROD... i think he has used the ECE ones.
faribran is offline   Reply With Quote
Old 10-07-2010, 12:22 PM   #18
Clyde65
Clyde65's Avatar
I saw on LS1Tech.com alot of guys have the Kwickperformance ac bracket, however you need to change to a Sanden compressor. Those guys seem to really like that bracket setup and it isnt as expensive as S&P.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
