Old 09-21-2010, 10:28 PM   #101
swamp rat
swamp rat's Avatar
Re: '72 Chevy SWB, Project Driver
All I did to mount the hinge was grind two small notches for the original hinge blots to sit. Nice and solid, no need to weld any for the hinge. I did need to bend the hinge slightly to get the lens to sit right.
The welds are ugly....I was having problems lol. The filler is mounted using a strap of 1/8 steel and then the strap is screwed to the bed. The filler "bucket" is just mounted to the filler, not screwed in at all, but it fits good and solid.
[/QUOTE]
Could you let me know what vehicle you got the doner parts from for the gas flip door, bucket and filler pipe? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-22-2010, 02:58 AM   #102
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
95ish chevy Blazer. The write up is here.
http://67-72chevytrucks.com/vboard/s...&postid=599699
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 09-22-2010, 03:54 AM   #103
swamp rat
swamp rat's Avatar
Thanks for the info!!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-03-2010, 09:31 PM   #104
usmcchevy
usmcchevy's Avatar
Well some stuff has been going down around here 3/5 drop 1 and 1/2 coils cut off the front springs and 5" McCarthys rear springs with CPP track bar and SCOTI's OE shock relocation brackets. I need to get some smaller front tires, these are just what came with the rims. If anyone has a couple 235/60r15s laying around let me know.
Replaced these.
Build thread
LSx Swap FAQ index
Old 10-03-2010, 09:34 PM   #105
usmcchevy
usmcchevy's Avatar
Before:
After:
Build thread
LSx Swap FAQ index
Old 10-03-2010, 09:36 PM   #106
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
cool, looking better all the time, any pics of the underside?
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 10-03-2010, 09:48 PM   #107
brn agn
brn agn's Avatar
I like it! The slots look good on the truck too!
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 10-03-2010, 09:48 PM   #108
VA72C10
VA72C10
VA72C10's Avatar
nice improvement!!!
Old 10-03-2010, 09:52 PM   #109
fishingjred73
fishingjred73's Avatar
O Yeah much better!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 10-03-2010, 10:01 PM   #110
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
MUCH better, got the link to scottis shock relocators? Ive seen it but didnt save it Truck looks GOOD
John
1999 Toyota Tacoma 4x4
Old 10-03-2010, 10:20 PM   #111
usmcchevy
usmcchevy's Avatar
Sure do! http://67-72chevytrucks.com/vboard/s...d.php?t=359399
I used a 4lb hammer and my poor little 4in bench vise to beat the lower brackets flat.
Build thread
LSx Swap FAQ index
Old 10-03-2010, 10:35 PM   #112
oldblue1968chevy
thanks! what shocks did you use? trac bar?
John
Old 10-04-2010, 04:25 PM   #113
usmcchevy
usmcchevy's Avatar
Thanks Everyone!
I'll have to get some tomorrow. Nothing special, still rusty, but I wanted it lowered for Crusin'
Still running the stock shocks all around. Rears actually feel great, front............. I've got some work to do Track bar is a CPP Super track bar kit.
Build thread
LSx Swap FAQ index
Old 10-04-2010, 05:29 PM   #114
tantrumpipeline
I just want to see the mounts really, and cpp installed, good work on the build, driving it during the build would be the answer, shouldn't have started rippin mine apart, but the cab had to be swapped and it's not a daily, super jealous
20 Duramax tow pig
52 short project
Old 10-04-2010, 07:23 PM   #115
chevyboy55
chevyboy55's Avatar
Ben
I just sat & read 5 pages of your build thread. NICE WORK! looks a lot better sitting lower I'm kinda partial to low though. keep it up. Mike
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 10-05-2010, 02:54 PM   #116
usmcchevy
usmcchevy's Avatar
Thanks guys. The reason I'm trying to get it to be a driving project is I already destroyed one of these trucks. I was 15 when I got my '70, blew up the motor and tore down the whole truck for restoration when I was 17. I ran out of time, space and money. I ended up selling it as a pile of parts when I was 22 when my dad was sick of looking at it.
Took the truck to CTC today. Need to do something with the choke, floods every time I try to start it when warm.
Heres the rear suspension pics.
Build thread
LSx Swap FAQ index
Old 10-13-2010, 09:02 AM   #117
bguild
bguild's Avatar
Originally Posted by 72BlckButy View Post
Nice progress, and props to Rowland for the offer.
Roland hooked me up as well.. He is the man.. Awesome guy.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 10-18-2010, 01:13 PM   #118
usmcchevy
usmcchevy's Avatar
Yes he is!
No real noticeable progress.
I finally got it inspected today and got my hot start problem sorted out. Had two problems with the carb, choke was set wrong and it was full of crud AGAIN. Also got the parking brake working and cut 1" off of all the bump stops. It rides much better now.
Build thread
LSx Swap FAQ index
Old 10-19-2010, 09:40 AM   #119
Roland
Junior Member
Roland's Avatar
Great job, Ben. I wish I were making the progress you are. Seems like everytime I start to move forward, I think, "...well, since I'm this far into it, I might as well take this apart and check it out." Still going backward after two years. But! It's still fun!
Roland is offline   Reply With Quote
Old 10-19-2010, 01:29 PM   #120
68 TT
Still plays with trucks
68 TT's Avatar
That is the hardest thing to resist when building a vehicle. It is so easy to get the "you might as well" disease and go off the deep end.
I had that problem really bad on my last Camaro. Original plan was to just replace all the age hardened body bushings & suspension bushings over one weekend then $60k and a year later I ended up with a completely rebuilt and restored car.
It turned out OK though because that car helped me get out of my bachelor pad and buy a house in a nice neighborhood where I wanted my children to grow up and go to school. No shop or garage to work in now but my girls are worth it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-19-2010, 02:04 PM   #121
bguild
bguild's Avatar
I actually had to take a step back from my project.. This is my 2nd project truck. The last one I had it torn down to a frame with no money to get it back together.. This one I have decided I am going to get it running driving for awhile and enjoy it for a few months before i tear it down to do the patch panels and air ride.. Its tough to not fall into that habit.
Great work on the truck
Toys:
2014 Dodge Ram
1967 SHORTBED
Old 10-19-2010, 02:34 PM   #122
Pop's C-10
Pop's C-10's Avatar
nice work..i've always loved slots..
Pop's C-10 is offline   Reply With Quote
Old 10-19-2010, 02:39 PM   #123
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice job! You've came a long way with this truck. Keep up the great work.
Ryan
1969 Chevy milk truck
Old 10-19-2010, 07:26 PM   #124
oldblue1968chevy
Love it man, keep at it!
John
Old 10-20-2010, 08:01 AM   #125
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
