Old 10-30-2010, 08:36 AM   #26
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: lowered my truck today
Lookin' good!
I completely agree with you concerning ECE... they are top notch!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-30-2010, 10:24 PM   #27
VA72C10
VA72C10
VA72C10's Avatar
you having some rubbing issues??? Read in the stock spring needed thread you were having an issue....
Old 10-31-2010, 05:16 AM   #28
dmwphoto
dmwphoto's Avatar
yes, front tires are rubbing inner fender well on dips and dips and turns. I either need a smaller tire or go up one inch. I think putting the stock spring back in with the 2 1/2 drop spindles will do the trick. I was in denial on the first road test but now I am going to have to deal with it.
dmwphoto is offline   Reply With Quote
Old 10-31-2010, 09:42 AM   #29
aintmisbehavinn
Sharp; where'd the bucket seats come from? Awesome truck...
aintmisbehavinn is offline   Reply With Quote
Old 10-31-2010, 12:04 PM   #30
POPO1984
POPO1984's Avatar
what size tire are you running
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 10-31-2010, 12:21 PM   #31
RCbowtie69
RCbowtie69's Avatar
Hey from from N.C. great looking truck, the drop look good on your ride, keep on truckin''
RCbowtie69 is offline   Reply With Quote
Old 10-31-2010, 03:26 PM   #32
VA72C10
VA72C10
VA72C10's Avatar
17 x 7 on the front with 245/50/17 and 17 x 9.5 on the rear with 275/60/17 BF Goodrich tires.
That's weird it's rubbing...the tire is a lot shorter than a stock 235 75 15. Only 26.6" tall. So you wouldn't think it'd have any issues...almost seems like you got a 2 or 3" drop spring instead of a 1" spring now that I look at it more...That's not much fender well clearance for only 3 1/2" drop....
Old 10-31-2010, 05:20 PM   #33
dmwphoto
dmwphoto's Avatar
Jonathan if that is the size I said I was running earlier it is wrong. I have 17 x 7 245/65/17 on front. Rear is correct as you quoted. the front are 28.5" inches tall
Old 10-31-2010, 05:23 PM   #34
dmwphoto
dmwphoto's Avatar
The seats were in it when I got it but I think they are out of an 84-87 monte carlo
Old 10-31-2010, 05:58 PM   #35
lolife99
67-72 parts collector,…
lolife99's Avatar
Don't raise it up.
It looks good the way it is.
I vote for shorter front tires!
Keith
Convert to disc brakes.
Old 10-31-2010, 06:01 PM   #36
dmwphoto
dmwphoto's Avatar
shorter front tires may be the way to go if I can get them in 17s and not be too different from the rear in looks (tread)
Old 10-31-2010, 06:34 PM   #37
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Very nice classy looking truck. White is a classic timeless color and your truck really looks super with the drop and classic rims.
That is exactly the drop I want to do to my longbox as well and was wanting to run 255/70R15's all the way around but they are 29.06 inches tall and your front 245/6517 tires are 29.54 inches tall and I do not want any rubbing issues but would like 4 tires the same size. .
Heres a question .. Does using the same size tire (for instance a 255/70R15) on a 8 inch rim instaed of a 7 inch lower the tire as the tire has to stretch more ( which should push it down?) to fit the 8 inch as opposed to the 7 inch.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is online now   Reply With Quote
Old 10-31-2010, 06:39 PM   #38
dmwphoto
dmwphoto's Avatar
No it will not affect the tire height in the two different rims. Thanks for the compliments. Where did you get the 29.54" on my tire size info? the specs I found say 28.5"
Old 10-31-2010, 06:56 PM   #39
VA72C10
VA72C10
VA72C10's Avatar
You might want to do a physical measurement. The tire size calculator I used also said 29.5" for that size tire.
Old 10-31-2010, 06:58 PM   #40
dmwphoto
dmwphoto's Avatar
I will. What calculator tool are you using? How would a 225/60/17 measure?
Old 10-31-2010, 07:06 PM   #41
Already Gone
The 29.5 I think is just a rounded off number but since you asked, here is how I arrive at my tire sizes. I always take the section width ,in this case 245and times it by .03937 which gets to the width in inches which is 9.65 inches. The sidewall height ratio is 65% of the 9.65 which in this case is 6.27inches. Add the sidewall height height by 2 and the rim width ( 17 )in this case and :
17.00
6.27
6.27
29.54
Old 10-31-2010, 07:09 PM   #42
Already Gone
According to my calculations the height should be 27.64 inches of you could use 27.6 with the 4 being 4/100ths of an inch.
Old 10-31-2010, 07:11 PM   #43
dmwphoto
dmwphoto's Avatar
thanks Greg. so if I am following along well the 225/60/17 would be
17
5.76
5.76
____
28.52
Old 10-31-2010, 07:11 PM   #44
dmwphoto
dmwphoto's Avatar
hmmmnnn
Old 10-31-2010, 07:13 PM   #45
dmwphoto
dmwphoto's Avatar
my bad I used 65 when I did the math
Old 10-31-2010, 09:42 PM   #46
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by 72BlckButy View Post
Lookin' good!
+2
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 11-01-2010, 05:47 AM   #47
Already Gone
17
5.76
5.76
____
28.52
Should be:
17
5.31
5.31
27.62
Old 11-03-2010, 03:47 AM   #48
greenbd71
greenbd71's Avatar
Question Re: lowered my truck today
So how does it handle now that it is lowered? Is is more or less bumpy on the road? Just curious about the good and bad when the truck is lowered.
greenbd71 is offline   Reply With Quote
Old 11-03-2010, 05:56 AM   #49
dmwphoto
dmwphoto's Avatar
It handles great. Overall I would say the ride is improved. Obviously I need to eliminate the rubbing in the front. Also one of the exhaust pipes now rubs the frame on bumps. I am planning a different exhaust system so I will eliminate that issue. There are always some issues when altering so you have to be prepared to identify and deal with them. The look of the truck now is outstanding and really draws attention. I am replacing front tires later this week and will post back the results.
Old 11-04-2010, 09:46 AM   #50
DALTON
69 C-10 Short Fleet
DALTON's Avatar
Good looking truck,,,like the white. do you get any glare off of the white dash? I want to go with white however, some told me the white dash blinds you
Tony Dalton
DALTON is offline   Reply With Quote
