Old 10-18-2010, 12:04 AM   #26
VA72C10
VA72C10
VA72C10's Avatar
Re: [PROJECT] Laidout53 Part II
very nice!!!
Old 10-19-2010, 12:00 AM   #27
FnLow69
FnLow69's Avatar
Well i got the frame rails capped and the tie rod notches cut. only got on welded in. heres the pictures for today.
Smoothed...
Tie rod notch welded...
Smoothed...
let me know what you all think
Justin
FnLow69 is offline   Reply With Quote
Old 10-19-2010, 12:02 AM   #28
VA72C10
VA72C10
VA72C10's Avatar
Looking good as usual! Keep at it! You're making nice progress.
Old 10-19-2010, 12:15 AM   #29
jwalk
What was I thinking?
jwalk's Avatar
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 10-19-2010, 12:37 AM   #30
narx66gmc
subscribed!! keep up the good work and thank you for building your crossmember, i am gettin gmore courage to do the same... on the next project.
Build Thread - Papa's truck build up
narx66gmc is offline   Reply With Quote
Old 10-21-2010, 08:02 PM   #31
FnLow69
FnLow69's Avatar
Thanks guys...hopefully I can get the other notch in tonight.
Old 10-21-2010, 08:50 PM   #32
kev2809
low n' slo
kev2809's Avatar
looking good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-21-2010, 09:06 PM   #33
SCOTI
SCOTI's Avatar
You definitely have the 'touch' for fabbing. I like it!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2010, 01:42 AM   #34
FnLow69
FnLow69's Avatar
Well i worked on it last night and today. Got the other tie rod notch done and the welded and smoothed. All the joints will get plated later. Today I got the front crossmember in and made the upper A-arm mounts still need to make some gussets for them.
Anyways here are the pictures...
Crossmember tacked in...
Lower arm bolted up...
The upper arm mounts...(forgot to take progression shots)
Spindles and rotors on...
What do you think?
Justin
Old 10-25-2010, 09:46 AM   #35
VA72C10
VA72C10
VA72C10's Avatar
Looks great!!!
Keep up the good work....because the sooner this is done the sooner you can get back to the 69
Old 10-25-2010, 12:11 PM   #36
67cheby
67cheby
67cheby's Avatar
wow..amazing job
67cheby is offline   Reply With Quote
Old 10-25-2010, 02:53 PM   #37
rondog4416
rondog4416's Avatar
you can work on my truck anytime you want !! great job !!
rondog4416 is offline   Reply With Quote
Old 10-25-2010, 06:23 PM   #38
jwalk
jwalk's Avatar
Man thats looking killer!
Justin
Old 10-25-2010, 06:49 PM   #39
FnLow69
FnLow69's Avatar
Thanks guys
Old 10-25-2010, 09:37 PM   #40
68laydout
Junior Member
68laydout's Avatar
Awesome work as usual!
68laydout is offline   Reply With Quote
Old 10-26-2010, 09:35 AM   #41
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
tivo activated
IvelDesigns is offline   Reply With Quote
Old 10-31-2010, 02:01 AM   #42
FnLow69
FnLow69's Avatar
Heres tonights progress, got the gussets made and welded for the upper arm mount. Also got started on the front clip/radiator mount.
Heres the pictures...
Justin
Old 10-31-2010, 02:54 AM   #43
jwalk
jwalk's Avatar
Maybe one of these days I'll attempt a full frame build. You make it look so easy.
Justin
Old 11-08-2010, 08:27 PM   #44
FnLow69
FnLow69's Avatar
Well i got to work on the frame last night a today, got the bag mounts made up front. Had to get 2" drop spindles, so i got those installed mocked up the rack to make sure it would fit. Also got the frame gussets cleaned up and tack where there suppose to go.
Anyways heres th pictures...
bag mounts
rack mocked up
And the frame gussets tack on
Justin
Old 11-08-2010, 09:00 PM   #45
Mike J
vw guy & now c-10 guy
Mike J's Avatar
looks awesome man. really like the frame gussets, function and style
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 11-09-2010, 10:46 AM   #46
67cheby
67cheby
67cheby's Avatar
WOW.... this rocks !!
Old 11-09-2010, 11:58 AM   #47
SCOTI
SCOTI's Avatar
I love the detail aspect w/the gussets....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-09-2010, 12:13 PM   #48
67cheby
67cheby
67cheby's Avatar
its going to be a shame to cover up that frame with a body !!
Old 11-09-2010, 01:36 PM   #49
-sean-
Thumbs up Re: [PROJECT] Laidout53 Part II
I don't no whether to be motivated or discouraged. Amazing work!
-sean- is offline   Reply With Quote
Old 11-09-2010, 03:52 PM   #50
SCOTI
SCOTI's Avatar
I had the same thought this morning when I checked the update....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
