Old 11-01-2010, 09:23 PM   #1
lsp1369
Front coil spring stuck!
(73 c10)
well.. i started tearing into my front end this morning so i could clean it up and replace all bushings and ball joints, and i kinda expected a little tension on the coil spring when i dropped the lower arm, and the spring didnt move at all. i took the rest apart and it seems that the spring has 2 coils wedged into the upper spring socket, as if someone jumped it or hit somethin really hard.
any ideas on getting this out safely without damaging other parts or myself??
btw, not planning on keeping this spring, so i was thinking plasma cutter unless you guys have any ideas to just get it out and i could possibly save the spring.
thanks guys.
lsp1369 is offline   Reply With Quote
Old 11-01-2010, 09:34 PM   #2
lsp1369
Re: Front coil spring stuck!
here are a couple pictures of what im workin with.. i left the lower arm on so i might be able to compress the spring and try that route.. but i think im gonna have to end up cutting it..
Old 11-01-2010, 09:37 PM   #3
bigblock73
yeller
bigblock73's Avatar
Raise the LCA enough to contain the spring should it try to shoot out, then kick the spring a few times with your foot or hit it with a 5 pound sledge...it'll pop loose. Same thing happened to my 77 on one side. When mine came loose, it just fell down, there wasn't much, if any tension on it at all.
bigblock73 is offline   Reply With Quote
Old 11-01-2010, 09:39 PM   #4
lsp1369
ill give it a try, but i tried using my prybar wedged between the spring and the perch and it wouldnt move at all, do you think the lower arm would relieve that much tension?
Old 11-01-2010, 09:52 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
YES... i used a large prybar to pop mine out not much tension when i did it
could always sawsall it too
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-02-2010, 12:14 PM   #6
lsp1369
well.. its out.. it took the gentle persuasion of a ratcheting tie down(now broken), two rather large pry bars and a hammer.. and it was locked in there tight.. you guys must have had it made with yours.. this one was tough. but thanks for the input you guys, im just glad i was able to save the coil.
btw... anyone need any 1/2 ton front coils??
