#226 | |
![]() Join Date: Jul 2006
Re: Project "Popeye"
I'll get some engine mount pics for you.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#227 |
Registered Chevy Owner
I saw this thread a while ago; when you first got it. I thought I was subscribed, but I guess I wasn't. I just found it again. You've been busy.
I thought about doing the trailing arm set up on my '51. Looks like that is working out great for ya.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#228 |
Yeah, the arms worked out great. I think the ride will be worth it. I've been through your build a few times too, I love the s-10 bed, still considering doing that in Popeye.
#229 |
I thought about doing the S-10 bed but I decided not to. The pix of that on my build thread are from Bluejeep; he put the S-10 bed in his.
#230 |
67cheby
![]() Join Date: Sep 2008
the s-10 bed thing had my curiosity up, so i had to check that out , i think that would be killer on POPEYE, i like it with the tubs in it in case you ever run wider wheels
#231 |
I might have to do some small tubs, looks like I've only got 1/2 tire clearance at ride height. Surely an S-10 bed can be found cheap.
#232 |
Yes, I did the s10 bed floor in mine and I like it. I first had the tubs, but cut them out later so that I could haul plywood in the bed. Here's the pics again:
Mock up: ![]() ![]() Since mine's a long box, I had to add to the front: ![]() Wheel tubs filled in: ![]() And how it looks currently: ![]()
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 10-14-2010 at 10:05 PM. |
#233 |
Ooops, got you mixed up with nickp51chevy. Bed looks really good!
#234 |
Jumped over here to see what popeye was. Looking good. I have a 52 big truck in hidding I want to put a tube frame under with a suicide front and chop with a straight 6 or even better a straight 8.I just sold my 52 Daily driver. Metric subframe with v-8 auto, ps pb and cruise. You should have seen peoples faces when I'd blow by them on I-44. I'll try to post a pic or 2.
Not trying to jump on your thread here. Looks like you have a nice little place to work on your toys also. |
#235 |
Oh man that's a cool truck!
#236 |
Thanks I have my moments.Yours has me itchen to start my tube frame truck. I really wish I could sell the 71. I'm just getting tired of it. The only reason I want TBI is something to do more or less. 700r4 should be put together this week. I may try to get it in next weekend.
#237 |
The transmission is finally in for good and the Hurst shifter cleaned up real nice after a soak in oxalic acid and some soda blasting then a little grease. It shifts nice and smooth, not sloppy like I expected. I also mocked-up the brake booster and decided that I'm going to move it up to the firewall. The brake arm hits the clutch arm and also there is no room for exhaust on that side.
I spent some time yesterday modifying the center crossmember to make room for the driveshaft. Luckily I had some 1/4" plate and was able to cut a section out and fab a hump. I have a driveshaft being made next week. As you can see I have a large but manageable to-do list left for the chassis! This week is brake lines...
#238 |
looks good man....
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#239 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Looking good leevon.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#240 |
67cheby
looking good man
#241 |
Nice. Ive got one of those boards in my garage too, but not as much marked off.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
#242 |
Nice thread Leevon...Great work. I'm learning as I lurk on the site. The under frame power brake setup and your exhaust situation is an eye opener. I have a bone stock 55 second generation big window shortbox and plans are formulating, but reading and doing research are going to pay off. I'll keep lurking, and you keep posting pictures...deal? You're son is going to love the truck when it's done!
Rob |
#243 |
The build project is coming along good. Looking good.
For those that are looking for a small wheel tub, check out the trailer fender at Tractor Supply or Northern Tool. I was looking at them this weekend and they would be easy to cut and weld into the bed sides. I think I'm going to use the trailer fenders.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 Last edited by 52 Rat; 12-11-2010 at 11:49 PM. |
#244 |
Leevon, where are you sticking your gas tank. I see your air tank is where most mount there gas tank.
Posted via Mobile Device |
#245 | |
Thanks everybody!
I've let this thing stall out...lost my sister on 12/13, she was 27 and had three kids so priorities changed a bit. It's funny how things come into perspective and become irrelevant at times (like one's hobbies). Slowly getting back to "normal" though, and I'm going to try and do SOMETHING, anything on the truck this weekend to get the fire back. It's been really freakin cold here too and I'm a big baby about cold so that's not helping either. ![]()
#246 |
67cheby
cant wait to see progress, and im am truely sorry for your loss, God bless you and keep your head up, have gone through more than my share of the same kind of losses i understand
#247 |
Thanks Mike. I remember that day I came by (10th) vividly for some reason, it was a fun day with my daughter and a nice to visit with you.
I'm getting back to it though, starting with that brake booster bracket. Just need a little motorvation. ![]()
#248 |
67cheby
lets get crack- a -lakin
#249 |
Sorry to hear about your sis. There has been a lot of that over here in the last two months. I understand about the cold. Y'all definitely got it worse. I look forward to your updates and hope you get your mojo back.
#250 |
looks good. subscibed
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
